Rattling brake dust shields
Bought a 50cm cable tie and managed to get it around the shield it’s stopped rattling for now but definitely want to replace it!
On searching on here saw a post to a US site that supplied them in two pieces so you don’t need to take the hub off … as it seems the bearings fall apart. Mind you might be worth doing the bearing anyway if it’s that bad?
Advice?
Advice?
Currently BMW Z4 E85 3.0si
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 Turbo
Toyota Celica ST205 GT4
Nissan R33 Skyline GTST
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
- TOMGREEN413
So am I correct for your comment that these sheilds are also on the rear?
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
- pvr
Yep, they were very well vented in my case. Reversing the car sounded like I was scraping the floor
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- tug
If you remove the brake disc you can then use large washers to secure. After my first one went as i mentioned earlier in this thread, the other side started rattling so i thought sod that! Took the disc off and got full view of the bolts, secured them and been fine ever since.
E85 N46 2.0i SE BLACK SAPPHIRE
- TOMGREEN413
Thanks, I'll probably try this method my the spring.
First sensible responsetug wrote: ↑Sat Dec 23, 2023 10:10 am If you remove the brake disc you can then use large washers to secure. After my first one went as i mentioned earlier in this thread, the other side started rattling so i thought sod that! Took the disc off and got full view of the bolts, secured them and been fine ever since.
2009 09 Carbon Black Cinnamon E86
Thanks. When I get the chance to jack the car up and take stuff off will do the washer solution
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
- TOMGREEN413
Let us know how you get on please
Anyone know what size washers to use? I am going to have a go at this on Sunday morning. Will take pics etc. for the benefit of others.
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
All done. Washers definitely the way to go. Got the discs off and was faced with the bolt hole clearly corroded. In fact there is another one just the other side of the hub which I gave a gentle tug off and it literally fell apart and broke in my hands so put a washer on that one too.
Anyway for reference this is what it looked like
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
- tug
- pvr
Pah, that is not rusted
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
And thanks Tug for the advice, spot on
And not the shield itself wasn't rusted PVR, I just had a rusty hole ....
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
- pvr
I can't show you a picture now as they have been replaced, but mine were grinding on the disks when reversing as "the hole" was about 50% of the shield
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Wasn't much of a shield then mind you probably cooled the brakes better
I didn't actually have time to do the other side, I am half expecting that to kick up a fuss sooner rather than later.
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
Previously
BMW Z4 E86 3.0si
Vauxhall VX220 NA
Nissan 350z
