So, came to use the car after it being not used for a few months, and the aircon is blowing warm. I had it regassed last year, not because it needed it, but as a precaution really to top the oil content up. I recall it had lost something like 15-20% according to the weight of gas that was removed, which I thought was good given it had lasted 8 years.
I'm wondering if something wasn't tightened up correctly and its leaked out, or perhaps a leak totally un-connected. So options are to get it regassed and hope for best, or delve a little deeper. I have INPA so wondering if there are any tests I can run etc? If they do leak, where is the most likely area they leak?
Justin
Air Con Failure
Air Con Failure
2008 Z4MR Silver Grey
2017 Audi A6 Avant Quattro 3.0 BiTdi
2003 Clio 172 Cup
2003 Clio 172 Cup
Air Con Failure
Do you have the air-con switched on all the time, or only when it's warm?
I was told to leave it on at all times to ensure the seals don't perish through lack of lubrication, and mine's still cold after 11 years and 150,000 miles.
- Beedub
Air Con Failure
I've never used mine ever.
i better check if it still works....
Air Con Failure
Always good to use in the winter!
