kangarooing
kangarooing
Can anyone tell me if the kangarooing effect I get in 1st or 2nd gear, but particularly moving down to 2nd, is my poor clutch control
or "normal"occasionally in my Z4MR?
Can be quite disconcerting at times , is this improved by CDV delete or just getting used to knowing how to avoid it?
Have had car few months now.
Excuse any ignorance
Z4MR Titanium
- buzyg
kangarooing
Mine does it a bit when it's really cold. I.e. When I first drive off in the morning, it's better if I use higher octane fuel but doesn't completely disappear.
- Bing
kangarooing
You can learn to drive round it, but CDV removal helps. That said, it's still possible to look stupid if you don't concentrate
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
kangarooing
Characteristic of the car underfortunately, there are several ways you learn to drive around it and after a while it shouldn't be a problem.
07 Z4MC standard spec
kangarooing
Just the way it is, takes a bit of getting used to, almost as embarrassing as sticking it in reverse at the lights instead of 1st, or is it just me!
2008 Z4 2.0i SE E85, Space Grey, 18" 241 staggered rims, 255/35/18, 225/40/18, 2 tone anthracite/silverstone leather Msport heated seats, M sport MFC Steering wheel, Bluetooth, Comfort pack, Tracker, Automatic climate control, Gaptech, Blah, blah.
- srhutch
- Moderator
kangarooing
Must be too rough with the gear stick to select reverse by mistakeGeezah wrote:Just the way it is, takes a bit of getting used to, almost as embarrassing as sticking it in reverse at the lights instead of 1st, or is it just me!
- ronk
kangarooing
Don't complain about the kangaroo clutch until you've driven one of the original Lotus Elans
- RickRob
kangarooing
I had this a few times when I first got mine. Got used to it now - all gear changes up and down are super smooth now.
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
- maxman
kangarooing
CDV removal helps,but you can still get it if you just dump the clutch.
- ronk
kangarooing
It's in the system for a reason tho!!!!maxman wrote:CDV removal helps,but you can still get it if you just dump the clutch.
German Engineers don't tend to do things just for fun.
I would err on the side of caution and learn to live with the cdv in situ.
- Smartbear
kangarooing
It's to ensure the cars transmission lasts a bit longer than the warranty periodronk wrote:It's in the system for a reason tho!!!!maxman wrote:CDV removal helps,but you can still get it if you just dump the clutch.
German Engineers don't tend to do things just for fun .
e85 3.0si sold
- markos
kangarooing
I once did that! Never did it again but I felt a right plank!Geezah wrote:Just the way it is, takes a bit of getting used to, almost as embarrassing as sticking it in reverse at the lights instead of 1st, or is it just me!
R8 4.2 V8... Previous: Sapphire Black MC | red/black bi-colour heated seats | nav with camera alerts | BT | extended storage | elec folding mirrors | PDC | loudspeaker upgrade | Intravee | CSL reps | Remus backboxes
- ronk
kangarooing
I would say the driven plate is the weakest link in the chain.Smartbear wrote:It's to ensure the cars transmission lasts a bit longer than the warranty periodronk wrote:It's in the system for a reason tho!!!!maxman wrote:CDV removal helps,but you can still get it if you just dump the clutch.
- srhutch
- Moderator
kangarooing
Never heard of anybody having an issue because they have removed the CDV. As long as you give your car the respect it deserves removing the CDV will not cause any issues.
