Online
I cleaned up after my cat.
I had the bonnet up... witnessed my cat leap from the wall into the engine bay... he had a quick sniff and look around and then pissed all over the N52 goodness.
- MikeyH
Oh dear, the smelly little bugger
- 1536Z4
Finally finished fitting Geoff Steel carbon roof .
- 20240402_173046.jpg (229.16 KiB) Viewed 541 times
- 20240402_173026.jpg (176.91 KiB) Viewed 541 times
- 20240402_173008.jpg (113.39 KiB) Viewed 541 times
- 20240402_172951.jpg (127.51 KiB) Viewed 541 times
- 20240402_172939.jpg (186.67 KiB) Viewed 541 times
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Barty
Very cool! How would you rate the finish? Heard the clear coat isn’t always briliant?
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- 1536Z4
Hi Barty .
No its not a showroom finish like the diffuser but then it is a decent price for what it is . I don`t think they are clear coated just epoxy gelcoat . If you wanted a decent finish you would need to wet sand / clear /sand /clear and so on . The weave is also quite wavey and there are some bubbles. To me it does the job and is sold as a race part so is acceptable especially from 6 foot away
Today after 4 months i am done ready for season
E53 4,4i
E70 4,8i
F10 - 530xD
E85 - 3.0i M54
E70 4,8i
F10 - 530xD
E85 - 3.0i M54
- patriot66
The cable in my nearside window regulator finally succumbed to corrosion and snapped yesterday. It was the original and almost 21 years old ! Managed to source a new complete regulator locally (not a cable repair kit) and fitted it this evening. Quite a straightforward job if a little bit fiddly. All greased up, adjusted and working very smoothly and quietly now. It's so smooth that when I get chance I'll strip the offside door down and inspect the regulator with a view to cleaning/greasing or replacing that side
Marking his territory, that's his car nowFred Smith wrote: ↑Mon Apr 01, 2024 8:34 pm I cleaned up after my cat.
- MikeyH
Perhaps he is hinting that you should get a big cat E typeFunkyGBrown wrote: ↑Wed Apr 03, 2024 10:27 amMarking his territory, that's his car nowFred Smith wrote: ↑Mon Apr 01, 2024 8:34 pm I cleaned up after my cat.
Replaced O2 sensor bank 2 before cat. Code 2715 cleared and engine management light extinguished. Result
2003 Maldives Blue 3.0i auto
Online
He did also jump in when I got in to move it... straight up the back, slipped through to the coupe's boot like the boot cover is one of those rat traps where the rat falls in a bucket... then out again in sheer panic when the engine fired up and the car started moving. My other car IDGAF, but I need to keep him from destroying the leather and boot cover in the Beamer... I must never let him in that car again (caveat - caged en route to vet is ok!)
- Big Andra
Had a sun strip fitted
2009 E89 2.5 Alpine white.
2008 cayman 2.7 Arctic silver.
- 1536Z4
Now guaranteed 3 weeks of solid rain
2009 09 Carbon Black Cinnamon E86
- MikeyH
Again
