Wow, perfect, congratulation!
The two T20 screws you mentioned are connecting the motor with the hydraulic unit, right?
The hydraulic circle is a closed system, where no water can get in. If you remove the motor from the hydraulic unit in the middle, oil will run out and you should renew this o-ring. What about the hydraulic level in the reservoir on the left? You can take ZHM from Febi to fill it up, if required.
What about the current fault codes?
Water in boot rooftop goin up slowly then stopping
- RobbiZ4
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
yeah those were the screws and yeah it was mainly oil in there the levels for the oil for the hydraulic are within the min/max
- Christopher72
Dont forget to replace your trunk seals...
Christopher
2011 E89 Sdrive35i - Deep Sea Blue, Beige Kansas Leather
'fits in progress - PDC, Cameras, Comfort Access, Respray/Correction - all queued for poor weather.
(9) E46 convertibles; (1) E39 540i; (2) E36 Z3 roadsters; (1) Pre-prod E36 Z3- all gone
so i had water in the trunk again with the same roof problems i attemped to fix it by replicating what i did before and now the roof doesnt go down and i dont hear the motor running. i am getting a green light on the roof button but a red rooftop icon on the dash. the error code i am getting is 00a694. when i took the motor off the hydraulic unit some pins were beneath the o ring?. also would you happen to know what kind of oring it is so i can replace it.RobbiZ4 wrote: ↑Thu Apr 13, 2023 6:28 am Wow, perfect, congratulation!
- RobbiZ4
69 x 3,00 mm NBR70
Yes, there are some "pins" (6 or 7?) in a "wheel" on the hydraulic side of the pump, not on the motor's. None of them may be lost!
A694: Microswitch 'cowl panel reached'
Very rarely source of an issue in our E89, as it sits on top of the windscreen.
