Oil Light
- Stratts
Re: Oil Light
Are you sure the level is fine? Switching off and finding the yellow light on is normally a warning that the level is a bit low. Check oil with the engine still hot (10 mins after shut off).
Mine was the same, I was convinced the level was fine, as soon as I topped it up everything is fine again.
The other possibility is the oil level sender in the sump, which can easily be replaced but is not particularly cheap.
Red oil light is oil pressure related.
2004 Z4 3.0i Auto
Sapphire Black / Red M Sport Leather / Eibachs / 108s / Poly Bushes / Vanos upgrade / Stubby
Amateur BMW Guru. If I don't know how to fix it, it's because I haven't broken it yet.
Diagnostics and coding services available.
- Wyldie85
Re: Oil Light
If you switch off and the yellow light comes on then it means you need to add 1L of oil.
I know this because mine has come on again this morning so must add some when I get home.
Re: Oil Light
Put some oil in and happy days back to normal, thanks guys
