nfbr's 2007 Ruby Black Z4 Coupé! Blog/Build-Thread
- nfbr
Re: My 2007 Ruby Black Z4 Coupé!
After a trip along the Pennines over to my parents house, I'm starting to remember why I said I'd never buy another black car! I'm sure it'll come up good after a wash!
Anyway - once the rain, snow and hail had stopped I nipped out to have a check up on some of my gripes.
Dropped the glovebox door down to see the fuses, checked fuses 37 and 14 for continuity, all ok, so swapped them for fresh ones anyway. Checked fuse 14, live only with ignition as it should be. Checked fuse 37, permanently live. So everything is all good at that end. My next job later in the week is going to be to check the terminals at the horn end to see if any power is coming down them when the horn is pressed...
But for the time being - I have found the resolution to my glovebox issue. On the right hand side of the first image you will see a black plastic tube moulded into the glovebox lid within which sits a brass pivot bush, this slides over a peg allowing the pivot.
On the second image you see where the fault is! The right hand side tube has become damaged and the top half of the tube that retains the brass pivot bush. Luckily the bottom half has remained intact, so a quick fix with a cable tie was carried out, wrapping it around the brass pivot bush and the remaining section of the plastic tube that the pivot bush sits unti.
I still ideally need to adjust the latch at the top as you have to give it quite a stern push to get the glovebox to shut properly.
Hopefully somewhere along the line someone will find these helpful
P.S. Sorry about the terrible photo quality, for some reason I picked up my iPad instead of my iPhone.
nfbr's 2007 BMW Z4 3.0si Sport Coupé - Car Diary/Blog/Build Thread
Ruby Black - Steptronic - Champagne Merino leather.
I like taking Photos, Cars, Technology and Rock Music
I had my M coupe out over the pennines(Woodhead>>Snake) earlier on...
My OCD got the better of me when i got home and i had to wash and dry the car.......lol.........
- nfbr
So... A couple of my colleagues were staying behind at in the workshop tonight, so I took the opportunity to make my Z4 horny again!
Having ordered up a pair of so called 'Direct replacement horns' from Euro carparts, I found that they weren't exactly a direct replacement, but soon figured out a way to fit them on without chopping up the original wiring harness.
So, As you can see on the original horn, there's an electical contact designed to fit the O.E plug. Upon removal of this contact from the horn housing, You're greeted with something that can be used for a nice custom loom!
This 'Micky Mouse' shaped electical contact has two sockets inside it which fit the red 'bullet' connectors a treat!
Before going any further at this point, I plugged my new looms in and got a colleague to press the horn button whilst I checked with a multi-meter for voltage.
All was good, so now ready to fit!
Attached the horn to it's original bracket and bolted back up in position (this time with the horns facing away from the front of the car, so they don't drown again!!)
Now bolted up into position, covers re-fitted, tested and all working perfectly! Very happy that this didn't end up being a nasty job involving more intricate wiring.
And now... time for a couple of pictures of the car in our workshop (Sorry for how dirty it is... I'll be giving it a clean over the weekend!)
And if anyone's interested in the E46 M3, That's my colleague Mike's M3 - His build thread can be found here on M3 Cutters
It's been having a pair of these fitted...
What does it say about VAG's when you guys are driving BMW's...
- nfbr
So, With Mike and John struggling for clearance with the manifolds on the E46 M3, I decided it was time to make a cup of thinking juice... Then get on to downsizing the foam in the intake resonator pipe.
Truth is, This stuff ^ solves more problems every day than money does!
Intake tube off...
Foam Removed. Now I didn't really want to make it too much louder than stock...
So, reduced the longer piece of foam by 40%, and the shorter piece of foam by 30%
All done, Back together and ready for a road test!
Intake tube off...
- nfbr
It says a lot!Z4M-2006 wrote:What does it say about VAG's when you guys are driving BMW's...
Firstly - That I've worked as a VAG Specialist since 19 years old in the parts trade right up to being close to 30 years old in the performance sector! Near 10 years is enough for anyone to get bored of anything!
Secondly - For the ~£10,000 price point, there just isn't anything that VW/Audi/SEAT/Skoda produce that makes my balls tingle!
Thirdly - I see the common problems of VAG cars day in day out, So can't look at a used VW car without thinking... this guys selling it cos it's f***ed
Love the Z4 so much already though!
You dont have to explain yourself to me.....lol..
I do the same job as yourself...
- nfbr
Re: My 2007 Ruby Black Z4 Coupé! Diary/Blog/Build Thread
Some more goodies have arrived today! Possibly a job for this weekend!
Was that a cup of piss?
Simon's Ruby Black Z4 MC Journal
viewtopic.php?t=70563
E36 M3 Evolution - Individual Journal
http://www.bmwowner.com/forum/viewtopic ... 6&t=209427
The closer you are to death, the more alive you feel!
- DPG
Good work.
Any exterior mods planned? Aero skirts, M front & rear, Quad pipes etc.
- nfbr
If you have Milky piss, then I think you might need to see a doctorsimonlpearce wrote:Was that a cup of piss?
I've only just discovered the wonder of the Aero skirts! and love the M-Front bumper. I quite like the twin pipes and wouldn't want to make an Si look like an M though, so bodywork is probably gonna stay relatively subtle. Suspension and handling is more my thing.DPG wrote:Good work.
- DPG
Aero skirts do look good even on a black car.nfbr wrote:If you have Milky piss, then I think you might need to see a doctorsimonlpearce wrote:Was that a cup of piss?
- nfbr
Oh wow! Now that does look really nice and muscular!DPG wrote:Aero skirts do look good even on a black car.
I wish I knew what BMW were thinking when they put those stupid reflectors on the sides of the si front bumper.
Also loving the M-Grilles. The chrome rim on black bars does suit a black car!
- nfbr
Both absolute stunners! Must admit, I think only the 'M' can pull off the colour red. Having seen a couple of 'si' coupé in Red, I just feel they look as if something is missing.
