Martyn's Z4M Coupe
Online
Martyn's Z4M Coupe
Absolutely stunning Martyn.
I wish BMW still made cars as good looking as this and the E46 M3. It just doesn’t get any better than this, Z4MC on CSLs.
Taz there’s a set for sale on this forum.
Looking for an E85 3.0si sport manual for the weekends
F22 M240i
E82 123d. Gone
E46 M3. Sold huge mistake
E46 330ci. Gone
F22 M240i
E82 123d. Gone
E46 330ci. Gone
- 3gGT01
Martyn's Z4M Coupe
Wow Martyn, that looks amazing!!! The silver color really pops! Not sure if you clay barred it or what, but it looks great. I would like to do some of the same mods you have done.
Where did you get that carbon fiber front splitter?
Just the right amount of splitter for a great looking street car. Not overly done like you might expect on a track car.
I ordered the front calipers you have and should be on there way this week. Would like to get the same coilovers you have, I see there is a 4-5 week lead time. At 112K miles, the stock struts are rough on bumps and also the 19" rims probably don't help me either.
Neat to see someone doing all this cool stuff to their M.
~Tom
~Tom
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
- Martyn
Martyn's Z4M Coupe
Thanks all.
The wheels are Atomic CSL reps from BM Autosport.
I gave it a quick machine polish as it was covered in crap and light marking where Ive been working on.
The splitter is from here: https://www.schmiedmann.com/en/product/ ... E8586EDCAR
- Martyn
Martyn's Z4M Coupe
So for those debating whether the transmission tunnel is smaller than the E46 M3.....I can confirm it's not! The trans doesn't appear to be any smaller either!
For reference, Z4M ZF gearbox next to an inline 6 E9x DCT box.
You all know what's coming next.
Sprung flywheel.
And of course, the DCT box bolted up into the Z4M.
No hammering of the trans tunnel at all.
Even the E46 M3 DCT trans mount bolted up to the Z4M trans mounting bolt holes perfect.
I'm absolutely battered from rolling around on the floor under the car so more updates to come over the next few days.
Sprung flywheel.
- Ed Doe
Martyn's Z4M Coupe
Honestly the most consistently interesting thread on the forum Martyn - hats off to you!
Looking forward to more updates as they come - personally DCT-ing my car isn't something I'd want to do but I'm fascinated to see the results you'll have!
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- TomK
Martyn's Z4M Coupe
All super interesting as usual Martyn, well done! So it's a box from an i6 correct? I've seen the v8m3 dct box is fairly different dimensions to ours so that makes sense.
Any thoughts why they didn't use the zf instead of the getrag manual box if the trans tunnel is the similar dimensions? I guess there must be some peculiarity of the zf to prevent it? Or just cheaper more likely?
- 1536Z4
Martyn's Z4M Coupe
Very interested in this Martyn and I hope this works out as you may remeber from this post viewtopic.php?t=130841
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- XMetal
Martyn's Z4M Coupe
I'm confused. Is that an E9x M3 DCT box or an E46 M3 SMG box? There's no such thing as an E46 M3 DCT
- Martyn
Martyn's Z4M Coupe
I did a DCT conversion on my old E46 M3 so had some parts left over like a custom gearbox mount for a DCT box and E 46 chassis.
The DCT gearbox is an e92 335i DCT gearbox flashed with modified M3 GTS software.
- XMetal
Martyn's Z4M Coupe
Gotcha - thanks for the clarification.
Online
Martyn's Z4M Coupe
This is amazing, great work. Hope to see more updates and maybe some videos?
Does the Z4m have the same traction and stability control systems as the E46 M3 and are you doing anything in that department to handle the extra horses Martyn? I wonder if you could implement E92 or later systems which are superior to the old gen stuff.
F22 M240i
E82 123d. Gone
E46 330ci. Gone
F22 M240i
E82 123d. Gone
E46 330ci. Gone
- Vanne
Martyn's Z4M Coupe
looks good man!
Powered by Severn Tuning
- Martyn
Martyn's Z4M Coupe
Regarding traction / stability, as I'm not using the stock ECU any more DSC is totally defunct, I'm using MaxxECUs traction control setup which is much more advanced than the stock system (The MK60 the Z4M uses is very similar to the MK60 setup in the later E46 M3), which craps its pants any time I went near the throttle lol.
I didn't get much done yesterday, or today but I did manage to measure the required length for the prop so it could be shortened and have the yoke changed to suit the gearbox. I dropped it off to a friends engineering company to see what he can do with it.
I cut the yoke from a 335i prop, ready to be grafted to a donor Z4M prop.
Donor Z4M prop.
Next up was to fit the DCT shifter to the car, the holes for the shifter were already there, and in exactly the right places! I chucked in some rivnuts, bolted it down and tested the trim. It all fits, but the gaiter really needs re-trimming due to the bulk of the E92 M3 DCT shifter.
I also modified the wiring for the paddle shifters I'll be using so they mimic the resistance of the OEM E9x M3 paddles. I'm going to re-use the pins from the stock clock spring as I'll no longer be running the stock multi function steering wheel. Once I have the position of the steering wheel where I want it I'll crimp on some dupont connectors and connect them to the clock spring.
I hope to fit the inline thermostat for the gearbox and connect up the gearbox oil cooler lines tomorrow, then I can partially fill the gearbox. I won't completely fill the gearbox until I have some form of exhaust on for obvious reasons.
Donor Z4M prop.
- LawrenceW
Martyn's Z4M Coupe
Loving this thread, this is several levels above my spannering capability so slightly in awe…
- 3gGT01
Martyn's Z4M Coupe
Great! Thanks for the info Martyn. Quite interesting stuff you are doing. Was doing my own tuning on my built 5.0L Mustang due to the expense for professional tuning on a dyno everytime I made a tweak... Really need a Dyno for tuning rather than collecting data on the street. Too expensive for a Dyno, unless tuning other cars to augment cost.Martyn wrote: ↑Tue May 02, 2023 8:27 pm Thanks all.
