Rear Trailing Arm Bushings (RTAB) Replacement
- TOMGREEN413
Brilliant, well d one
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
Awesome write up and great pictures, would be good to drop in the how-to section for peeps to find later.
- Jembo
From memory you need a special tool to line up the bush on tightening so it isn't stressed.
Yantekin made a homemade one... see pickie
I also went for both poly RTAB's & RTAL's just in case.
- IMG_2893.jpeg (135.73 KiB) Viewed 874 times
Lifer 54
Lifer 54
Hey Ashley,
Sorry for late reply. I’m in Warwickshire, if that works send me a PM. Could meet you somewhere too. I’ve just got to check the tool is still working fine as may have damaged the threads slightly..
Yeah the pretensioning requirements for OEM replacements worried me as I was new to all this, so went with the polys. No regrets so far, they’ve been great.
- smorris_12
The pretensioning bit is easy: only properly tighten the bolts when the car is sat squarely on its wheels rather than when they're dangling with the car on a trolley jack.
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
Scott
- TOMGREEN413
Great to remember.
I think you submit your post in this section for a how-to and then the mods move it into the correct how to section.
viewforum.php?f=34
Thanks Matty, done.Matty_Z4 wrote: ↑Thu Jun 01, 2023 9:17 amI think you submit your post in this section for a how-to and then the mods move it into the correct how to section.
viewforum.php?f=34
Onlineryushe
@chengy, great write up. It’s another one for the “things to do” list
How long approximately did this take you?
'06 E85 Z4 3.0si 6 speed manual - Black metallic w/ champagne interior
Prev BMWs: '04 E85 Z4 Individual 2.5i • '04 E85 Z4 3.0i • '04 E46 M3 • '04 E61 535d • '86 E28 525i • '87 E28 528e
Sorry for the delay and thank you
First go was probably around 4-5 hours including set up time as I didn’t have a step by step guide, so had to figure things and ask people. Second go on the other side was a lot faster, probably 1-2 hours.
Hope this helps, any questions let me know.
Easier said than done considering you cannot access the bolt for this bushing once the bracket is in position and the tire is on the groundsmorris_12 wrote: ↑Fri May 26, 2023 10:35 am The pretensioning bit is easy: only properly tighten the bolts when the car is sat squarely on its wheels rather than when they're dangling with the car on a trolley jack.
Nice write up! I really disliked performing this job and even had a skilled helper. Having a better tool designed solely for dealing with these bushings would have helped. The tool I bought off amazon is designed for this purpose but also other BMW bushings so it was a bit less specialized for this task. Installing the new OEM style bushings was not easy so going with these poly bushings is probably the way to go. It's a much bigger job but I must admit I'd rather do my oil pan again that deal with these bushings.
