Thats what you do, and pretty much thats what I do when working on brakes either car or bike but there is no way your normal dealer mechanic goes to all that trouble on everybodys brakes.andyfanshawe wrote:At my shop.....Bluecat wrote:When i had my z4 coupe insp 2 done,the indy garage I used highlighted that the pads and discs were between 80-85% worn, they stated that its 1.5 hours labour to replace all discs and pads, thats from the official bmw site, so if its 45 mins to do front pads and discs must be less than 30 mins to do the pads?
Drive car in
Put lift legs under it
Reposition car because legs wont go under pads unless its in the perfect position!!
Find locking wheel nut
Phone owner to ask where locking wheel nut is....
Raise car
Remove both front wheels
Remove caliper and hang it from the coil spring on a metal hook.
Spray caliper, and especially piston dust boot with brake clean.
Clamp off flexible line and loosen bleed nipple, attach tube and press piston in.
Tighten bleed nipple.
Remove pad carrier bracket and media blast areas where pad contacts.
Check any sliders and boots are free to move
Clean any metal shims if present
Grease areas on pad carrier where pad goes
reinstall pad carrier and torque bolts to spec
Sliver of grease on new pads and install (not forgetting pad wear sensor)
Reattach caliper and torque bolts up.
Repeat on other side
Spray aluminium antiseize grease on hub where wheels contact
Wheels back on
Lower to floor
Torque wheel nuts up
Put locking wheel nut back where I found it (cleaning it first)
Check brake fluid level
Wipe mucky hand marks off wheels
press pedal a few times to position pads in correct place
Remove overalls........wash hands, quick test drive
Reset any service indicators
Phone customer to say car is ready
All that in 30 minutes????? YEAH RIGHT!!!.......And i still only charge 40 to 45 for fitting pads.
So everybody wants a quality job on their car, but most are not prepared to pay for the time it actually take to do this quality job.
Thank god I was a teacher before this, and not a mechanic to earn a living.
I only take certain jobs on, but all are done with great care. But if someone says to me you only need 30 mins to do the pads....guess what............take it somewhere else then.
Find a good Indy to do this job. One you can trust. BMW are taking the p*ss to charge what they do.
Enough said.
Andy
I have no doubt that pads could be changed in 30 mins but its whether or not you should change them in that time is the question.
