Usel
Post by Usel » Sat May 11, 2024 8:28 am
STC_Zed wrote: Sat May 11, 2024 8:16 am
Usel wrote: Sat May 11, 2024 8:10 am
STC_Zed wrote: Sat May 11, 2024 8:04 am
I need to remove my seats to clean under them; I’m guessing that it’ll not be all that pleasant under them after 16 years! Daft question, but will the car be in transport mode if I disconnect the battery to remove the seats? It’s the one that’s put me off so far.
No, I think the transport mode possibility is only when the battery has been disconnected for a couple of weeks.
Only seems to effect a handful of cars.
Brill, thanks. When I first viewed the car it was in transport mode after it’d had some work done and the chap I bought it from said it was because they’d disconnected the battery, hence my reluctance to do so again. Looks like the seats are coming out soon for a proper clean then!
As it has happened to you before I would have a backup plan. What part of the UK do you live in?
If you have a business trip on Monday then I wouldn't take the seats out on Sunday :rofl:
T_J_G
Post by T_J_G » Sat May 11, 2024 9:09 am
T_J_G wrote: Fri May 10, 2024 2:20 pm Took the seats out to carpet clean underneath, they were grim. Took the time to clean all the seat rails, seats everything else I now had access. Then repaired a stone chip on a replacement wing that I may get on the car over the weekend.
Next up back brakes, and to stop the front from squealing every time I brake.
No you’ll be fine, just remember to disconnect it before disconnecting the seat plug, you’ll need it connected to move the seats to access bolts if they’re electric.
I also didn’t take the seatbelt off the base of the seat just pulled it out and put it next to the car whilst I cleaned
E85 2003 Z4 3.0i
TheDan
Post by TheDan » Sat May 11, 2024 10:00 am
Yesterday and this morning I've had my new wheels arrive, got tyres fitted, installed the front and rear stud conversion kit (finally) and mounted the front wheels (rear stud loctite is drying). Finally cracking on with getting my poor, static Z4 back to its former track loving glory.
A few pics of the wheels and studs (ignore the rusty discs, I'll be honing them or replacing them if they're too far gone).
STC_Zed
Post by STC_Zed » Sat May 11, 2024 12:46 pm
T_J_G wrote: Sat May 11, 2024 9:09 am
Thanks, yes I had the faff of moving seats backwards and forwards to get at the bolts on my electric E92 seats.
chanlon1
Post by chanlon1 » Sat May 11, 2024 3:29 pm
AdyBish wrote: Fri May 10, 2024 5:32 am
chanlon1 wrote: Thu May 09, 2024 2:31 pm
AdyBish wrote: Sun May 05, 2024 10:53 pm Whilst I was under the car I took a look at the water pump and stat. It definitely looks like it could still be the original pump. I’ve no history of it being changed and it’s pretty cruddy. The car is on 118000 miles so decided to replace it and have put an order in to Autodoc. More tinkering to come then Happy days :thumbsup:
Interested to hear how this goes as it's something I think I need to do on mine. Hoping the fact it's electrical makes it easier.......
It looks like it should be a simple job to me. There may be a surprise breakage along the way, but that’s old cars for you. :roll: The parts have arrived so I hope to crack on with it soon. Good price and service from Autodoc. I’ll report back and let you know how it goes :thumbsup:
Thanks. You should start a new topic about it, so we don’t lose any good info about the pump among this current massive thread!
E86 Z4 Coupe 2006 Silver
TOMGREEN413
Post by TOMGREEN413 » Sat May 11, 2024 4:58 pm
Very smart :thumbsup:
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport 💙 (Faster than the above....much faster :)
TOMGREEN413
Post by TOMGREEN413 » Sat May 11, 2024 5:01 pm
Changed all my water cooling parts last summer might refresh the suspension next but I'll see what my local garage chap thinks as l believe it had recent work done just a couple of years ago.
axelleveau
Post by axelleveau » Sat May 11, 2024 7:05 pm
Made some progress on front end, it is tricky as I had to weld together three pieces of honeycomb as I could not get a piece wide enough (everyone online sells up to 120cm, would have required 135 :( ). I used small strips of plastic to hide the weld and "enforce" the lines from the radiator opening. I used the originalgrill tabs and fine tuned the adjustment to avoid the edge of the opening being wavy. Blanking of one side beyond the radiator opening has the glue drying right now; other side should go alright too and then I will start with the foglights blankings.
Hopefully this will finish as a 6 foot job, mabe 3 (as in you would think it is perfect from that distance). If I was to start over again I could land a foot job with the experience and a one piece grill (see what I did there? :rofl: )
Gone - Ford Ka MK2 Petrol - Black
Will hang around to carry materials/people and in emergency - Ford Fiesta MK7 1.0 Ecoboost - Black, white rally rims, white decals, remapped
Now - Z4 Coupe - Montego Blue: Here
FixMyZ4
Post by FixMyZ4 » Sat May 11, 2024 9:07 pm
AdyBish wrote: Sun May 05, 2024 10:53 pm Fitted some spacers.
Did you do them front and back and what is the offset please.?
Where I live I have these stupid humps and considering to widen stance for comfort first, looks second, handling last (bit afraid of leaving roundabouts and loosing wheel, while on very gentle slide)
Zedebee
Post by Zedebee » Sun May 12, 2024 9:16 am
VANOS back on yesterday, fluids topped up, cooling airlock resolved.
However, on test drive there is a conspicuous flat spot at c. 3k revs and I have error code:
3C1F DME: Exhaust camshaft sensor: signal
It’s possible I haven’t plugged in the sensor properly, but any other suggestions before I get to it today?
2003 Maldives Blue 3.0i auto
j3nks79
Post by j3nks79 » Sun May 12, 2024 10:19 am
Sensor and wiring would be first thing to check.
2009 09 Carbon Black Cinnamon E86
enuff_zed
Post by enuff_zed » Sun May 12, 2024 11:08 am
j3nks79 wrote: Sun May 12, 2024 10:19 am Sensor and wiring would be first thing to check.
Yup, always start with things you've disturbed.
Be aware that even if it is plugged in, sometimes on old components simply disturbing them can cause them to fail.
Had it twice on ABS sensors after changing discs.
HQ of 'Norfolk Zed Rescue'.
Zedebee
Post by Zedebee » Sun May 12, 2024 2:08 pm
Thanks guys. Pleased to report that unplugging the cam position sensor, cleaning it up and plugging it firmly back together seems to have fixed the problem. I seem to have spilt oil on it when I took the VANOS off (NewTIS instructions suggest putting a container underneath to catch the oil - good luck with that :? ).
Oddly the sensors were reporting a static 12% angle on both the inlet and exhaust sides, even though there was no fault on the inlet side. Now they are both showing around 35% and zip up and down when I blip the throttle :thumbsup:
Now for another test drive when I clear the drive of badly parked visitors.
T_J_G
Post by T_J_G » Sun May 12, 2024 2:39 pm
Fitted a brand new second hand wing then took a few photos of it.
E85 2003 Z4 3.0i
wiganz4
Post by wiganz4 » Sun May 12, 2024 5:44 pm
T_J_G wrote: Sun May 12, 2024 2:39 pm Fitted a brand new second hand wing then took a few photos of it.
Take it you watch Salvage Rebuilds UK with that quote! 😊👍
