Rear Light Facelift Update Cheap How to
Re: Rear Light Facelift Update Cheap How to
Can anyone tell me how to code the LCM? i bought the software but i have no idea how to go about coding it
hope you guys can help
- half
I'm done. I modified the bumper of E85 by smoothing the corners. I really like. The bumper seems less stocky and is more rounded.
I even encoded the lsz so I did not put the resistance and I did turn on only the LEDs as the location.
Thank you all!
- LukeMace
That looks great! Fantastic job! Well done! Always nice to do something yourself an look back and admire your handy work!
Good job too with the bumper. How did you manage to shape it?
3.0, Quad Conversion, 19" CSLs, Bucket Seats, Big Brake Conversion, Lowered 40mm, AE and Clear Hockeys etc...
CLICK HERE FOR THE BUILD THREAD
- LukeMace
Trying to get my ncs expert to run this evening to sort the T effect out and stop checking for errors.
Not having much luck though at the min!
- Alun1976
+1 how you shape it?LukeMace wrote:That looks great! Fantastic job! Well done! Always nice to do something yourself an look back and admire your handy work!
Z4 3.0i Roadster (ESS TS2 supercharged, E36 M3 headers, AA methanol injection, E46 M3 Rear axle inc LSD, Brembo (Porsche) Brake upgrade, M3 CSL discs, KW V3 coilovers, Eibach wheel spacers, Miltek backbox, CDV delete, 6-speed illuminated M gear knob.)
- mac27040
You need to use ncsexpert to code the LCM see link for codes http://www.muga-uk.co.uk/z4/bmwz4e85-86revA.pdfsebeast wrote:Can anyone tell me how to code the LCM? i bought the software but i have no idea how to go about coding it
Heres a guide to how to use ncsexpert
http://forums.bimmerforums.com/forum/sh ... NCS-Expert
Sent from my iPhone 5 using Tapatalk pro
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- half
It is not necessary to dismount the bumper for bevel angle. It is sufficient to loosen it and get it down to 5 cm. Then with this http://www.grecoshop.it/ptech/scheda.asp?id=2173 I sanded chamfers to complement to the headlight. The bevel should be lifted up as if to pierce the bumper. Then grouted, Sands and paints.
The US Army has spent 1/2 hour.
I DID IT! i installed the lights, did all the wiring and installed the bumper! next step is to take it in along with the new aero front bumper so the WHOLE car can new paint. I have NOT done the coding yet, but the leds are not flickering, are they going to get brighter when its coded and it sends 12V? I have the T-effect which will be gone with coding. When i reverse one reverse light and one fog light turn on. Im getting the coding work done at the dealer for $198.00 dollars. are there any other codes that i can have them do that can affect the engine positively?
thanks for this MARVELOUS post!
- grayboots
Just as an idea of what can be coded here is the LSZ list from my car:
Generated with NCS Dummy version 0.6.0.1 — copyright © 2013 revtor
Output : Module Functions
Chassis : E85 (E85,E86)
Module : LSZ.C37
FUNCTION KEYWORD FUNCTION KEYWORD TRANSLATION
PARAMETER KEYWORD PARAMETER KEYWORD TRANSLATION
PWM_ANSTEUERUNG_BL_MITTE PULSE-WIDTH MODULATION (PWM) CONTROL OF THIRD BRAKE LIGHT
wert_01 value 01
PWM_ANSTEUERUNG_SL_VO_RE PULSE-WIDTH MODULATION (PWM) CONTROL OF RIGHT FRONT STANDING LIGHT
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
PWM_ANSTEUERUNG_SL3_LI_HI PULSE-WIDTH MODULATION (PWM) CONTROL OF LEFT REAR STANDING LIGHT 3
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
PWM_ANSTEUERUNG_BL PULSE-WIDTH MODULATION (PWM) CONTROL OF BRAKE LIGHTS
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
PWM_ANSTEUERUNG_BLK_VORN PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT TURN SIGNALS
wert_01 value 01
wert_02 value 02
PWM_ANSTEUERUNG_NSL_LI PULSE-WIDTH MODULATION (PWM) CONTROL OF LEFT REAR FOG LIGHT
wert_01 value 01
PWM_ANSTEUERUNG_SL3_RE_HI PULSE-WIDTH MODULATION (PWM) CONTROL OF RIGHT REAR STANDING LIGHT 3
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
PWM_ANSTEUERUNG_FERNLICHT PULSE-WIDTH MODULATION (PWM) CONTROL OF HIGH BEAMS
wert_01 value 01
wert_02 value 02
wert_03 value 03
PWM_ANSTEUERUNG_SL_VO_LI PULSE-WIDTH MODULATION (PWM) CONTROL OF LEFT FRONT STANDING LIGHT
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
PWM_ANSTEUERUNG_AL PULSE-WIDTH MODULATION (PWM) CONTROL OF LOW BEAMS
wert_01 value 01
wert_02 value 02
wert_03 value 03
PWM_ANSTEUERUNG_SL_LI_HI PULSE-WIDTH MODULATION (PWM) CONTROL OF LEFT REAR STANDING LIGHT
wert_01 value 01
wert_02 value 02
wert_03 value 03
PWM_ANSTEUERUNG_SL2_RE_HI PULSE-WIDTH MODULATION (PWM) CONTROL OF RIGHT REAR STANDING LIGHT 2
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
PWM_ANSTEUERUNG_KZL PULSE-WIDTH MODULATION (PWM) CONTROL OF LICENSE PLATE LIGHTS
wert_01 value 01
wert_02 value 02
wert_03 value 03
PWM_ANSTEUERUNG_SL_RE_HI PULSE-WIDTH MODULATION (PWM) CONTROL OF RIGHT REAR STANDING LIGHT
wert_01 value 01
wert_02 value 02
wert_03 value 03
PWM_ANSTEUERUNG_BLK_HI PULSE-WIDTH MODULATION (PWM) CONTROL OF REAR TURN SIGNALS
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
PWM_ANSTEUERUNG_ZUSTZBLK PULSE-WIDTH MODULATION (PWM) CONTROL OF AUXILIARY TURN SIGNALS
wert_01 value 01
wert_02 value 02
PWM_ANSTEUERUNG_BIXENON PULSE-WIDTH MODULATION (PWM) CONTROL OF BI-XENON LIGHTS
wert_01 value 01
PWM_ANSTEUERUNG_NSW PULSE-WIDTH MODULATION (PWM) CONTROL OF FRONT FOG LIGHTS
wert_01 value 01
SPG_NACHREGELUNG_0
wert_01 value 01
SPG_NACHREGELUNG_1
wert_01 value 01
SPG_NACHREGELUNG_2
wert_01 value 01
SPG_NACHREGELUNG_3
wert_01 value 01
LOAD_DUMP_U_GR
wert_01 value 01
LOAD_DUMP_TIME_OUT LOAD DUMP PROTECTION TIMEOUT
wert_01 value 01
LOAD_DUMP_PWM_BLK
wert_01 value 01
LOAD_DUMP_EINVER
wert_01 value 01
VARIANTE_LSZ LIGHT SWITCH (LSZ) VARIANT
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
LAENDERVARIANTE_LSZ COUNTRY VARIANT LIGHT SWITCH (LSZ)
wert_01 value 01
wert_02 value 02
LENKSEITE_LSZ LIGHT SWITCH (LSZ) DIRECTION
wert_01 value 01
wert_02 value 02
KALTUEBERWACHUNG_BL_MI COLD MONITORING OF THIRD BRAKE LIGHT
nicht_aktiv not enabled
aktiv enabled
KALTUEBERWACHUNG_SL_RE COLD MONITORING OF RIGHT STANDING LIGHTS
aktiv enabled
KALTUEBERWACHUNG_RL_3_LI COLD MONITORING OF LEFT TAIL LIGHT 3
aktiv enabled
KALTUEBERWACHUNG_BL COLD MONITORING OF BRAKE LIGHTS
aktiv enabled
KALTUEBERWACHUNG_BLK_VO COLD MONITORING OF FRONT TURN SIGNALS
aktiv enabled
KALTUEBERWACHUNG_NSL_LI COLD MONITORING OF LEFT REAR FOG LIGHT
aktiv enabled
KALTUEBERWACHUNG_RL_3_RE COLD MONITORING OF RIGHT TAIL LIGHT 3
aktiv enabled
KALTUEBERWACHUNG_FL COLD MONITORING OF HIGH BEAMS
aktiv enabled
KALTUEBERWACHUNG_SL_LI COLD MONITORING OF LEFT STANDING LIGHTS
aktiv enabled
KALTUEBERWACHUNG_AL COLD MONITORING OF LOW BEAMS
aktiv enabled
KALTUEBERWACHUNG_RL_LI COLD MONITORING OF LEFT TAIL LIGHT
aktiv enabled
KALTUEBERWACHUNG_RL_2_RE COLD MONITORING OF RIGHT INNER TAIL LIGHT
aktiv enabled
KALTUEBERWACHUNG_KZL_LI COLD MONITORING OF LEFT LICENSE PLATE LIGHT
aktiv enabled
KALTUEBERWACHUNG_RL_RE COLD MONITORING OF RIGHT TAIL LIGHT
aktiv enabled
KALTUEBERWACHUNG_BLK_HI COLD MONITORING OF REAR TURN SIGNALS
aktiv enabled
KALTUEBERWACH_ZUSATZ_BLK COLD MONITORING OF EXTERNAL TURN SIGNALS
aktiv enabled
KL_50_FUNK_AKT
aktiv enabled
LOAD_DUMP
aktiv enabled
AL_KL_50 LOW BEAMS ENABLED WHEN STARTING ENGINE
aktiv enabled
FL_KL_50 HIGH BEAMS ENABLED WHEN STARTING ENGINE
aktiv enabled
NSW_KL_50 FRONT FOG LIGHTS ENABLED WHEN STARTING ENGINE
aktiv enabled
LOAD_DUMP_AUSVER
wert_01 value 01
WARMUEBERWACHUNG_BL_MI HOT MONITORING OF THIRD BRAKE LIGHT
aktiv enabled
WARMUEBERWACHUNG_SL_RE HOT MONITORING OF RIGHT STANDING LIGHTS
aktiv enabled
WARMUEBERWACHUNG_RL_3_LI HOT MONITORING OF LEFT TAIL LIGHT 3
aktiv enabled
WARMUEBERWACHUNG_BL HOT MONITORING OF BRAKE LIGHTS
aktiv enabled
WARMUEBERWACHUNG_BLK_VO HOT MONITORING OF FRONT TURN SIGNALS
aktiv enabled
WARMUEBERWACHUNG_NSL_LI HOT MONITORING OF LEFT REAR FOG LIGHT
aktiv enabled
WARMUEBERWACHUNG_RL_3_RE HOT MONITORING OF RIGHT TAIL LIGHT 3
aktiv enabled
WARMUEBERWACHUNG_FL HOT MONITORING OF HIGH BEAMS
aktiv enabled
WARMUEBERWACHUNG_SL_LI HOT MONITORING OF LEFT STANDING LIGHTS
aktiv enabled
WARMUEBERWACHUNG_AL HOT MONITORING OF LOW BEAMS
aktiv enabled
WARMUEBERWACHUNG_RL_LI HOT MONITORING OF LEFT TAIL LIGHT
aktiv enabled
WARMUEBERWACHUNG_RL_2_RE HOT MONITORING OF RIGHT INNER TAIL LIGHT
aktiv enabled
WARMUEBERWACHUNG_KZL_LI HOT MONITORING OF LEFT LICENSE PLATE LIGHT
aktiv enabled
WARMUEBERWACHUNG_RL_RE HOT MONITORING OF RIGHT TAIL LIGHT
aktiv enabled
WARMUEBERWACHUNG_BLK_HI HOT MONITORING OF REAR TURN SIGNALS
aktiv enabled
WARMUEBERWACH_ZUSATZ_BLK HOT MONITORING OF AUXILIARY TURN SIGNALS
aktiv enabled
LOAD_DUMP_KL58G
aktiv enabled
LOAD_DUMP_P5_10
aktiv enabled
LOAD_DUMP_P30_29
aktiv enabled
LOAD_DUMP_P44_45
aktiv enabled
LOAD_DUMP_P20
aktiv enabled
LOAD_DUMP_P37
aktiv enabled
LOAD_DUMP_P38
aktiv enabled
LOAD_DUMP_P49
aktiv enabled
CC_BREMSLICHT_MITTE CHECK CONTROL NOTIFICATION FOR THIRD BRAKE LIGHT
aktiv enabled
CC_STANDLICHT_RECHTS CHECK CONTROL NOTIFICATION FOR RIGHT STANDING LIGHTS
aktiv enabled
CC_RUECKLICHT_3_LINKS CHECK CONTROL NOTIFICATION FOR LEFT TAIL LIGHT 3
aktiv enabled
CC_BREMSLICHT CHECK CONTROL NOTIFICATION FOR BRAKE LIGHTS
aktiv enabled
CC_BLINKER_VORN CHECK CONTROL NOTIFICATION FOR FRONT TURN SIGNALS
aktiv enabled
CC_NSL_LINKS CHECK CONTROL NOTIFICATION FOR LEFT REAR FOG LIGHT
aktiv enabled
CC_RUECKLICHT_3_RECHTS CHECK CONTROL NOTIFICATION FOR RIGHT TAIL LIGHT 3
aktiv enabled
CC_FERNLICHT CHECK CONTROL NOTIFICATION FOR HIGH BEAMS
aktiv enabled
CC_STANDLICHT_LINKS CHECK CONTROL NOTIFICATION FOR LEFT STANDING LIGHTS
aktiv enabled
CC_ABBLENDLICHT CHECK CONTROL NOTIFICATION FOR LOW BEAMS
aktiv enabled
CC_RUECKLICHT_LINKS CHECK CONTROL NOTIFICATION FOR LEFT TAIL LIGHT
aktiv enabled
CC_RUECKLICHT_2_RECHTS CHECK CONTROL NOTIFICATION FOR RIGHT INNER TAIL LIGHT
aktiv enabled
CC_KENNZEICHENLEUCHTE_LI CHECK CONTROL NOTIFICATION FOR LEFT LICENSE PLATE LIGHT
aktiv enabled
CC_RUECKLICHT_RECHTS CHECK CONTROL NOTIFICATION FOR RIGHT TAIL LIGHT
aktiv enabled
CC_BLINKER_HINTEN CHECK CONTROL NOTIFICATION FOR REAR TURN SIGNALS
aktiv enabled
CC_ZUSATZBLINKER CHECK CONTROL NOTIFICATION FOR AUXILIARY TURN SIGNALS
aktiv enabled
FEHLER_BL_BLINKEN BRAKE LIGHT FAULT FLASHES
nicht_melden not reported
melden reported
FEHLER_NSL_RECHTS RIGHT REAR FOG LIGHT FAULT
melden reported
BLK_H_R_PICT RIGHT REAR TURN SIGNAL IN INSTRUMENT CLUSTER
aktiv enabled
BLK_H_L_PICT LEFT REAR TURN SIGNAL IN INSTRUMENT CLUSTER
aktiv enabled
BLK_V_R_PICT RIGHT FRONT TURN SIGNAL IN INSTRUMENT CLUSTER
aktiv enabled
BLK_V_L_PICT LEFT FRONT TURN SIGNAL IN INSTRUMENT CLUSTER
aktiv enabled
FEHLER_SCHALTER_BREMSL CHECK CONTROL NOTIFICATION FOR BRAKE LIGHT SWITCH FAULT
melden reported
FEHLER_ANHAENGER CHECK CONTROL NOTIFICATION FOR TRAILER FAULT
melden reported
ENTPRELLZAHL_FEHLERERK FAULT RECOGNITION DEBOUNCING (NUMBER OF SUCCESSIVE FAULTS NEEDED TO REPORT A FAULT)
wert_01 value 01
ANZAHL_QUICK_RUNDEN NUMBER OF QUICK COLD MONITORING CHECKS WHEN SWITCHING ON IGNITION
wert_01 value 01
ZEIT_KALT_RUNDEN TIME BETWEEN COLD MONITORING ROUNDS [TIME_S=DATA*2.5]
wert_01 value 01
ZEIT_KALT_PULSE TIME BETWEEN COLD MONITORING PULSES [TIME_MS=DATA*10]
wert_01 value 01
ZEIT_KALT_PULSE_QUICK TIME BETWEEN QUICK COLD MONITORING PULSES [TIME_MS=DATA*10]
wert_01 value 01
ZYKLUS_KALT_RUNDEN_QUICK TIME BETWEEN QUICK COLD MONITORING ROUNDS [TIME_MS=DATA*10]
wert_01 value 01
BLS_PRUEFEN BRAKE LIGHT SWITCH CHECK
aktiv enabled
SCHALTER_BREMSL_SCHWELLW BRAKE LIGHT SWITCH THRESHOLD
wert_01 value 01
SCHALTER_BREMSL_WARTEZEIT WAITING TIME FOR BRAKE LIGHT SWITCH FAULTS
wert_01 value 01
DAUERFAHRLICHT_US DAYTIME RUNNING LIGHTS (USA)
aktiv enabled
DEF_PIN_20_DEFEKTBLINKEN
aktiv enabled
DEF_PIN_37_DEFEKTBLINKEN
aktiv enabled
DEF_PIN_5_10_DEFEKTBLK
aktiv enabled
PIN_38_RE_LI_MELDEN
links_defekt left defect
rechts_defekt right defect
PIN_38_VO_HI_MELDEN
hinten_defekt rear defect
vorne_defekt front defect
DEF_PIN_29_30_DEFEKT_BL
aktiv enabled
DEF_PIN_5_10_DEFEKT_SL
aktiv enabled
DEF_PIN_29_30_DEFEKT_SL
aktiv enabled
DEF_PIN_37_VOR
aktiv enabled
DEF_PIN_20_VOR
aktiv enabled
NACHREG_DYN_SLOW
aktiv enabled
FO_ME_HOME_SL2
aktiv enabled
PIN37_49_PARKL PARKING LIGHTS WITH INNER TAIL LIGHTS / LEFT REAR FOG LIGHT (DEPENDS ON CHASSIS)
aktiv enabled
BFD_SW1_STUFE3 BRAKE FORCE DISPLAY STAGE 3 ACTIVATED BY DECELERATION SENSOR 1
aktiv enabled
ST3_SCHWEL
aktiv enabled
BLST1_BLST3 AKTIV: INNER AND OUTER BRAKE LIGHTS]
aktiv enabled
BFD_SW1_STUFE2 BRAKE FORCE DISPLAY STAGE 2 ACTIVATED BY DECELERATION SENSOR 1
aktiv enabled
BFD_MINDEST_GESCHW BRAKE FORCE DISPLAY MINIMUM SPEED
wert_01 value 01
wert_02 value 02
BFD_STUFE_2_VERZOEG BRAKE FORCE DISPLAY STAGE 2 DELAY
wert_01 value 01
wert_02 value 02
BFD_STUFE_2_MAX_EIN
wert_01 value 01
wert_02 value 02
PIN29_30_BFD BRAKE FORCE DISPLAY WITH INNER TAIL LIGHTS / REAR FOG LIGHTS (DEPENDS ON CHASSIS)
aktiv enabled
PIN49_37_BFD BRAKE FORCE DISPLAY WITH INNER TAIL LIGHTS / LEFT REAR FOG LIGHT (DEPENDS ON CHASSIS)
aktiv enabled
PIN38_20_BFD BRAKE FORCE DISPLAY WITH OUTER TAIL LIGHTS (DEPENDS ON CHASSIS)
aktiv enabled
PIN5_10_BFD BRAKE FORCE DISPLAY WITH BRAKE LIGHTS
aktiv enabled
BFD_BLINK_EINZEIT BRAKE FORCE DISPLAY FLASH OFF PERIOD
wert_01 value 01
wert_02 value 02
BFD_BLINK_AUSZEIT BRAKE FORCE DISPLAY FLASH ON PERIOD
wert_01 value 01
wert_02 value 02
BEI_NSL_KEIN_BFD BRAKE FORCE DISPLAY NOT SIMULTANEOUSLY WITH REAR FOG LIGHTS
aktiv enabled
BFD3_ASC_TIMER
wert_01 value 01
wert_02 value 02
BFD_SW2_STUFE2 BRAKE FORCE DISPLAY STAGE 2 ACTIVATED BY DECELERATION SENSOR 2
aktiv enabled
BFD_SW2_STUFE3 BRAKE FORCE DISPLAY STAGE 3 ACTIVATED BY DECELERATION SENSOR 2
aktiv enabled
BFD_ABS_STUFE2 BRAKE FORCE DISPLAY STAGE 2 ACTIVATED BY ANTILOCK BRAKING SYSTEM (ABS)
aktiv enabled
BFD_ABS_STUFE3 BRAKE FORCE DISPLAY STAGE 3 ACTIVATED BY ANTILOCK BRAKING SYSTEM (ABS)
aktiv enabled
BFD_STUFE2_TIMER BRAKE FORCE DISPLAY STAGE 2 TIMER
wert_01 value 01
wert_02 value 02
BFD_STUFE3_TIMER BRAKE FORCE DISPLAY STAGE 3 TIMER
wert_01 value 01
wert_02 value 02
FLC_LED_AKTIV AUTOMATIC LIGHT CONTROL (FLC) LED ENABLED
aktiv enabled
ALC_DEF_AKTIV
aktiv enabled
PIN49_BFD BRAKE FORCE DISPLAY WITH LEFT INNER TAIL LIGHT / LEFT REAR FOG LIGHT (DEPENDS ON CHASSIS)
aktiv enabled
PIN38_BFD BRAKE FORCE DISPLAY WITH RIGHT OUTER TAIL LIGHT (DEPENDS ON CHASSIS)
aktiv enabled
ALC_BLK_PER
wert_01 value 01
wert_02 value 02
INTERM_FL INTERMITTENT HIGH BEAMS
wert_01 value 01
wert_02 value 02
AH_US_OPTION
aktiv enabled
PIN38_20_PARK PARKING LIGHTS WITH OUTER TAIL LIGHTS (DEPENDS ON CHASSIS)
aktiv enabled
PIN29_30_PARK PARKING LIGHTS WITH INNER TAIL LIGHTS / REAR FOG LIGHTS (DEPENDS ON CHASSIS)
aktiv enabled
HEIMLEUCHTEN_SL3_H FOLLOW-ME-HOME LIGHTS WITH REAR STANDING LIGHTS
aktiv enabled
PIN29_30_BL_NSL
aktiv enabled
FL_AL_AUS LOW BEAMS NOT SIMULTANEOUSLY WITH HIGH BEAMS
aktiv enabled
ANHAENGERMODUL_PWM_WERT TRAILER MODULE PULSE-WIDTH MODULATION (PWM) VALUE
wert_01 value 01
wert_02 value 02
BL_ERSETZ_DEFEKT_SL BRAKE LIGHT REPLACES DEFECTIVE STANDING LIGHT
aktiv enabled
PIN_29_30_AHM_ERS_FU_GESP
aktiv enabled
PIN_5_10_AHM_ERS_FU_GESP
aktiv enabled
XENON_TEST XENON LIGHTS TEST
aktiv enabled
XENON_TIMEOUT XENON LIGHTS TIMEOUT
wert_01 value 01
XENON_TIME XENON LIGHTS TIME
wert_01 value 01
KL58_HELLIGKEITSSTUFE
wert_01 value 01
U_POTI_DIMMER_MIN INSTRUMENT LIGHTS DIMMER POTENTIOMETER MINIMUM VOLTAGE [VOLTAGE_V=(DATA*5)/255]
wert_01 value 01
U_POTI_DIMMER_DELTA INSTRUMENT LIGHTS DIMMER POTENTIOMETER VOLTAGE SPAN BETWEEN MINIMUM AND MAXIMUM [VOLTAGE_V=(DATA*5)/255]
wert_01 value 01
MELDUNG_AENDERUNG_DIMMER INSTRUMENT LIGHTS DIMMER CHANGE BEFORE K-BUS MESSAGE GENERATED [ANGLE_°=(DATA*120)/255]
wert_01 value 01
POTI_DIMMER_INVERS INVERTED POTENTIOMETER FOR INSTRUMENT LIGHTS DIMMER
aktiv enabled
POTI_LWR_INVERS INVERTED POTENTIOMETER FOR VERTICAL HEADLIGHT AIM CONTROL (LWR)
aktiv enabled
LEUCHTDICHTE_EXPO EXPONENTIAL LUMINANCE CHANGE FOR INSTRUMENT LIGHTS
aktiv enabled
TELEGRAMM_ZEIT_ZYKLUS MESSAGE TIME CYCLE
aktiv enabled
TAGFAHRLICHT_ECE DAYTIME RUNNING LIGHTS (EUROPE)
aktiv enabled
FL_UND_NSW_NICHT_GLEICHZ FRONT FOG LIGHTS NOT SIMULTANEOUSLY WITH HIGH BEAMS
aktiv enabled
BI_XENON BI-XENON LIGHTS
aktiv enabled
SL_VO_ANSTEUERUNG FRONT STANDING LIGHTS CONTROL
aktiv enabled
SIDEMARKER_US USA SIDE MARKER LIGHTS
aktiv enabled
NSL_ALS_STANDLICHT REAR FOG LIGHTS AS STANDING LIGHTS
aktiv enabled
PIN_20_ALS_SL_LI_3_ANSTEU
aktiv enabled
PIN_20_ALS_FRA_LI_VO_2
aktiv enabled
PIN_37_ALS_SL_RE_2
aktiv enabled
PIN_37_ALS_FRA_RE_VO_2
aktiv enabled
PIN_38_ALS_SL_RE_3
aktiv enabled
BREMSLICHT_ALS_STANDLICHT BRAKE LIGHT AS STANDING LIGHT
aktiv enabled
STANDLICHT_ALS_NSL_LINKS REAR LEFT STANDING LIGHT AS LEFT REAR FOG LIGHT
aktiv enabled
STANDLICHT_ALS_BREMSLICHT REAR STANDING LIGHTS AS BRAKE LIGHTS
aktiv enabled
DRL_BLK_VORN_GEDIMMT DIMMED FRONT TURN SIGNALS AS DAYTIME RUNNING LIGHTS
aktiv enabled
GED_FL_ALS_DRL DIMMED HIGH BEAMS AS DAYTIME RUNNING LIGHTS
aktiv enabled
BLINKIMPULS_WARNBLK HAZARD LIGHTS FLASHING [DATA=1: NORMAL, DATA=2: NORMAL, DATA=3: FAST, DATA=4: DOUBLE IMPULSE]
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
BLINKIMPULS_CRASHBLK CRASH LIGHTS FLASHING [DATA=1: NORMAL, DATA=2: NORMAL, DATA=3: FAST, DATA=4: DOUBLE IMPULSE]
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
DRL_BLK_VORNE_2_GEDIMMT
aktiv enabled
STANDLICHT_ALS_NSL_RECHTS RIGHT REAR STANDING LIGHT AS RIGHT REAR FOG LIGHT
aktiv enabled
BEGRENZUNGSLICHT_IN_PARK POSITION LIGHTS IN PARK POSITION
aktiv enabled
CRASH_WARNBLINKEN SWITCH ON HAZARD LIGHTS AFTER CRASH
aktiv enabled
TAXI_ENABLE TAXI MODE ENABLED
aktiv enabled
BETR_STD_NICHT_LOESCHEN NO CLEARING OF OPERATING HOURS
aktiv enabled
SCHALTER2_BL HILL DESCENT CONTROL (HDC) OPERATES BRAKE LIGHTS WHEN ACTIVATED
aktiv enabled
CRASH_KLEMME_58G_EIN INSTRUMENT LIGHTS SWITCH ON AFTER CRASH
aktiv enabled
DRL_DIMMUNG DAYTIME RUNNING LIGHTS DIMMING
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
TASTVERH_KL_58G_MIN MINIMUM BRIGHTNESS PULSE DUTY FACTOR FOR INSTRUMENT LIGHTS (BASE WIDTH)
wert_01 value 01
ZUWACHS_TASTVERH_KL_58G MAXIMUM BRIGHTNESS PULSE DUTY FACTOR FOR INSTRUMENT LIGHTS (ADDED TO BASE WIDTH)
wert_01 value 01
TAST_WBLKTASTER_MIN
wert_01 value 01
wert_02 value 02
TAST_WBLKTASTER_ZUWACHS
wert_01 value 01
wert_02 value 02
HEIMLEUCHTEN FOLLOW-ME-HOME LIGHTS (ACTIVATED BY FLASHING HIGH BEAMS WITH IGNITION OFF) [WERT_01: OFF] [TIME_S=DATA]
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
HEIMLEUCHTEN_AL FOLLOW-ME-HOME LIGHTS WITH LOW BEAMS
aktiv enabled
HEIMLEUCHTEN_SL_H FOLLOW-ME-HOME LIGHTS WITH REAR STANDING LIGHTS
aktiv enabled
HEIMLEUCHTEN_FL FOLLOW-ME-HOME LIGHTS WITH HIGH BEAMS
aktiv enabled
HEIMLEUCHTEN_KL58G FOLLOW-ME-HOME LIGHTS WITH INSTRUMENT LIGHTS
aktiv enabled
HEIMLEUCHTEN_SL_V FOLLOW-ME-HOME LIGHTS WITH FRONT STANDING LIGHTS
aktiv enabled
HEIMLEUCHTEN_NSW FOLLOW-ME-HOME LIGHTS WITH FRONT FOG LIGHTS
aktiv enabled
HEIMLEUCHTEN_KZL FOLLOW-ME-HOME LIGHTS WITH LICENSE PLATE LIGHTS
aktiv enabled
HEIMLEUCHTEN_BL FOLLOW-ME-HOME LIGHTS WITH TURN SIGNALS
aktiv enabled
ADU_UNTERGRENZE
wert_01 value 01
wert_02 value 02
ADU_OBERGRENZE
wert_01 value 01
wert_02 value 02
ABSCHALTUNG_UNTERSPG UNDERVOLTAGE SWITCH-OFF THRESHOLD FOR STANDING LIGHTS [VOLTAGE_V=0.7+(DATA*18)/255 : DATA=0=132]
wert_01 value 01
ABFRAGEZEIT_AHM QUERYING TIME OF TRAILER MODULE IN LOW POWER MODE [TIME_MS=DATA*30]
wert_01 value 01
wert_02 value 02
KL58_HELLIGKEITSSTUFE_FLC
wert_01 value 01
STEIG_KL58_T_PER_D
wert_01 value 01
BLK_DIMMEN DIMMED TURN SIGNALS
aktiv enabled
SL_X_3_ERSETZT_DEFEKT_BL
aktiv enabled
SL_ERSETZT_DEFEKT_BL STANDING LIGHT REPLACES DEFECTIVE BRAKE LIGHT
aktiv enabled
RECHTS_LINKS RIGHT/LEFT
aktiv enabled
NSL_ERSETZT_DEFEKT_BL REAR FOG LIGHT REPLACES DEFECTIVE BRAKE LIGHT
aktiv enabled
SL_ERSETZT_DEFEKT_BLK STANDING LIGHT REPLACES DEFECTIVE TURN SIGNAL
aktiv enabled
SL_3_ERSETZT_DEFEKT_BLK STANDING LIGHT 3 REPLACES DEFECTIVE TURN SIGNAL
aktiv enabled
BL_ERSETZT_DEFEKT_BLK BRAKE LIGHT REPLACES DEFECTIVE TURN SIGNAL
aktiv enabled
BIXENON_EIN_BEI_LICHTHUPE BI-XENON LIGHTS ON FOR FLASH-TO-PASS
aktiv enabled
PIN_20_ALS_SIDEMARKER OUTPUT PIN 20 AS USA SIDEMARKER LIGHTS
aktiv enabled
PIN_20_ALS_NSL OUTPUT PIN 20 AS REAR FOG LIGHTS
aktiv enabled
GEDIMMT_BLK_BEGRENZ_LICHT DIMMED TURN SIGNALS AS POSITION LIGHTS
aktiv enabled
GEDIMMT_BL__BEGRENZ_LICHT DIMMED BRAKE LIGHTS AS USA SIDE MARKER LIGHTS
aktiv enabled
PHASE_AUS_GEDIM_LICHT_AUS
aktiv enabled
SPG_NACHREGELUNG_LANGSAM
aktiv enabled
P_10_5_ALS_BL_FUNKTION
aktiv enabled
PWM_WERT2_ALS_BL_AUSGANG
wert_01 value 01
wert_02 value 02
PWM_WERT2_ALS_SL_AUSGANG
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
PWM_WERT2_NSL_ZUSATZFKT
wert_01 value 01
PWM_WERT2_BLK_ZUSATZFKT
wert_01 value 01
wert_02 value 02
wert_03 value 03
PWM_WERT2_FL_BIXENON
wert_01 value 01
wert_02 value 02
wert_03 value 03
PWM_WERT2_SL3_ZUSATZFKT
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
LEUCHTWEITENREGELUNG MANUAL VERTICAL HEADLIGHT AIM CONTROL (LWR)
aktiv enabled
HALB/VOLLSCHRITT HALF/FULL STEP
halbschritt half step
vollschritt full step
TEST_OD_ST2_OHNE_NSW
aktiv enabled
SP_MOTOR_STOP
aktiv enabled
SP_F_EINTR_OD_ALC_NSW_PIC
aktiv enabled
TR_F_EINTR_OD_ALC_AL_FPIC
aktiv enabled
SP_BEWERT_OD_ALC_NSW_AUS
aktiv enabled
TREIBER_STOP_OD_ALC_RE_OK
aktiv enabled
U_POTI_0_OD_FAILSAFE_ON
wert_01 value 01
wert_02 value 02
U_POTI_1_OD_DAEMMERSTUFE
wert_01 value 01
wert_02 value 02
U_POTI_2_OD_ALC_PARA_01
wert_01 value 01
wert_02 value 02
SCHRITTE_0_OD_ALC_AKTIV_0
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
SCHRITTE_1_OD_ALC_AKTIV_1
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
wert_10 value 10
SCHRITTE_2_OD_ALC_AKTIV_2
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
wert_10 value 10
wert_11 value 11
wert_12 value 12
ABS_MIN_2_OD_ALC_AKTIV_3
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
wert_10 value 10
wert_11 value 11
wert_12 value 12
SCHRITT_GRENZE_OD_ALC_IO
wert_01 value 01
wert_02 value 02
TEMP_GRENZE_OD_ALC_NIO
wert_01 value 01
wert_02 value 02
HYSTERESE_OD_AL_XENON_IO
wert_01 value 01
wert_02 value 02
wert_03 value 03
T_STROM_OD_ALC_PARA_02
wert_01 value 01
wert_02 value 02
wert_03 value 03
REF_LAUF_ZAHL_OD_ALC_1
wert_01 value 01
wert_02 value 02
REF_LAUF_STEP_OD_ALC_2
wert_01 value 01
wert_02 value 02
REF_LAUF_T2_OD_ALC_3
wert_01 value 01
wert_02 value 02
REF_LAUF_T1_OD_ALC_4
wert_01 value 01
wert_02 value 02
SCHRITTABSTAND_STARTPHASE START PHASE STEP DISTANCE
kennlinie_01 characteristic curve 01
kennlinie_02 characteristic curve 02
M_TELEGRAM_OD_ALC_5
aktiv enabled
LWR_INVERS_OD_ALC_6
wert_01 value 01
wert_02 value 02
S_MOTORWEG_OD_ALC_7
wert_01 value 01
wert_02 value 02
TEMP_RAMPE_OD_ALC_8
aktiv enabled
LWR_VORZEICHEN
aktiv enabled
vorn_aktiv front enabled
LEUCHTWEITENREG_AUTOM AUTOMATIC VERTICAL HEADLIGHT AIM CONTROL (LWR)
aktiv enabled
LEUCHTWEITENREG_DYNAM DYNAMIC VERTICAL HEADLIGHT AIM CONTROL (LWR)
aktiv enabled
AUSWERT_PROP_ABWEICHUNG
aktiv enabled
AUSWERT_GRADIENT
aktiv enabled
KENNLINIE_LWR_SENSOR_VO FRONT HEIGHT SENSOR CHARACTERISTIC CURVE FOR AUTOMATIC VERTICAL HEADLIGHT AIM CONTROL (LWR)
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
KENNLINIE_LWR_SENSOR_HI REAR HEIGHT SENSOR CHARACTERISTIC CURVE FOR AUTOMATIC VERTICAL HEADLIGHT AIM CONTROL (LWR)
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
DEF_LWR_SENSOR_HI DEFAULT VERTICAL HEADLIGHT AIM CONTROL (LWR) REAR HEIGHT SENSOR
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
LWR_NEIGUNG_KONSTANTE AUTOMATIC VERTICAL HEADLIGHT AIM CONTROL (LWR) INCLINATION CONSTANT
wert_01 value 01
wert_02 value 02
wert_03 value 03
OFFSET_LWR OFFSET VERTICAL HEADLIGHT AIM CONTROL (LWR)
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
EPSILON_DELTA_AV
wert_01 value 01
wert_02 value 02
wert_03 value 03
EPSILON_DELTA_A
wert_01 value 01
wert_02 value 02
wert_03 value 03
ANHEBUNG_175_KM/H
wert_01 value 01
wert_02 value 02
wert_03 value 03
ABSENKUNG_10_KM/H
wert_01 value 01
wert_02 value 02
VMAX_BESCHLEUNIGUNG MAXIMUM SPEED ACCELERATING
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
VMIN_BESCHLEUNIGUNG MINIMUM SPEED ACCELERATING
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
VMAX_BREMSEN MAXIMUM SPEED BRAKING
wert_01 value 01
VMIN_BREMSEN MINIMUM SPEED BRAKING
wert_01 value 01
SCHW_GRAD_BESCHLEUNIGUNG
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
SCHW_GRAD_BREMSEN
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
SCHW_PROP_ABWEICHUNG
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
DIFFERENZ_MSP_DYN_STAT
wert_01 value 01
DAUER_DYN_NACHFUEHRUNG
wert_01 value 01
ABTASTRATE_DYN DYNAMIC SAMPLING FREQUENCY
wert_01 value 01
MITTELUNGSINTERV_DYN
wert_01 value 01
wert_02 value 02
MIN_STEIGUNG_VZ_WECHSEL
wert_01 value 01
MITTELUNGSINTERV_VZ_WECHS
wert_01 value 01
MINDESTANZAHL_VZ_WECHSEL
wert_01 value 01
HOEHENWEG
wert_01 value 01
ABTASTRATE_TREND SAMPLING FREQUENCY TREND
wert_01 value 01
MITTELUNGSINTERV_TREND
wert_01 value 01
SCHW_TREND
wert_01 value 01
ABWEICHUNG_TREND DIVERGENCE TREND
wert_01 value 01
GRADIENT_SCHLECHTWEG
aktiv enabled
NACHLAUF_SCHLECHTWEG
wert_01 value 01
SAETT_TIMER_SCHLECHTWEG
aktiv enabled
SCHW_GRADIENT_SCHLECHTWEG
wert_01 value 01
LH_MIT_BIX
aktiv enabled
FL_ALS_SL_LR
aktiv enabled
FL_DRL_MIT_RL
aktiv enabled
PO_ALS_DRL POSITION LIGHTS AS DAYTIME RUNNING LIGHTS
aktiv enabled
PIN_20_37_ALS_PO
aktiv enabled
HEIMLEUCHTEN_BLK FOLLOW-ME-HOME LIGHTS WITH TURN SIGNALS
aktiv enabled
CYCL_TI_BLK ONE-TOUCH TURN SIGNAL FUNCTIONALITY [BLINKCOUNT=DATA]
einmal once
dreimal triple
PIN20_PWM_BLK
wert_01 value 01
wert_02 value 02
PIN37_PWM_BLK
wert_01 value 01
wert_02 value 02
PIN49_PWM_BFD
wert_01 value 01
wert_02 value 02
LAENGE_LWR_REF
wert_01 value 01
wert_02 value 02
LAENGE_LWR_STELL
wert_01 value 01
wert_02 value 02
LWR_DIAG_PARAM VERTICAL HEADLIGHT AIM CONTROL (LWR) DIAGNOSTIC PARAMETERS
wert_01 value 01
SL_AUS_BEI_FA_TUER_AUF STANDING LIGHTS SWITCH OFF WHEN OPENING DRIVER DOOR
aktiv enabled
PROGRAMMPARAMETER_LCM_1 PROGRAM PARAMETERS LIGHT CONTROL MODULE (LCM) 1
wert_01 value 01
Module : LSZ.C37
wert_01 value 01
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_01 value 01
SPG_NACHREGELUNG_0
wert_01 value 01
SPG_NACHREGELUNG_1
wert_01 value 01
SPG_NACHREGELUNG_2
wert_01 value 01
SPG_NACHREGELUNG_3
wert_01 value 01
LOAD_DUMP_U_GR
wert_01 value 01
wert_01 value 01
LOAD_DUMP_PWM_BLK
wert_01 value 01
LOAD_DUMP_EINVER
wert_01 value 01
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
KL_50_FUNK_AKT
aktiv enabled
LOAD_DUMP
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
LOAD_DUMP_AUSVER
wert_01 value 01
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
LOAD_DUMP_KL58G
aktiv enabled
LOAD_DUMP_P5_10
aktiv enabled
LOAD_DUMP_P30_29
aktiv enabled
LOAD_DUMP_P44_45
aktiv enabled
LOAD_DUMP_P20
aktiv enabled
LOAD_DUMP_P37
aktiv enabled
LOAD_DUMP_P38
aktiv enabled
LOAD_DUMP_P49
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
melden reported
melden reported
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
melden reported
melden reported
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_01 value 01
aktiv enabled
wert_01 value 01
wert_01 value 01
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
PIN_38_RE_LI_MELDEN
PIN_38_VO_HI_MELDEN
aktiv enabled
aktiv enabled
aktiv enabled
DEF_PIN_37_VOR
aktiv enabled
DEF_PIN_20_VOR
aktiv enabled
NACHREG_DYN_SLOW
aktiv enabled
FO_ME_HOME_SL2
aktiv enabled
aktiv enabled
aktiv enabled
ST3_SCHWEL
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
BFD_STUFE_2_MAX_EIN
wert_01 value 01
wert_02 value 02
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
aktiv enabled
BFD3_ASC_TIMER
wert_01 value 01
wert_02 value 02
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
aktiv enabled
ALC_DEF_AKTIV
aktiv enabled
aktiv enabled
aktiv enabled
ALC_BLK_PER
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
AH_US_OPTION
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
PIN29_30_BL_NSL
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_01 value 01
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
PIN_37_ALS_SL_RE_2
aktiv enabled
aktiv enabled
PIN_38_ALS_SL_RE_3
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_01 value 01
TAST_WBLKTASTER_MIN
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
ADU_UNTERGRENZE
wert_01 value 01
wert_02 value 02
ADU_OBERGRENZE
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_01 value 01
wert_02 value 02
wert_01 value 01
STEIG_KL58_T_PER_D
wert_01 value 01
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_01 value 01
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
aktiv enabled
aktiv enabled
SP_MOTOR_STOP
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
wert_10 value 10
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
wert_10 value 10
wert_11 value 11
wert_12 value 12
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
wert_09 value 09
wert_10 value 10
wert_11 value 11
wert_12 value 12
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
M_TELEGRAM_OD_ALC_5
aktiv enabled
LWR_INVERS_OD_ALC_6
wert_01 value 01
wert_02 value 02
S_MOTORWEG_OD_ALC_7
wert_01 value 01
wert_02 value 02
TEMP_RAMPE_OD_ALC_8
aktiv enabled
LWR_VORZEICHEN
aktiv enabled
aktiv enabled
aktiv enabled
aktiv enabled
AUSWERT_GRADIENT
aktiv enabled
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
wert_07 value 07
wert_08 value 08
EPSILON_DELTA_AV
wert_01 value 01
wert_02 value 02
wert_03 value 03
EPSILON_DELTA_A
wert_01 value 01
wert_02 value 02
wert_03 value 03
ANHEBUNG_175_KM/H
wert_01 value 01
wert_02 value 02
wert_03 value 03
ABSENKUNG_10_KM/H
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
SCHW_GRAD_BREMSEN
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_02 value 02
wert_03 value 03
wert_04 value 04
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_01 value 01
wert_02 value 02
wert_01 value 01
wert_01 value 01
wert_01 value 01
HOEHENWEG
wert_01 value 01
wert_01 value 01
wert_01 value 01
SCHW_TREND
wert_01 value 01
wert_01 value 01
aktiv enabled
wert_01 value 01
aktiv enabled
wert_01 value 01
LH_MIT_BIX
aktiv enabled
FL_ALS_SL_LR
aktiv enabled
FL_DRL_MIT_RL
aktiv enabled
aktiv enabled
PIN_20_37_ALS_PO
aktiv enabled
aktiv enabled
einmal once
dreimal triple
PIN20_PWM_BLK
wert_01 value 01
wert_02 value 02
PIN37_PWM_BLK
wert_01 value 01
wert_02 value 02
PIN49_PWM_BFD
wert_01 value 01
wert_02 value 02
LAENGE_LWR_REF
wert_01 value 01
wert_02 value 02
LAENGE_LWR_STELL
wert_01 value 01
wert_02 value 02
wert_01 value 01
aktiv enabled
wert_01 value 01
2011 Z4 E89 sDrive 23i M Sport Highline
do the frame surrounds for the NEW tail lights a bolt on install? or do they need to be shaped? cause on of the new frame surrounds had to be shaped (cut) to fit. did everyone have the same issue?
Hi Sebeast,
Welcome to the club. I saw a post you left over on Bimmerfest last December and I thought I'd come over here and see if you found us. Congratulations on the progress thus far. AND GET SOME PICTURES POSTED!!!
I didn't have to trim the surrounds. They went in without a hitch. 4 screws if I recall.
As for the coding of the light module, if you don't have NCS Expert, or aren't comfortable with the learning curve, call around to your local indie Bimmer shops and see if anyone has an Autologic tool or something similar. They all have some sort of "advanced" coding tool to do diagnostics. I paid $25.00.
These are the key changes to the LSZ. These won't clear the warning light on the dashboard, but they do ensure that everything is working correctly out back.
PWM_ANSTEUERUNG_SL_RE_HI = Change to 01 (Default 02)
PWM_ANSTEUERUNG_SL_LI_HI = Change to 01 (Default 02)
BREMSLICHT_ALS_STANDLICHT = Change to Not Active (Default Active)
- half
I don't know if I understand but the frame that can be removed with three screws which is the headlight frame consists of 2 pieces. You can separate easily without breaking anything. Outward parts should be removed.sebeast wrote:do the frame surrounds for the NEW tail lights a bolt on install? or do they need to be shaped? cause on of the new frame surrounds had to be shaped (cut) to fit. did everyone have the same issue?
I think I see the issue. Step 3 on the first page of this post. If you use the old frames you need to do some trimming. If you buy the new frames for the facelift lights it's plug and play. They were for me, I just had to paint to match.
These guys.......
51717167525 Frame, rear light, left
51717167526 Frame, rear light, right
These guys.......
Im waiting for the shuttle to take me home,I dropped off my baby for coding. As for the frames, I didn't have an issue taking them out and I know about the tab that has to be cut if you want to keep the old frames. but I have a NEW frame from the 2006+ tail lights and it doesn't seem to be a simple swap i think they might be different. I couldn't get it to fit. Here are pics before and after.
The car goes in Tomorrow for a whole new paint job!
When linking images from Photobucket use the "IMG" link method instead of the "HTML" method. It's the last of the 4 link options.
