Nice work fella.VRSteve wrote:Work
Winter Project
Winter Project
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
SOLD
Winter Project
Quick update
New shocks, arms and drop links
All bolts replaced
New seals and filter
Back together!
Want to finish the Aprilia tomorrow (Bike hiding at the back) and get it in for MOT, so once thats done I'll turn the car around and start on the back!
All bolts replaced
Back together!
SOLD
SOLD
Winter Project
Its the oil restrictor in the vanos
2 seals and a gauze filter.
The seals on mine were flat and squashed but not leaking, the gauze filter was filthy.
Took 5mins to change, and really no excuse for not doing it!
http://www.hackengineering.co.uk/produc ... vice-pack/
SOLD
SOLD
Winter Project
Agreed! Cracking stuff, thanks for the link!VRSteve wrote:Its the oil restrictor in the vanos
Winter Project
While your doing that check the belts tooJAD wrote:Agreed! Cracking stuff, thanks for the link!VRSteve wrote:Its the oil restrictor in the vanos
Took 15mins to change mine. Could do it in 5 now.
SOLD
SOLD
Winter Project
Nice work, Steve!
I was wondering if you or anybody else knew what the plastic ring next to the smaller o-ring on the VANOS pressure regulator valve is for? It just seems to be some kind of spacer?
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
Winter Project
It is just a spacerMangozac wrote:Nice work, Steve!
Hack engineering sell replacements if you need one!
SOLD
SOLD
Winter Project
Looking good buddy
May buy the kit also:)
Torque for bolt afterwards?
Ta muchly
Ta muchly
Winter Project
Can't find one on TIS, but you know when its right, its bottoms out in the vanos block, you can feel it!D4dawg wrote:Looking good buddy
Ta muchly
SOLD
SOLD
Winter Project
Ah cheers buddy:)VRSteve wrote:Can't find one on TIS, but you know when its right, its bottoms out in the vanos block, you can feel it!D4dawg wrote:Looking good buddy
Ta muchly
Winter Project
Yeah I'd figured that but just wanted to make sureVRSteve wrote: It is just a spacer
Mine seemed fine so I just left it.
That's correct - the sealing is done by the outer O-ring so it only needs to be tightened enough to hold in place, hence why a torque specs isn't provided. Same with the oil constant pressure valve on the side of the engine block.VRSteve wrote: Can't find one on TIS, but you know when its right, its bottoms out in the vanos block, you can feel it!
Winter Project
I thought I found a value for the CPV on the side of the block.........let me checkMangozac wrote:Yeah I'd figured that but just wanted to make sureVRSteve wrote: It is just a spacer
Pressure holding valve to crank case (1bar) 20NM
SOLD
SOLD
Winter Project
Oh wow I feel silly now! That does indeed seem like the correct spec and I've just found it too - when I looked in the past though I only checked under the oil supply category, not engine block! In my defence though, all of the online DIYs I read didn't specify a torque and used the logic I explained aboveVRSteve wrote:I thought I found a value for the CPV on the side of the block.........let me check
