Maybe you have manual seats or/and no satnav?
z4m , whats the actual weight??
- Argenta
OnlineBeedub
ive read so many differing views, some say no driver 1390 , others just put 1480kg... but looking at some of the results here its very possible for this car to be sub 1400 .
- PerryGunn
Is it possible that people are mixing up two different European standards for measuring the weight of vehicles?
As an example, in Alpina's supplementary vehicle information manual it gives the weight of the RS as
1320kg DIN / 1395kg EU
DIN = vehicle with with 90% fuel, no driver, no luggage
EU = vehicle with 90% fuel, driver of 68kg and 7kg of luggage (giving the 75kg difference)
and, just to confuse matters further, I understand that the US have different standards for this so US-quoted curb weights will be different from those quoted for the European markets
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
OnlineBeedub
perry very possible..... i want to no what it weights without the driver, that car sat on its own, 75% or more fuel.
- RedUn
Leccy seats and sat nav here, few mods but I'd only expect to have dropped 20kg max?
IMOLA Z4///MR
- RedUn
I'd say just over 1400 in that case for a standard car?
IMOLA Z4///MR
- BMWZ4MC
That makes makes your ///MR 10kg lighter than my ///MC which is the weight difference stated by BMW IIRC.Franzino wrote:Z4M roadster on a car weight (used for the weight of trucks) => Total: 1.440kg = no driver / CSL wheels / with fluids / gas tank: ?
1395kg without a driver seems very light RedUn - how has yours been modified? With light weight back boxes and CSLs, mine came in at 1450kg without a driver.
S2000 GT - gone
- MrPT
I don’t think manual seats are much lighter. Wish I’d weighed both when I had them side by side! Can’t have been more than 3-4kg per seat and it’s weight that sits low in the car too.
The S54 is such a lump. The quoted weight of the ///M and the 3.0si are 100kg apart and nearly all of that is an engine sitting not-as-far-back-as-they-could-have-put-it-with-a-bit-more-effort.
An awesome lump, mind.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Argenta
True, to add I think the supposedly heavy M back boxes.
As for the el. seats, I think I’ve read 10kg’s extra somewhere, but considering 3 motors and some buttons/wires it does sound a bit much.
- GuidoK
dual backbox, larger front/rear brake discs, bigger diff (210 vs 188) and numerous small things like larger cv joints, added oil cooler etc etc.
But the bulk is the engine
OnlineBeedub
the exhaust system on the ///M is absolutely ridiculously heavy, and i mean seriously heavy the back boxes alone were like 20kg easily EACH... having removed it and handled it numerous times i could not believe the weight of it... All together with the cats this is a 65kg system, i saved a monster amount of weight in this area, my RPI ( which i hate btw) cam in at like 4kg each , cat section 6kg .
i really want to weight the car i wonder if i take it to the tip they will tell me the number on the bridge they use for the trucks.....
- Fishy Dave
As mentioned before, mine is 1483kg as above.
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Mazda RX-8 race car
- MrPT
Worth a try, but it only costs £10-£15 to get a car weighed at a proper weigh bridge. You might have some luck using this: https://www.gov.uk/find-weighbridge
Must be all that additional cow you've got in yours (extended leather that it - apologies to Mrs Dave).
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Fishy Dave
Corvette C6
Mazda RX-8 race car
Mazda RX-8 race car
- RedUn
I know it is strange, it was done on proper corner weighting scales so I know it's accurate?BMWZ4MC wrote: ↑Tue Jan 16, 2018 11:27 pmThat makes makes your ///MR 10kg lighter than my ///MC which is the weight difference stated by BMW IIRC.Franzino wrote:Z4M roadster on a car weight (used for the weight of trucks) => Total: 1.440kg = no driver / CSL wheels / with fluids / gas tank: ?
I've got very similar mods to you, plus brakes all round and decats, I'm assuming they are worth 10kg all in?
I can't think of anything else that would have dropped so much weight out?
I'll post a picture of the corner weighting later in case I can't see the wood for the trees
IMOLA Z4///MR
