Squeeking steering
- Leesfarm07
Squeeking steering
Just come to use the car again after prob 3 months and the steering is so squeeky turning at low speed off the drive... can I oil somewhere?
Current
2012 Mercedes SLK 250 AMG Sport auto in black
Westfield SE 1800 Zetec on twin 45's Aldon-Tuned pocket rocket in orange
Gone but not forgotten my lovely Zed 2.5
Squeeking steering
I would just use it for a while and see how it goes, if it's been sitting, things can dry out. You could try oiling the little UJ in the engine bay, but you need to use a spray tin with a nozzle so you can fire the fluid into the joint.Leesfarm07 wrote:Just come to use the car again after prob 3 months and the steering is so squeeky turning at low speed off the drive... can I oil somewhere?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ewazix
Squeeking steering
+1 on lube on the 2 UJ's as worth trying,
Getting some silicone spray up in to the white plastic collar/bearing where the steering column comes out through the firewall in to the engine bay sorted mine a few years ago and hasn't returned
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- Leesfarm07
Squeeking steering
Thanks firebobbyfirebobby wrote: I would just use it for a while and see how it goes, if it's been sitting, things can dry out. You could try oiling the little UJ in the engine bay, but you need to use a spray tin with a nozzle so you can fire the fluid into the joint.
I've driven a few miles since and it's deffo quieter...and I've just oiled the UJ under the bonnet so ill drive it a bit more and see how it goes. The links on squeaky steering all talk about drones but mines like a dry plasticy noise....suppose I could turn the radio up
Current
- Leesfarm07
Squeeking steering
I'll get some silicone spray spray from engine bay side or inside the cockpit?Ewazix wrote:+1 on lube on the 2 UJ's as worth trying,
Current
- Ewazix
Squeeking steering
A good squirt upwards from low down, looking back at the firewall from inside the engine bay where the column comes throughLeesfarm07 wrote:I'll get some silicone spray spray from engine bay side or inside the cockpit?Ewazix wrote:+1 on lube on the 2 UJ's as worth trying,
Fiesta Ecoboost
Fiesta Ecoboost
- Leesfarm07
Squeeking steering
Current
- Ewazix
Squeeking steering
No probs, if you are stuck for more things to try I originally read about various fixes on our friends at bimmerforums, but you will need some time to read it through!
http://www.bimmerforums.com/forum/showt ... eup-w-pics
Fiesta Ecoboost
Fiesta Ecoboost
