German gear adjustment fix? Can you share this with us please?MACK wrote:I'm Sorry but this simply isn't true, I have spoke to a few members privately on this and those that have done the german gear adjustment fix haven't had any further reoccurring issues.jamesbond wrote:sorry to give bad news ... but normally the only 100% fix is a new steering column
unless you can find someone to strip change the bearings and lubricate the worm gear .. for me I had to change the whole rack that cost £3k . this was BMW main dealer though but at least got a 2 year warranty
Sticky steering problem. Time to sort it! Help and advice.
2008 Z4 2.0i SE E85, Space Grey, 18" 241 staggered rims, 255/35/18, 225/40/18, 2 tone anthracite/silverstone leather Msport heated seats, M sport MFC Steering wheel, Bluetooth, Comfort pack, Tracker, Automatic climate control, Gaptech, Blah, blah.
- MACK
There's a link to it in GuidoK's post on page 16 of this threadGeezah wrote:German gear adjustment fix? Can you share this with us please?MACK wrote:I'm Sorry but this simply isn't true, I have spoke to a few members privately on this and those that have done the german gear adjustment fix haven't had any further reoccurring issues.jamesbond wrote:sorry to give bad news ... but normally the only 100% fix is a new steering column
Silver 05 3.0i SE
White E89 20i M Sport
- Shady Ady
Just followed the link but it's all in German, can anyone shed any light?
Ady
Ady
3.0i SE Royal MFSW, ZHP, Cruise, Ginger, stubby, GAPTEH RCH+
- Ewazix
Depending on your web browser it should translate, on Chrome either automatically or by right clicking and select 'translate'. Other browsers have similar functions but be warned the translation is usually a bit dodgyShady Ady wrote:Just followed the link but it's all in German, can anyone shed any light?
Ady
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- Shady Ady
Many thanks will have a go on the laptop tomorrow
- MACK
Depending on your web browser it should translate, on Chrome either automatically or by right clicking and select 'translate'. Other browsers have similar functions but be warned the translation is usually a bit dodgy [/quotEwazix wrote:Shady Ady wrote:Just followed the link but it's all in German, can anyone shed any light?
Ady
if memory serves and you do a search there are a few other threads on here that go through the procedure in plain english.
Silver 05 3.0i SE
Onlinebladeowner
Have to agree with MACK. I now believe the majority of sticky steering issues can be cured by moving the eccentric ring - see here: viewtopic.php?f=3&t=78250&hilit=eccentric#p1152263Shady Ady wrote:Just followed the link but it's all in German, can anyone shed any light?
Ady
I later found that that 10mm movement sorted mine permanently although I had different bolts to the German peeps which caused access issues.
2004 Sapphire Black 2.5 SE Z4 SMG
- chutley
Re-visiting this thread...
The movement of the tension ring by 12mm completely sorted my Z4 sticky steering. Many thanks for the steer bladeowner.
Onlinebladeowner
Amazing, isn't it?
I nudged mine 14mm; total fix. I tried the grease thing first, only minor improvement. The trick for me was to remove the knee airbag so I could see what I was doing, and use a very shortened 6 mm stub with a universal and about a 4" extension. With that, it became almost easy. Aside, of course, from laying on my back under the dash, which is not at all fun.
Thanks to bladeowner and GuidoK for pointing me to the fix.
Greetings,
I have just done it and it is simple and very effective. First I lubed my axle joints with some lithium based grease. In a left side wheeld car is pretty easy, with my averge sized hand could do it within 2 minutes. Then I drilled the whole, but for first time i did not do it right, the hole was offcentered, so I diceded to expand it, the original was 3 mm than i went to 4 and 5. With 5 mm i can see a small hole inside my hole, tha I sprayed some PFTE (Liquid teflon) into the hole. TBH i didn not cover it yet, I am planning to plug it with a greasing nipple. With the joint lube the car get definetly better (tried separately), but in hot weather the stickyness remaind. After the drill IT HAS GONE! Thanks for the orignal poster (Bmwha) and all of you who made comments and shared your experience. Now I can use my car safely and drive it like it meant to be!
Cheers from Hungary!
PS: If any of you looking for help my Hungarian fellows (and of course any of you also), PM me.
Hi Bladeowner,
I have just bought an 04 Z4 3.0 as a weekend runner with what seems to be exactly the same problem you had. Are there any videos or more detailed pictures showing how to adjust the eccentric ring. I'd prefer to try that before do any drilling!
Cheers,
Stu
Cheers,
Stu
Current:
2016 BMW F30 330e Msport+
2004 BMW E85 Z4 3.0se (manual)
Previous:
2003 E39 530i Msport (auto)
2004 E46 330ci Msport (manual)
2008 E85 Z4 3.0si se (manual)
2008 E92 330i Msport (auto)
Previous:
Onlinebladeowner
This thread should give you the best answers with pics and the BMW official instructions. viewtopic.php?f=3&t=100725BB16 STU wrote: ↑Sun Apr 29, 2018 9:04 am Hi Bladeowner,
Cheers,
Stu
Perfect. Thanks mate.
Current:
Previous:
Previous:
Another success story here. Thanks for bringing this to light! Adjusted the ring by around 10mm and solved it. Thanks again.
