Just got started to replace the rear wishbone bushes on my e85 2.5 roadster and came across this droplink which is snapped, but connected to a sensor. What does it do? Does it somehow stiffen the suspension when in 'sport' mode? It's so small and flimsy looking.
Does anyone know what this part is actually called / or have a part number to hand as I can't see it on a realoem diagram?
What Does This Snapped Droplink Do?
- EViS
- IMG_20170414_115324.jpg (147.38 KiB) Viewed 789 times
- Bing
That's the connector for the headlight levelling sensors I believe - quite commonly broken when people go to change springs and forget to undo it first. Though I think it's usually the plastic that breaks so that may have just corroded. You may be able to buy a replacement on eBay - check realoem.com to find the part number. You might also get one from a breakers.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- Smartbear
I think that's for headlight leveling purposes
e85 3.0si sold
- Ducklakeview
Yup that's the xenon levelling sensor as stated, there's another at the rear. Make sure you don't invert the arm when replacing it.
Mike
Mike
- Bing
Sorry, didn't realise you couldn't find it on realoem because I didn't read your post properly
This is the diagram you need : http://www.realoem.com/bmw/enUS/showpar ... Id=33_1137
I have randomly selected a model so you may want to adjust the model type just in case the parts differ. Pretty likely they don't for something like this though.
- EViS
So #5 on that diagram (part number: 37146766778)? Same part number as on my model, comes under the rear axle category as opposed to front axle which is where it's located .Bing wrote: ↑Fri Apr 14, 2017 12:28 pm Sorry, didn't realise you couldn't find it on realoem because I didn't read your post properly
- Bing
They are different shapes, so I'd go for the one that looks the same as your broken one with the bolt holes facing in different directions - number 5EViS wrote: ↑Fri Apr 14, 2017 2:30 pmSo #5 on that diagram (part number: 37146766778)? Same part number as on my model, comes under the rear axle category as opposed to front axle which is where it's located .Bing wrote: ↑Fri Apr 14, 2017 12:28 pm Sorry, didn't realise you couldn't find it on realoem because I didn't read your post properly
- EViS
Great, part ordered of the 'bay. £13 delivered .
Out of interest, how does this affect my xenons at the moment with the broken link?
- Ducklakeview
