Clanging/Rattling Over Bumps
Hi all,
Picked up my z4 coupe a few weeks ago. It's fantastic, absolutely thrilled with it. However, since the weather's gotten a bit warmer and having the window down I've noticed a horrible noise when on rough roads, bumps, speed bumps etc. It sounds like there's a bag of spanners rattling around in the boot(there isn't...I've checked!) or a similar sound to driving over loose manhole/drain covers is the best way I can describe it. I'm sure it's coming from around the drivers side/rear wheel area. It's almost silent with the windows up.
Did some searching and came across the common broken spring issue, fit the symptoms perfectly so got it booked into a local BMW specialist. But two technicians have both taken it for a drive and had it up on the ramp and have found absolutely nothing wrong with it. They were familiar with the spring issues and assured me it's not that. They also didn't charge me anything for their time which was nice and advised I take it back in a week or so if it's still bothering me.
I guess I should be pleased but the rattling noise is absolutely awful.
Is there anything else it might be?
Mat
Mat
- Smartbear
Hi, check the rear silencer support brackets-the weld can break & cause a noise when going over bumpy roads
e85 3.0si sold
- buzyg
Exhaust mount or heat shield lose. Though sure they would have checked that.
- Marlon
One would have hoped if its the silencer brackets that the BMW Indy would had spotted it. Sounds like you should have gone out on the test drive with one of them.
Gone: 3.0si 2008 E85
911 997 Carrera S
Mine did the same, check heat shields and stone guards behind disks, both prone to rusting round the mounting bolts and coming loose.
2004 E85 Z4 2.5i SE Sterling Grey.
- Ducklakeview
Strut top mounts or anti roll bar drop links?
Mike
Mike
had the same noise on my mini changes anti roll bar bushes and drop links.....ok now
only cost me £100 fitted inc parts
I had the same in my old Z. Turns out it was where one of the rear springs had snapped and the loose part was trapped within itself, rattling around! Should be visible if this is the case with yours so take a quick look
'56 ///MR
Rear springs.
Its always the rear springs.
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
SOLD
- Smartbear
No its not, mine was the silencer bracketVRSteve wrote:Rear springs.
e85 3.0si sold
There's nothing loose in the battery compartment? Mine had the toolkit loose in there, suspension is stiff enough to give it a good rattle when going over bumps
E85 3.0l i Roadster - Titan Silver
