plasispray wheels
plasispray wheels
anyone on here tried plastispraying wheels at all??
- dhobbs
plasispray wheels
I've read about it on other sites. Not sure whether to do this on my winter wheels.
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
plasispray wheels
Yes, I have done several sets on my cars, the newer metallic sprays are more durable..
- dhobbs
plasispray wheels
Does it take to the wheels if they have corrosion?
plasispray wheels
if you clean them up, so there's no loose corrosion then yes, BUT it won't fill the pits so it'll look fine from s couple of feet away but not pass close scrutiny
On the plus side - if you don't like it you can peel it off easily so it's worth a shot.
plasispray wheels
Her's a couple of before & after shots from my Smart Roadster and my wife's SLK
- road1.jpg (121.08 KiB) Viewed 2359 times
- Paulr
plasispray wheels
That Roadster Spikeline has come out well. Hate to it but the Merc wheel looks like a plastic trim...
If you try and take a cat apart the first thing you have is a non working cat.
- Chris_D
plasispray wheels
Did this to my E36's winter wheels, now pilfered for use on the zed in winter. they look tiny as theyre 16" but plastidipping them matt black helped mask the size discrepancy a tidbit.
As above, make sure surfaces are skweeky kleen before spraying and give sharp corners a few sprays as it can tear if too thin.
