Rebuilt engine Dyno - 378bhp!
Onlineflimper
How does the Evolve CSL intake compare to the Eventuri they also produce in figures & costs?
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
- sixspeed
Sadly not, since the "before" stage was a broken engine. The whole bottom end has been rebuilt, head skimmed, new cams etc.
As mentioned above, the last time I was at Evolve I got quite low numbers, with their tune and the Evolve airbox. Will see if they still have it on file as I can't remember what it was but pretty sure it was mid-330s...
- sixspeed
Completely different. The Eventuri is a Gruppe-M style cone intake with carbon shroud/heatshield, that still uses the MAF etc. "CSL" airbox does away with the MAF entirely, and runs an Alpha-N tune. Much larger air inlet.
Also, think with tune and airbox the CSL style is usually in the £2k-2.5k range. Eventuri not sure - but guessing about £400 (not every looked)?
- MrPT
Really happy this car is back on the road. One of the best.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Mad Professor
True but its not dependent on getting the power down on rollers via the wheels
Present : 987 Box
Past history : ,Z4MR ,Cat HPC evo , XKR , Eunos VR , Eunos VS, Westie S8 ,TVR S2 , S54 Z3MR, SL500 , TVR Wedge 4.6 , Cat Xflow , Saab 900 Turbo ,Cat VXE ,Cat BDR, Cat Twincam , Elan S3 , Haldane Healey, Lancia HF turbo
- Mad Professor
Still the point here is that your engine is clearly in a healthy state whatver the exact output
Present : 987 Box
Sixspeed happy to see your car back on the road and stronger
Can I ask you if you see any differences after the tuning on the following situations:
1) At cold start the car starts the same way as before the tune?
2) What is your idle rpms?
3) Have you noticed a difference on the mile per gallon consumption?
4) Have you seen a difference between driving the car on with sports mode on or off?
5) Do you have a smell of gasoline out the pipes?
With the cams do you see any difference in the low rpms?
Thank you...
Thank you...
WOW! impressive numbers... sure you must be enjoying this amazing machine!
07 Z4 M Coupe - Sapphire Black/Imola Red
- Vanne
Very nicely indeed 6speed. Congrats again on getting it sorted mate. Sure as heck are very healthy those numbers.
Spot on! Did GS say anything about running in the bearings and cams/followers?
2007 EuroSpec Z4///MC Building/Developing Z4 GT3
Powered by Severn Tuning
- Beedub
that must fly!
www.topwrapz.com - Multi Award Winning - Detailing | Vinyl Wrap | Paint Protection Film Specialists |
Ha wouldn't really stand a chance against the Guilia, saying that will an Alfa make it to the end of the runway!!sixspeed wrote: ↑Thu Apr 20, 2017 2:48 pmHaha!Viren wrote: ↑Thu Apr 20, 2017 2:17 pmGlad you got it all sorted and showing some good figures, but you know the only real way to test it is against my car on a airfield runway right.sixspeed wrote: ↑Thu Apr 20, 2017 1:11 pm Finally got my Geoff Steele rebuilt engine on the dyno yesterday up at Evolve. Quick health check and a map tweak for the cams part of that as well.
Really happy with the result, 378bhp and 290lb/ft
Spec is H&S exhaust (cat back)
Evolve "CSL" intake
Schrick 288/280 cams
Some photos from IG post with graphs:
https://www.instagram.com/p/BTFKaPtF9RJ/
Back at the 'Ring next weekend. Hopefully manage more than 2 laps this time!
I'm there on the 6th? (although in my newly acquired Giulia QF, not the Z - but it could be there... )
I'll probably be at the goodwood breakfast, so will keep an eye out for you.
07 Z4MC standard spec
- ga41
That's a very healthy figure! Yours, TomK's and Vanne's are my ideal engine spec Z4Ms
-- http://www.freerice.com/ For each answer you get right, they will donate 10 grains of rice to the United Nations World Food Program --
- Argenta
- sixspeed
Hey FD3S, long time...
2. 1,000rpm
3. MPG on a cruise seems much the same to me. I'm sure in-town/city driving would suffer a bit just due to the increased idle RPM.
4. Ive never used sports mode on my Z, and haven't tried it since the new tune, but i'l try and let you know.
5. Not that I've noticed!
6. Low RPM is still very driveable. It's probably a little less torquey than before but hard to discern, and I don't drive the car as often as I used to. Either way it doesn't feel a whole lot different at low RPM to before, so far!
1. Cold starts are a pretty spluttery, lumpy affair, but it smooths out after a minute or so.FD3S wrote: ↑Thu Apr 20, 2017 11:05 pm Sixspeed happy to see your car back on the road and stronger
2. 1,000rpm
- RedUn
Brilliant results!
Have they sorted the heel and toe issue with their software now?
IMOLA Z4///MR
