Glad you like it, it's going to odd driving to work tomorrow with the OE cluster back in.
What updates/repairs/mods have you planned for the winter?
Dave
2011, 23i, Grey with Red leather.
Nice Nick
I was in the Blue E89 before you, having a Mr12Volt MMI installed.
I must add, a big thanks to AnubisZed for the installation.
Will be interested if you can work out how to install a blind spot monitoring kit on our E89s.
- pvr
Denso starter ordered, couldn’t get any of the other recommended ones as are permanently out of stock.
Barty recommended it so should be fine.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
OnlineB21
I’m going with the ID4 Motion version that supports blind spot via radar…Silverstar wrote: ↑Tue Nov 14, 2023 9:03 pmWill be interested if you can work out how to install a blind spot monitoring kit on our E89s.
Interesting, but what sort of sensors are needed and how do you mount them? I’ve looked at some kits from AliExpress / alibaba but they require sensors to be mounted at the corners of the rear bumper behind the bumper trim but I don’t believe there is sufficient space to mount the sensors there.B21 wrote: ↑Tue Nov 14, 2023 9:34 pmI’m going with the ID4 Motion version that supports blind spot via radar…Silverstar wrote: ↑Tue Nov 14, 2023 9:03 pmWill be interested if you can work out how to install a blind spot monitoring kit on our E89s.
OnlineB21
Radar based sensors that beam through the plastic..mounted inside the bumper…Silverstar wrote: ↑Tue Nov 14, 2023 11:40 pmInteresting, but what sort of sensors are needed and how do you mount them? I’ve looked at some kits from AliExpress / alibaba but they require sensors to be mounted at the corners of the rear bumper behind the bumper trim but I don’t believe there is sufficient space to mount the sensors there.B21 wrote: ↑Tue Nov 14, 2023 9:34 pmI’m going with the ID4 Motion version that supports blind spot via radar…Silverstar wrote: ↑Tue Nov 14, 2023 9:03 pm Will be interested if you can work out how to install a blind spot monitoring kit on our E89s.
https://id4motion.shop/collections/all- ... ot-monitor
Hmmm, I'll look into thatSilverstar wrote: ↑Tue Nov 14, 2023 9:03 pmWill be interested if you can work out how to install a blind spot monitoring kit on our E89s.
Dave
That looks more or less the same as kits sold on Ali for less than £100 but I guess you are paying for the integration with the ID4 cluster. Will be interested to see how you get on with the install of the sensors behind the bumper.AnubisZed wrote: ↑Wed Nov 15, 2023 8:20 am Radar based sensors that beam through the plastic..mounted inside the bumper…
OnlineB21
Yup I’m not into Chinese integration projects…s/w is the key…pressed the order button tonight so we will see…Silverstar wrote: ↑Wed Nov 15, 2023 10:45 pmThat looks more or less the same as kits sold on Ali for less than £100 but I guess you are paying for the integration with the ID4 cluster. Will be interested to see how you get on with the install of the sensors behind the bumper.AnubisZed wrote: ↑Wed Nov 15, 2023 8:20 am Radar based sensors that beam through the plastic..mounted inside the bumper…
Isn't your MMi box a Chinese Integration?B21 wrote: ↑Wed Nov 15, 2023 11:33 pmYup I’m not into Chinese integration projects…s/w is the key…pressed the order button tonight so we will see…Silverstar wrote: ↑Wed Nov 15, 2023 10:45 pmThat looks more or less the same as kits sold on Ali for less than £100 but I guess you are paying for the integration with the ID4 cluster. Will be interested to see how you get on with the install of the sensors behind the bumper.AnubisZed wrote: ↑Wed Nov 15, 2023 8:20 am Radar based sensors that beam through the plastic..mounted inside the bumper…
But anyway it will be great to see how you get on with the ID4 kit (cluster and blind spot kit).
OnlineB21
Silverstar wrote: ↑Thu Nov 16, 2023 8:33 pmIsn't your MMi box a Chinese Integration?B21 wrote: ↑Wed Nov 15, 2023 11:33 pmYup I’m not into Chinese integration projects…s/w is the key…pressed the order button tonight so we will see…Silverstar wrote: ↑Wed Nov 15, 2023 10:45 pm That looks more or less the same as kits sold on Ali for less than £100 but I guess you are paying for the integration with the ID4 cluster. Will be interested to see how you get on with the install of the sensors behind the bumper.
The radar blind spot stuff integrates with the Dutch ID4 unit..it’s made by Dutch people in Dutch-land ..the s/w is writttdn by Dutch-landers
I only do 2.5 k per year and it’s changed yearly. But it’s the first time I’ve decided to do it myself
The car is booked into Tuned UK in Wrexham for the Eibach handling package (Springs and set up) and have the the Meyle tie rods installed
2010 Black E89 35i
OnlineB21
I trust that's the Meyle HD track rod ends?Gingerlomax wrote: ↑Tue Dec 12, 2023 4:39 pm The car is booked into Tuned UK in Wrexham for the Eibach handling package (Springs and set up) and have the the Meyle tie rods installed
Will be interested to see what you think one its been aligned and re-sprung..
Make sure they get the front and rear toe in correct..and ask them to check the RTABs and associated linkage bushes for play n flex..
While theya re there ask em to pry bar the front bushes too..the top one especially wears badlly on N54 E89s..
