Post
by tomscott » Mon Dec 05, 2016 3:43 pm
Not really been looking forward to writing this post. But...
The car started to clang after I did a 300 mile trip at the weekend. Been anxious all week and not really been much fun, sounded like sticky lifters trying not to panic but reading online never makes anything better especially when it comes to Porsche. Had the car inspected and the car is only a 2 owner, has done 2k in the last 18 odd months which I did 1000 in the 10 days I had it.
It's hard to comprehend the length you must go to, to get the right car.. it's rare to find a car of that age with low owners especially a roadster. You just never know how it's been treated regardless of owners. You will never know either unless the engine is stripped which makes no economical sense.
Took it to the specialist, Strasse (leeds who are excellent) we have used for years and he did the 117 point inspection and put a camera down all of the left banks and couldn't find any bore scoring but the sound he thought was most certainly piston slap. The car also started to vibrate over 3000rpm which was very disconcerting. Essentially it was almost certainly the onset of bore scoring. But it could have been a sticky lifter but the hydraulic tappets never go wrong. An oil service could have sorted it but probably not. No point spending the money doing it.
The RMS had a very slight leak which he put down to the car sitting for 18 months then doing 1000 miles in so little time, otherwise they tend to leak quite a bit and you would see the patch which it wasn't previously. RMS isn't the nightmare like the 911, the 911s is contained so no signs and then it penetrates and starts creating havoc. The boxster advice is to leave it until it needs a new clutch.
The clutch also started juddering which he thought was down to the oil penetrating onto the clutch but at 77k it probably needed a new clutch anyway. The rear discs were gone too, problem with having the engine right next to them is they tend to rust because of our climate and the heat coming from them, same with the exhaust bolts which is not a surprise or difficult job and I would have done on any car this age. The drivers side condenser also had a slight leak which could only be seen right in the far end, so hard to see. You get a very small damp circle where it is leaking but with the weather very hard to spot. Also leaves and dirt tend to build up in the front of the car and the condenser tends to rot good idea to replace as a pair as replace one the other will go too.
So really the main maintenance I was thinking needed done was the rear discs, some bolts and some cosmetics. The inspection showed the car was pretty much a financial write off. The bore scoring would cost 5500-6500 when not if, the RMS might as well do the IMS at the same time and the clutch and flywheel so another £3k minimum rear discs and pads £600 and the condensers pick a number £1000 plus labour probs. He said give it 3 months and if not treated catastrophic engine failure is the most likely outcome.
Just shows, the car had 0 symptoms which is why I bought it, no noises pulled well no leaks and within a week of some motorway driving the car developed all of these symptoms. TBH the engine could have been numerous things may not have been bore scoring as the camera showed no ware to the liners at all but the pistons you cant check without stripping the engine which makes no financial sense. So probably wouldn't have been £6k but the fact is its a possibility on a car I had owned for 10 days.
I think I was very unlucky the specialist said that the 3.2 is the most reliable engine out of them all as its the base block before they bored them to 3.4, 3.6 and 3.8 and said in the time he's had the garage there has been one or two but both with double the mileage and very unlucky for a 2 owner car.
All in all the car probably needed 10-12k spent on it with labour and more would have probably been found along the way. So more than I paid for it. The dealer knew of the my issues before I sent it to the specialist and offered me a no quibble money back guarantee if the inspection came back like it did. I took the car back and got my money back thankfully which I think was very lucky also... How many dealers would be ok taking a car back with no financial penalty as its not really their fault either... at the end of the day its an 11 year old car most is ware and tear and probably not enough care taken early on in its life warming up etc.
Just shows you cannot be sure at all. You need to get it up on the ramp and see whats going on before the purchase.
I don't seem to have much luck, brand new Mini Cooper S 2 engines 2 gearboxes in 12k miles now my weekender has gone the same way.
Im sure I probably should have taken my own advice that buying a 2 owner car that's 11 years old and not expect many issues. But pretty much everything major that could go was going.
Gutted is an understatement and has made me very worried about future purchases. I would say I'm well versed in the issues been Porsche obsessed for so long and dads car being one of the 911s with the possibility of all of the above issues, keeping an eye out for the 5 years he had it.
So Saturday I went from manc to Leeds Leeds to Birmingham and then the train home car-less.
Absolutely gutted. Obviously was a terrible idea. It's put me off thinking about what next and its obviously embarrassing posting this and eating my words.
Only caveat is nobody was hurt and it's just a bit of metal and silver lining that I got the money back.
Cheers Tom
