Bogging power issue M54 3.0i
- enuff_zed
I can get to move freely but even with pliars it’s not coming out, should it pop up as it just sits flush until you turn the solenoid upside down and it then drops freely?
2004 E85 3.0i, LCI xenons, red sports interior, backbox delete, twin pipe conversion, diff ratio upgrade, coilovers, clear rear lights, cup holders, Sapphire black
2014 F31 M Performance Pack, Avin headunit, LED headlights
- enuff_zed
Ah no, not in the solenoid! In the housing. The solenoid operates it.
Item 4 on the picture above.
Ah ok the spring inside the housing of the vanos moves fine it was the pin in the solenoid that was a bit stuck
- enuff_zed
You do have the valve there between the spring and the solenoid?Wookster78 wrote: ↑Sun Feb 11, 2024 3:21 pm Ah ok the spring inside the housing of the vanos moves fine it was the pin in the solenoid that was a bit stuck
Yeah got that out and all smooth, solenoid pin moves freely now also and put on a 12v battery and pin shoots out so assuming now all good. Will try and get the lower one off now
- enuff_zed
Let's hope this is the problem then.Wookster78 wrote: ↑Sun Feb 11, 2024 3:28 pm Yeah got that out and all smooth, solenoid pin moves freely now also and put on a 12v battery and pin shoots out so assuming now all good. Will try and get the lower one off now
Well 50% there can’t get the bottom one off without the radiator coming out, just no clearance so will have to save that for another day when I have some more coolant, pain it’s so tight in there
- enuff_zed
See if there's any improvement with just that one done.Wookster78 wrote: ↑Sun Feb 11, 2024 4:15 pm Well 50% there can’t get the bottom one off without the radiator coming out, just no clearance so will have to save that for another day when I have some more coolant, pain it’s so tight in there
Fingers crossed just took her for a run and back to full power with no bogging, if the top one was gunky then the bottom must not be far behind so have to see if I can find a super deep socket to get it off.
I removed my intake solenoid with the vanos off the car during the vanos overhaul but I couldn't remove the exhaust one it was really tight, I left it because i wasn't getting any issues and the intake one was really clean however I did research afterwards removing it from the vanos whilst on the car to check it.Wookster78 wrote: ↑Sun Feb 11, 2024 5:10 pm Fingers crossed just took her for a run and back to full power with no bogging, if the top one was gunky then the bottom must not be far behind so have to see if I can find a super deep socket to get it off.
You need a 32 mm socket that is at least 3.5 inches deep quite hard to find or a 32mm crows foot spanner can also remove it but I can't confirm that.
I did find this on ebay tho but can't find a picture of it.
https://www.ebay.co.uk/itm/404554764049 ... media=COPY
04 2.2i Sapphire Black Roadster
Thanks had a look on eBay and found an extra deep 32mm socket that’s 120mm total length and inner approx 70mm so hopefully do the job and don’t have the take the whole thing apart
- enuff_zed
If that really has cured the problem it was worth a few hours of work.Wookster78 wrote: ↑Sun Feb 11, 2024 5:10 pm Fingers crossed just took her for a run and back to full power with no bogging, if the top one was gunky then the bottom must not be far behind so have to see if I can find a super deep socket to get it off.
Not exactly what I thought the problem may be, but it got you there.
Could always be an intermittent fault gremlin as it’s not a daily driver but only time will tell
- enuff_zed
Yerah, I'll keep the smug grin on hold for a whileWookster78 wrote: ↑Sun Feb 11, 2024 6:22 pmCould always be an intermittent fault gremlin as it’s not a daily driver but only time will tell
