Certainly looks like you could stand at least a size up if not 2 from that picture unless its the angleDas882 wrote:I've had Altenzo's fitted on the recommendation of the fitter, he and his son both have M3's and they say they cannot fault them. As you can see from the photo the shoulders are quite rounded and to me looks like there would be room to go with a wider tyre?
I should of stated that the offsets are 38front and 27 rear.
If you specifically want rim protection then you could be better choosing a different brand ?
The review of those tyres does read very well but only trying them out will tell the whole story , they may well perform out of their price range the few budget tyres ive tried on my cars along the way i found in general when new on 6,7,8mm most performed ok but as the mms drop to 5,4,3 then they struggle to keep up whereas a Michelin/Vredestein or Conti always find the same no matter how worn
Also worth noting the yellow dot should be where the valve is but unless you have a problem with how they feel at speed its not worth fussing over
