Recaro Pole Position ABE fitting
"M" Specific discussion
mmm-five
Post by mmm-five » Fri Sep 04, 2020 8:38 pm
Definitely did...not long after my last post...still haven’t got around to fitting the champagne cushions though.
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
RedUn
Post by RedUn » Sat Sep 05, 2020 11:03 am
mmm-five wrote: Fri Sep 04, 2020 8:38 pm Definitely did...not long after my last post...still haven’t got around to fitting the champagne cushions though.
They look lovely! That's made mind up!! :evil: How much lower than oem are they with the rails? I was thinking of just bolting to the floor to save 30mm or whatever it is?
IMOLA Z4///MR
mmm-five
Post by mmm-five » Sat Sep 05, 2020 12:01 pm
RedUn wrote: Sat Sep 05, 2020 11:03 amThey look lovely! That's made mind up!! :evil: How much lower than oem are they with the rails? I was thinking of just bolting to the floor to save 30mm or whatever it is?
As they are, with mounts & sliders, they're no lower than the standard seats - I got them simply for more support & comfort...without having to spend £4-5k on BMW M-Performance / Recaro Sportster CS / Tillet seats.
Without the slider and mount (there are slimmer ones available) then you'd probably save 25mm. But you could always fit some stick-on non-slip alcantara panels (about 2mm thick) instead of the foam cushions to save another 10mm - like they use in Tillets.
If I was to do it again, then I'd not bother with the sliders as I never move them - but they do make it easier to get to the bolts to remove the seats.
They were much easier to fit than I'd been lead to believe by the seat supplier (CA-Auto and Demon Tweaks). Both quoted 5-7 hours to fit the pair...it took me 2 hours for the first, and 1 hour for the second, and I've got no mechanical skills :P
Did find out the holes in the genuine Recaro sliders DO NOT match those in the Macht Schnell floor mount, which required me to drill out one hole in the sliders into a slot - so the PSDesigns one might have been the better purchase (slightly slimmer & more holes too).
Trigger’s Z4MC
Dubbedown
Post by Dubbedown » Sat May 27, 2023 8:35 pm
Bump. I’ve been toying with putting Recaros in my coupe. I actually did the same almost 10 years ago on my first track build so I’m not entirely new to this but it’s been a while. However this time around I would go with the ABE because of the 3 point comparability. Back then I had to use an extender to route the side belt.
Couple questions if you don’t mind….
  • Did you go with the heated option?
    Are the Recaro sliders and side mounts their “universal” version or seat specific?
    Back when I did my install I found a seller on eBay who offered a passenger seat emulator. Is that still the best option? What did you use to get around the occupancy sensor?
    How did the MS floor mounts work for you? I used the same (not sure if design or quality has changed) but my holes didn’t line up so I had to bust out the burr. Hoping to avoid and find more PnP option.
Thanks!
Follow latest mods on Image Imolarot_S54 M Coupe OEM+
mmm-five
Post by mmm-five » Sun May 28, 2023 11:22 am
Dubbedown wrote: Sat May 27, 2023 8:35 pm Couple questions if you don’t mind….
Thanks!
Didn’t go for the heated option as the alcantara covers don’t get cold
They’re Recaro sliders, but I just selected the ones offered on the same page as the seats
I fitted a spare seat occupancy mat from a seller on here - and that site under the cushions
Same for me with the Macht Schnell floor mounts…but I went the easier route of putting an extra hole in the slider rail - would probably go for PSDesign ones if I did it again.
Trigger’s Z4MC
Dubbedown
Post by Dubbedown » Sun May 28, 2023 1:19 pm
mmm-five wrote: Sun May 28, 2023 11:22 am
Thanks!
Interesting I didn’t think the oc sensor was even sold separately. When I looked into it years ago I was pretty sure it was integrated into factory seat and there was no separate p/n.
Re PSDesign - how do you know those would be a better fit? Would you happen to have a link to their mounts? All I see is their anti-sub bracket
mmm-five
Post by mmm-five » Sun May 28, 2023 3:31 pm
I only mention the PSDesigns floor mounts because that was the set I was recommended when I originally planned the install (along with the VAC motorsport ones).
My original plan was all VAC Motorsport items (except for the seats).
Unfortunately both the PSD and VAC were out of stock with no firm date for availability, so I swapped to Macht Schnell...on the basis that they were the same (as I'd seen them used elsewhere). But the fitting issue may be because of the sliders, rather than the mounts.
Plus their website doesn't even seem to list them now...
I got all my fittings (Recaro seats, side mounts & sliders, Macht Schnell floor mounts and hybrid belt mounts) from CA-Automotive in the end, as they offered a 10% discount for the bundle.
https://www.catune.co.uk/single_prod-cH ... 3MA==.html
Trigger’s Z4MC
Dubbedown
Post by Dubbedown » Mon May 29, 2023 12:17 am
mmm-five wrote: Sun May 28, 2023 3:31 pm I only mention the PSDesigns floor mounts because that was the set I was recommended when I originally planned the install (along with the VAC motorsport ones).
Good stuff, thanks for all the info. I suspect this will be a process, going to have to research and acquire parts slowly.
Wursle
Post by Wursle » Sun Sep 03, 2023 6:50 pm
Just to chime in on this thread, I recently installed some gosling racing mounts with a Recaro Abe. The install video is super simple and you only need 3 tools.
I’ve attached my video so you can take a look
Z4 Coupe E86 Recaro Pole Position ABE + Gosling Racing Adjustable Seat Mounts Install & Review
https://youtu.be/rlwHzfn_b-M
I have just made a video on installing the Recaro Pole Position ABE into my Z4 Coupe with the Adjustable Gosling Racing Seat Mounts.
In my opinion this offers the lowest adjustable seat option that is identical in height as solid mounts.
I’m new to doing YouTube videos, my content will be Z4 related with some bits on my E30 restoration
:D
Barty
Post by Barty » Tue Oct 17, 2023 11:08 am
Wursle, gave it a watch just now, thanks for sharing! Interesting to see your ideas and findings when it comes to fitting the seats.
Any thoughts on how you could overcome the rubbing issue? Ive got a mate with these in his Z4 where they don’t rub, but that’s because they’re on a custom made floor adapter frame, putting them even lower into the cabin. Ideally I’d run sliders too, but if they rub that way I might have to reconsider that. Would they rub without the sliders too? So straight mounted onto the floor adapters.
On a sidenote, good to see another green machine getting t some love :thumbsup:
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
Wursle
Post by Wursle » Fri Dec 01, 2023 4:32 pm
Barty wrote: Tue Oct 17, 2023 11:08 am Wursle, gave it a watch just now, thanks for sharing! Interesting to see your ideas and findings when it comes to fitting the seats.
Hey Barry,
Glad you enjoyed the video and yes there is a faint rub. So funny you mention about different floor mounts sitting it lower, I had some old e46 drift works side mounts kicking about and decided to give the passenger seat a test fit. These were even better and only slightly touched. So much so it wasn’t even noticeable with no impression on the seat. The issue I had though was actually getting on the nut on the tunnel side rear. It was incredibly difficult to get on and took about 1 hour to mount just 1 seat 😂 I have found a semi work around which isn’t perfect but atleast saves the rubbing for when I’m in the car, whenever I get out I slide the seat forward a few clicks and to prevent any contact, I am relatively tall (and wide) and found this an okay compromise for now until I find the perfect solution of no rubbing. I hope this helps, I will be releasing a new video soon on my thoughts of having the Recaro Pole position ABEs and how they compare to the competition
Barty
Post by Barty » Fri Dec 01, 2023 6:44 pm
Thanks Wursle, sounds good! Am I right in thinking you’ve now got E46 floor mounts and side mounts, on a set of sliders?
Looking forward to the comparison :thumbsup:
Wursle
Post by Wursle » Sun Dec 03, 2023 5:25 pm
Barty wrote: Fri Dec 01, 2023 6:44 pm Thanks Wursle, sounds good! Am I right in thinking you’ve now got E46 floor mounts and side mounts, on a set of sliders?
So I am using the E46 Sliders from Gosling Racing on the drivers side and just some driftworks mounts on the passenger mounted to the floor 😁
nitsuj
Post by nitsuj » Sun Jan 28, 2024 3:18 pm
Hello, I just discovered this forum! it's a mine of information for my z4 e85! I will install two recaros they look really good well done
Beedub
Post by Beedub » Mon Jan 29, 2024 9:01 pm
nitsuj wrote: Sun Jan 28, 2024 3:18 pm Hello, I just discovered this forum! it's a mine of information for my z4 e85! I will install two recaros they look really good well done
They are amazing seats! please post pics when you do your install!
