Meaning?
Nurburgring lap
- Franzino
Nurburgring lap
Crikey moment at 1.41! Good effort.
Nurburgring lap
I assume he means that you must be very happy with it!
- Chris_D
Nurburgring lap
Yep. Excuses jonger- het is een engelse vertaling!
Jij bent heel blij met hem?
- Franzino
Nurburgring lap
LOL; ok I did not know the expression....yes indeed; the M2 is a lovely daily car and I'm very happy with it...but on track I love my Z4M a bit more; viewtopic.php?p=1409884#p1409884
Nurburgring lap
That's a tad bit late for me but I'll try to reschedule so I can make an appearance Will read up on the track day rules, would anyone be able to rent a (track) car and enter or is it invite only?
2009 Z4M Coupe (TiAg) 80k KM
Nurburgring lap
Very impressive lap! I've managed 8:13 with mine (Pagid RS14 front, RS29 rear, standard suspension and PSS tires). I recently mounted CUP2s and will soon upgrade to a KW V3 suspension. Not sure I'll be able to hit the 8 minute mark though. 7:47 is an amazing lap time!
Nurburgring lap
Thanks very much.
You'll be surprised how much difference the KW's make.
You'll be very close to 8 minutes at least
- Franzino
Nurburgring lap
The fastest lap I drove with my Z4M roady is 8.20min BTG with PSS tyres, Bilstein suspension, AP racing brakes....
Under 8 is really fast and brave with the Z4M....verry impressed!
- Franzino
Nurburgring lap
Did you set-up your suspension rather soft...and a bit softer at the rear then the front?
Nurburgring lap
Suspension is quite hard really, however the rear compression is a couple of clicks softer than usual to make the car a little more forgiving...
Thanks for the feedback.
- Franzino
Nurburgring lap
I'm on the middle setting of my Bilstein PSS-10...any harder and it lowers the grip in my experience...but a bit softer at the rear seems to work better.
Nurburgring lap
Ditto - my Ring setting is 6 front and 4 rear (day to day is 2 clicks lower for both).
I did try 10/10 - but it ends up skipping/slewing all over the place (on PSS) and gets very light on crests (especially at 140mph-ish on the bump just before Schwedenkreuz).
Probably don't see anyone else from here at the track as I've usually done 4 or 5 laps by 10am (leave hotel at 7:45, usually get straight onto the track with the car nicely warmed up).
Routine tends to be:
- 1 or 2 sighting laps
- 1 quick lap
- cooldown drive
- 1 quick lap
- cooldown
- 1 quick lap
- then go off and drive around the area for a few hours
- have a nice lunch somewhere,
- go back around 5pm for another 4 or 5 laps before it closes for the evening
- Franzino
Nurburgring lap
You also have a Bilstein PSS-10 on your Z4M?mmm-five wrote: βThu Apr 20, 2017 11:18 amDitto - my Ring setting is 6 front and 4 rear (day to day is 2 clicks lower for both).
Probably don't see anyone else from here at the track as I've usually done 4 or 5 by 10am, then go off and drive around the area for a few hours, have a nice lunch somewhere, and then go back around 5pm for another 4 or 5 laps before it closes for the evening.
Tend to miss most of the fuckwittery and 1-3 hour closures that way.
