M Track Mode enabled on Z4MR
"M" Specific discussion
BMWZ4MC
Post by BMWZ4MC » Mon Dec 24, 2018 6:09 am
Meeko wrote: Mon Aug 25, 2014 12:27 pm Well it's raining today and I've just had a play with M Track Mode enabled. In this mode DSC doesn't cut power when the wheels spin in a straight line. It also allows some slip so you can get the car sideways and it will still allow full power - until a threshold is reached. I'm not sure what the angle is, but it does allow a fair amount! Obviously you should use this mode on a race track and I can't recommend it be used on the road :D This mode is what our cars have been screaming out for and I've no idea why BMW don't enable it from factory!
I'm wondering whether this is actually just DTC and not M Track Mode. Googling both seems to suggest they are similar anyway. Either way, this mode makes the car much more driveable, especially in the wet. Obviously disabling DSC gives the best experience, but for those of us not skilled enough enough to drive with it disabled, this mode is an excellent half way house.
So to enable it on your car. The procedure is relatively straightforward and assumes you are relatively proficient using Microsoft Windows...
Firstly you need to purchase the correct cable and obtain the software. This can be found on eBay and some sellers also provide a DVD with all of the necessary software. Buying one with the software supplied might be the best choice if you're not overly comfortable installing drivers and software in Windows. The cable required is a BMW OBD Diagnostics cable but check the one you get works with the Z4 (E85). It needs to use the K-Line protocol, but you could get a cable which supports the newer DCAN protocol too (in case you upgrade to a newer BMW and wish to future proof yourself). You also need to ensure the DATEN files are relatively new. I think v50.2 had the last revision of changes for the E85. Perhaps check with the supplier which version they are sending you.
The software you need to use is NCS Expert and there are lots of guides online explaining how to use it to add Option Codes to your cars Vehicle Order (VO) list (i.e. to retrofit features), or to code changes to existing modules (i.e. enable remote roof opening/closing, beep on lock etc.)
Once you have NCS Expert installed and working, you need to enable TDR on the MK60.C20 module:
Connect the cable to your car's OBD port and turn on the ignition...
1. Load NCS Expert.
2. Load an ExpertMode profile with Manipulation enabled.
3. Hit “FG/ZCS/FA” - might be "VIN/ZCS/FA" depeding on your NCS Expert version
4. Press “ZCS/FA f. ECU”
5. Select E85 in the box that pops up
6. Click OK with AKMB highlighted
7. FG and FA field will populate after a few seconds
8. Press Back
9. Click “Process ECU”, highlight the MK60 module and click OK
10. Change CBD-Name MK60.C10 to MK60.C20 and Click OK
11. Click "Change Job" and choose CODIERDATEN_LESEN
12. Click “Execute Job”
13. Browse to C:\NCSEXPER\WORK
14. Look for FSW_PSW.TRC and open it in notepad.
Look for:
TDR
nicht_aktiv
and delete the nicht_ leaving just aktiv
15. Save the file as “FSW_PSW.MAN” - (make sure it's not called FSW_PSW.MAN.TXT)
16. Click "Change Job" and choose SG_CODIEREN
17. Click "Execute Job"
NCS will then code your car and you should see "Coding Ended". Then turn your iginition off/on and pressing DSC will enable the DTC lamp (M Track Mode) and holding will disable DSC altogether.
There are lots of guides online which explain using NCS Expert in more detail, and it might be a good idea to read these and get more familiar before you attempt this yourself.
Largely thanks to this post by Meeko and a link that TomK sent me a few months ago, I managed to code M Track Mode today as well as coding out the Dynamic Brake Assist and activating triple flash turn signals.
The M Track Mode is bloody brilliant! It allows unlimited spinning at the rear wheels whilst preventing power-on oversteer when turning with too much throttle applied. Consequently, there is no more bogging down with the DSC light flashing when pulling away hard, instead it allows the driver to meter the amount of rear wheel slip with the throttle, but without losing the safety net of DSC. It's perfect for fast road driving (although I've only tested it in the dry so far).
I'll try it on my next track day, but I suspect I'll end up switching DSC off completely as I usually do so as to keep the brakes cool as well as to allow me to have complete control of the car (at least until the moment when I don't anymore and I hit the wall :lol: )
S2000 GT - gone
Simon 3.2M
Post by Simon 3.2M » Mon Dec 24, 2018 9:26 am
Does anyone do or have this in the Midlands?
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
AldridgeZ4
Post by AldridgeZ4 » Mon Dec 24, 2018 9:31 am
Simon 3.2M wrote: Mon Dec 24, 2018 9:26 am Does anyone do or have this in the Midlands?
I'm looking to get it done in the Midlands too, if any one is around.
Now gone.......Z4MR. 2007. Boring silver.
MY05 honda S2000
BMWZ4MC
Post by BMWZ4MC » Mon Dec 24, 2018 9:38 am
I think Beedub has done this now and he’s near you guys
S2000 GT - gone
Simon 3.2M
Post by Simon 3.2M » Mon Dec 24, 2018 12:24 pm
Stand up Beedub!! 😊
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
buzyg
Post by buzyg » Mon Dec 24, 2018 12:36 pm
BMWZ4MC wrote: Mon Dec 24, 2018 6:09 am
Don't do that. :wink:
BMWZ4MC
Post by BMWZ4MC » Mon Dec 24, 2018 1:27 pm
I’ve managed to avoid it so far in fifteen years of track driving, but there’s always next time! I did my first track day here in Aus a couple of weeks ago. In the morning a Huracan hit a wall breaking both of the driver’s wrists and in the afternoon one of the guys I work with span off causing $50K of damage to his F80 M3... :o
S2000 GT - gone
dgm
Post by dgm » Tue Dec 25, 2018 1:42 pm
Striven wrote: Sat Dec 22, 2018 6:03 pm Sounds like a great upgrade, I will check if B & M in Glasgow can do this.
They do, I gave them the instructions from here a couple of years ago and Douglas got his coder to do it.
06 Z4MC, Sapphire black, Aero sideskirts, BMW strutbrace, CSL's, Remus back boxes, Intravee and Alpine DAB
Striven
Post by Striven » Tue Dec 25, 2018 3:50 pm
Great,? That will be a plan in January.
Previous
Volvo 360 GLS
BMW 318iS
Mercedes 230C
BMW 328 Cabrio
Audi S4 Avant
TVR Tuscan Red Rose
Lotus Elise 111S
Lotus Exige Cup 240
Porsche Boxster Spyder
Audi A3 eTron
Current
BMW Z4M roadster
BMW i3s
Beedub
Post by Beedub » Tue Dec 25, 2018 9:17 pm
:evil: :evil: :evil: :evil: :evil: :evil: Ill sort it for you simon.... Drop into the shop when your available... :driving: :driving:
Tcochrane92
Post by Tcochrane92 » Tue Dec 25, 2018 9:36 pm
Beedub wrote: Tue Dec 25, 2018 9:17 pm
:evil: :evil: :evil: :evil: :evil: :evil: Ill sort it for you guy simon.... Drop into the shop when your available... :driving: :driving:
Where abouts are you located mate?
Do you charge for this?
Current: Imola Red 400bhp 640d & Ocean Blue BMW S1000XR Sport SE
Past: Silver Grey Z4MR, Silver Grey Z4C & Titan Silver Z4 3.0i
Beedub
Post by Beedub » Tue Dec 25, 2018 9:58 pm
Tcochrane92 wrote: Tue Dec 25, 2018 9:36 pm
Don't want to clutter forum.. please see here viewtopic.php?f=13&t=103467&start=210
Truth
Post by Truth » Wed Dec 26, 2018 1:03 pm
Peter Van Der Veer do this for any Northern owners. I think M track mode was £40/50 from recollection. They also do other coding and all other BMW specialist work. (No I’m not connected with them
In anyway)
https://www.bmwexpert.co.uk
Z4MC
crustyclown777
Post by crustyclown777 » Sun Feb 03, 2019 1:17 pm
Anybody available in the Surrey area? I'm looking at doing some track days this year, and would love this sorted prior. Seems like a sweet spot for a novice track driver. Beers will be provided!
Z4MC Interlagos Blue
Instagram: z4mcuk
Jembo
Post by Jembo » Sun Feb 03, 2019 6:01 pm
crustyclown777 wrote: Sun Feb 03, 2019 1:17 pm Anybody available in the Surrey area? I'm looking at doing some track days this year, and would love this sorted prior. Seems like a sweet spot for a novice track driver. Beers will be provided!
One of the things I need to ask the guys at ETA Motorsport @ Brands Hatch when mine goes in for a few more tweaks in April
Joined the dark side with a ///M Hell Bronze Sepang Coupe :happyclap:
Lifer 54
