Seat back's knackered
- Chris_D
So the drriver's side seat back won't stay put as i think the brackets are buggered somehow.
Been like that since buying it.
Theyre non sport seats.
The top brackets seem to locate the top of the seat back no problem but the two white brackets bonded to the lower part of the inside of the seatback don't seem to hold the the seatback in place and i'm guessing theres either something missing or broken.
Any ideas?
Don't to detach the passenger side one in case that one gets boll0cksed up too
Receiving hole drivers side seat Left bottom inner bracket which slots into seat receiving hole Right side
Any ideas?
I had visions of you being quite slim Chris, not a fat knacker. Bought it like it, yeah right
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Chris_D
- Chris_D
bumpity bump.
no ideas anyone? all the re-trimmers out there?
fekin yewsless the lot of yuz. lol
There are 2 plactic 'pins' that push in from the bottom.
Take the seat out, (remove the battery before unplugging the airbag) and you will be able to get access and see what i'm talking about. if the 2 pins are missing or damaged you can just use two self tappers and it will be like new
- Chris_D
thanks mate. when you say '2 plastic pins' you mean different to the white ones in the pics above? theyre both near the bottom of the seat back on the inside.synthedup wrote: ↑Wed Apr 12, 2017 11:29 am There are 2 plactic 'pins' that push in from the bottom.
Yes, separate to what is pictured.Chris_D wrote: ↑Wed Apr 12, 2017 11:35 amthanks mate. when you say '2 plastic pins' you mean different to the white ones in the pics above? theyre both near the bottom of the seat back on the inside.synthedup wrote: ↑Wed Apr 12, 2017 11:29 am There are 2 plactic 'pins' that push in from the bottom.
They're like grommets that go through a hole on the base of the back plate and into a hole on the seat base.
- Chris_D
top! thx. that all ties in with a grommet i found under the seat recently. will have a crack at it...synthedup wrote: ↑Wed Apr 12, 2017 12:05 pmYes, separate to what is pictured.Chris_D wrote: ↑Wed Apr 12, 2017 11:35 amthanks mate. when you say '2 plastic pins' you mean different to the white ones in the pics above? theyre both near the bottom of the seat back on the inside.synthedup wrote: ↑Wed Apr 12, 2017 11:29 am There are 2 plactic 'pins' that push in from the bottom.
Good luck, am sure a man of you skill can get it sortedChris_D wrote: ↑Wed Apr 12, 2017 12:07 pmtop! thx. that all ties in with a grommet i found under the seat recently. will have a crack at it...
- Chris_D
Wow Laura's looking great, didn't realise how ugly you are though Chris
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Chris_D
what ya like
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Chris_D
Update: fixed!
Following the definitive, awesome and spectacularly fantastic advice given by synthedup (over-acknowledgement there synth'?) .... the seatback is now well and truly back in position and holding nicely! yay
There was a little box of spare parts that came with the car and on inspection, there were the 2 white plastic pins that synthedup referred to. They're those nasty friction-fit pins - the sort where they degrade to the point of uselessness once theyve been moved/removed a few times so maybe that's why the previous owner didnt bother re-attaching the seat back. lazy barsteward!
Anyway, all good now, once again this was following advice from Sythedup, who I might add is a top bloke! lol
