Wow! What a difference... (handling)
- RickZ4
I've never been overly thrilled by my Zed's handling since I bought it. I went down the usual path. Ditched the run flats, new bushings, 4 wheel alignment from FCD in Bristol (great job)... but it still ain't no Boxster!
Then, as I pulled out of the drive last week, the tyre pressure and brake warning lights came on and the car was pulling very strongly to the left. I tiptoed into the stealers in Dorchester for advice and they said I would have to leave it and pay £106/hr for a diagnosis.
However, they said that normally I would have to book 2 weeks ahead but seeing as I was there they'd squeeze it in and give me a loaner. I needed to get to work, so they kind of had me over a barrel anyway. That afternoon they called to say that it wasn't obvious what the problem was but wanted to try reprogramming the steering sensor - would I authorise? Next morning, they called to say it was fixed
The bill, including 2 days insurance on the loaner (335d X-Drive M Sport) was £96. Was I happy... On top of that, the car is handling better than it ever was, and this is reason for my post. If you've tried everything to sort your handling and are still not satisfied, try reprogramming your steering sensor.
And a thumbs up to Westerly BMW in Dorchester.
07 2.5i Sport Auto
Onlinebuzyg
£96 quid to pump your tyres up,....bargain.....
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- maxman
And he's old
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- RickZ4
Nope, the first thing I did was to check the tyre pressures. I'm neither old, nor stupid.
You can also add the cost of cleaning the car inside and out. It hasn't been done for a month.
07 2.5i Sport Auto
Firebobby meant me being old Rick, not you.
Just a jokey post fella. Glad it’s sorted.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- RickZ4
I get itjohn-e89 wrote: ↑Sun Oct 22, 2017 1:16 pmFirebobby meant me being old Rick, not you.
However, I still can't get over the fact that:
Tyre pressure warning light + brake warning light = reprogram steering sensor = more planted than it's ever been
07 2.5i Sport Auto
- enzed4
Glad to hear it turned out to be an easy fix for them. But, how do you reprogram the steering sensor? Is there a list of parameters that need to be set? Just wondering if it would be easy to compare the 'right' settings with what's currently on the car, via INPA/NCS for example.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- bradz
I think you can reset the adaptions using INPA...
Z4M Coupe, E92 M3, E46 M3 Track car
- sw4nny
Try messaging andyfanshawe he did mine and several others for a lot less than £96 whilst my car was there for a new starter motorenzed4 wrote: ↑Mon Oct 23, 2017 10:25 am Glad to hear it turned out to be an easy fix for them. But, how do you reprogram the steering sensor? Is there a list of parameters that need to be set? Just wondering if it would be easy to compare the 'right' settings with what's currently on the car, via INPA/NCS for example.
