New Member, new build
- B21
Great work..epic project
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
- Mr Tidy
You've made some good progress there with some impressive fabrication work.
It will definitely be exciting when you get to drive it!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- 1536Z4
Thats a result Looking good . Are they vibra technics engine mounts ?
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Z4mal
Current
E85 Maldives blue (fun me)
G26 i4 M50 (the weapon for work me )
F01 730d Msport (gone but not forgotten)
10 other BMWs in my history! Eek that’s a lot of
Yes, they are Vibra Technics mounts. The stock S85 ones are big old things and got in the way of stuff in all sorts of ways. I was worried about the extra engine weight but when spoke to them they advised using the race/track version of a Z4M mount as the additional weight would offset the extra stiffness and therefore achieve the right amount of compliance. Fingers crossed that works out. Nice bits of kit though…
- 1536Z4
- Barty
Love the project! Following with extreme interest
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
Hi Jason. How's progress ?
Hi,
It’s going ok thanks. I’ve got the electric steering column out and replaced it with a Z4M version. I’ve had to make a bespoke intermediate shaft to couple the column to the rack whilst moving it out of the way of the exhaust. It’s got double UJ’s at either end which means it needs support bearings to keep it in position. Boy are those joints expensive! (Flaming River parts) And I wanted to keep it telescopic still, so that was another complication. The rad and AC condenser are mounted and the prop is almost done (mostly Z4M but with an E60 M5 front spider section spliced in.) The prop ends up shorter than a stock Z4M part, so I took all the bits and a set of dimensions to a local specialist to put it all together properly. I’ve figured out how to make an E60 e-box fit by using a 3D printed adaptor between the E60 part and the Z4 chassis so that the engine harness reaches and fits properly. Oh, and I’ve made a bracket for the E60 M5’s remote oil filter/stat housing. I’m mainly trying to get all the hard points done before I start on wiring, piping up and exhaust. I got hold of an aero kit front bumper which needs a bit of work and some aero kit cill covers, so I’ve got those to sort out and swap too. The stock Z4 battery tray is out to make room for a decent exhaust so I need to put the battery in the boot and make a blank for the hole left by the battery box.
I’ll get some pictures posted when I get chance.
Cheers,
Jason.
Cheers,
Jason.
