Roof remote control
- Pastry
Roof remote control
Is it possible to get a thingamajig to make the roof work via the remote control key and if so, does anyone on here fit it as I'm pretty useless at that sort of thing?... or according to the wife, everything
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
- markplant
Roof remote control
You can get a plug n play I'll look for the link
- Pastry
Roof remote control
Thank you is that for an E89?markplant wrote:You can get a plug n play I'll look for the link
991 Carrera 2S
Now gone:
Now gone:
- markplant
Roof remote control
- markplant
Roof remote control
E89 link above
- Pastry
Roof remote control
Sounds spot on... I wonder how 'plug and play' plug and play ismarkplant wrote:http://www.mods4cars.com/sms/shop/index ... iew&id=112
991 Carrera 2S
Now gone:
Now gone:
- mr wilks
Roof remote control
You should already be able to lower the roof mr P just by holding onto the open button on remote , need to keep it pressed though as its not a one touch feature .
Doesn't work on raising for some reason
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- markplant
Roof remote control
Was always told it doesn't work on close as it has no anti trap feature, it will probably work with key in door lock and turn an hold in the lock position same as e85, as it means you are next to the car
- Pastry
Roof remote control
The panoramic roof and windows in my X3 do that so tried the Zed but nothing. The guy from the service department told me it was an option with comfort access as there was no safety anti trap feature, do you have comfort access on yours?mr wilks wrote:You should already be able to lower the roof mr P just by holding onto the open button on remote , need to keep it pressed though as its not a one touch feature .
991 Carrera 2S
Now gone:
Now gone:
- jimbo1958
Roof remote control
And if you're not in a rush, keep an eye in the Classifieds here as they do come up from time to time.
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
- mr wilks
Roof remote control
Nope , no fancy comfort access stuff . I just hold the open car button from locked & away it goesPastry wrote:The panoramic roof and windows in my X3 do that so tried the Zed but nothing. The guy from the service department told me it was an option with comfort access as there was no safety anti trap feature, do you have comfort access on yours?mr wilks wrote:You should already be able to lower the roof mr P just by holding onto the open button on remote , need to keep it pressed though as its not a one touch feature .
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Roof remote control
It's closing from the key that's possible via comfort access. Opening from the key should be possible on any car provided you do not have the software updates to prevent OBD access. This also prevents lowering of the roof from the metal key and from the fob.
- Pastry
Roof remote control
markplant wrote:Was always told it doesn't work on close as it has no anti trap feature, it will probably work with key in door lock and turn an hold in the lock position same as e85, as it means you are next to the car
I think I've just been a bit of a div Im pretty sure it was closing I've tried and just assumed it wouldn't open but with the lack of anti trap its making sense now too much sunshine, I'll have a go when I'm back from holidaymr wilks wrote:
991 Carrera 2S
Now gone:
Now gone:
- Pastry
Roof remote control
I'd just figure out my own stupidness and what you said makes perfect sense nowManiac wrote:It's closing from the key that's possible via comfort access. Opening from the key should be possible on any car provided you do not have the software updates to prevent OBD access. This also prevents lowering of the roof from the metal key and from the fob.
991 Carrera 2S
Now gone:
Now gone:
- markplant
Roof remote control
If the remote doesn't seem to be playing ball, use the key in drivers door lock an hold in unlock position, see if that works, then try the same with roof open but hold the key in the lock position, if that does operate the roof then it should only need a bit of coding to make it work from key , but you will still have to press an hold the lock it unlock on the key fob
