What weights are you reffering too? Will be handy to know for when I change over to MPSS! ThanksWrs wrote:So the wheels weren't balanced after the tyres change? Even if they have, I'd start with getting the weights checked (this was the problem I had when I changed from run flats to MPSS last year) and if not sorted then go for a proper alignment. Preferably a Hunter system. Best of luck mate & welcome to the forum btw.nathannjay wrote:I don't think there's been any. Haven't had a balance since I've owned the car for about 6 weeks now, but I know the dealer I bought it off had it done before I bought it. yeah I think that would be a good idea!Wrs wrote:Are you feeling any vibrations through the steering wheel? I'd suggest getting your wheels balanced (if not done already) and a 4 wheel alignment carried out?
Please help - Non-RFT Tyre Change Issue
- sunnydays
- alex
I assume he's talking about the small weights they add to the wheels to make sure they are balanced.sunnydays wrote:What weights are you reffering too? Will be handy to know for when I change over to MPSS! ThanksWrs wrote:So the wheels weren't balanced after the tyres change? Even if they have, I'd start with getting the weights checked (this was the problem I had when I changed from run flats to MPSS last year) and if not sorted then go for a proper alignment. Preferably a Hunter system. Best of luck mate & welcome to the forum btw.nathannjay wrote:
Don't wish it was easier, wish you were better
35iS - Space grey, red leather and 19" 326Ms - now gone to a fellow forum member
- WLH
Bedding in take 250 to 500 miles....
Also could be a balance problem.
- Wrs
Correct.alex wrote:I assume he's talking about the small weights they add to the wheels to make sure they are balanced.sunnydays wrote:What weights are you reffering too? Will be handy to know for when I change over to MPSS! ThanksWrs wrote:
Gone - Black Sapphire Z4 E89 35is
Gone - Midnight Blue Z4 E85 3.0si
Are the tyres by any chance uni rotational ?
- Ewazix
The Eagle F1A2's are asymmetric hence my suggestion previously to check that the fitting instruction on the sidewall is visible, it says "outside" (or "lado exterior" if they are euro supplied). I must admit I didn't know the difference between directional and asymmetric until I got the Eaglesraymond.harper wrote:Are the tyres by any chance uni rotational ?
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- Kingfisher
The asymmetric labels are the first thing to check and then the balance weights to see if they're missing. Goodyear don't make tyres that make your car handle badly on purpose! Last, find out from anyone on here what pressures they run on your model with those tyres. If all that fails visit the fitter and get them to sort it with balancing/alignment/toe-in checks and if that doesn't work find someone, with all the right machinery, who does set-ups on racing cars, and if that still doesn't work ... buy some run-flats! ...
Dec 2014 ... E89 35is sDrive M DCT ... Red ...
- ronk
The last E89 did not give me any confidence at speed on the Autobahn last year - 100/120 ish it seemed like a constant battle. Constant correction was needed.Kingfisher wrote:The asymmetric labels are the first thing to check and then the balance weights to see if they're missing. Goodyear don't make tyres that make your car handle badly on purpose! Last, find out from anyone on here what pressures they run on your model with those tyres. If all that fails visit the fitter and get them to sort it with balancing/alignment/toe-in checks and if that doesn't work find someone, with all the right machinery, who does set-ups on racing cars, and if that still doesn't work ... buy some run-flats! ...
The dealer had just fitted new Bridgestones and I had checked all pressures with an analogue, top quality gauge.
In the Uk at Uk motorway speeds it was fine!
This is a description of (some of) the ways my Bridgestone run-flats performed.ronk wrote: The last E89 did not give me any confidence at speed on the Autobahn last year - 100/120 ish it seemed like a constant battle. Constant correction was needed.
That said, they did much worse things, too.
Vidi, vici, veni
- Buckz
actually AS3's do not have "outside" etc on the outside of the tyre.. they have a big marker on the inside of the tyre, it of course says "INSIDE" hahaEwazix wrote:The Eagle F1A2's are asymmetric hence my suggestion previously to check that the fitting instruction on the sidewall is visible, it says "outside" (or "lado exterior" if they are euro supplied). I must admit I didn't know the difference between directional and asymmetric until I got the Eaglesraymond.harper wrote:Are the tyres by any chance uni rotational ?
Thanks for all the replies guys - I've taken your advice and after 400 miles and a wheel balance at my local garage it's now all sorted!
Current:
Z4 E89 sDrive35i DCT
Gone:
Z4 E85 2.5i Manual
Z4 E85 2.2i Manual
Gone:
Z4 E85 2.5i Manual
Z4 E85 2.2i Manual
- Wrs
Great news!!nathannjay wrote:Thanks for all the replies guys - I've taken your advice and after 400 miles and a wheel balance at my local garage it's now all sorted!
- benv6
great stuff !!
Bedding issue I guess
Love your motor - mine is the exact same except I want your M-Sport Bumper!benv6 wrote:great stuff !!
Current:
Gone:
Z4 E85 2.5i Manual
Z4 E85 2.2i Manual
Gone:
Z4 E85 2.5i Manual
Z4 E85 2.2i Manual
- benv6
Haha .. thanks Nathan .. and I would like your DCT plz ... Initially I wanted a manual but now regretting not having bought the DCT in such a car but hey ...nathannjay wrote:Love your motor - mine is the exact same except I want your M-Sport Bumper!benv6 wrote:great stuff !!
