You don't. I've had it for some of my beemers, some I haven't. Never bothered me when I haven't had my 'valet' key, never used it!
Things to look for/check
- tjlazer
WAS: black on black MR with carbon trim. NOW: IB/Champagne/Carbon ZMC
- bensz4mc
Thanks guys - I will ask if they have it and not worry it not
- MrPT
Obvious ticking or knocking sound from the engine.
Any little signs that show it might have been in an undeclared shunt, e.g. front wing or bumper misaligned.
Leaking from the underside - engine or diff.
Ask about the ABS pump specifically - whether it has been replaced or refurbed
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Beedub
Not many have all 3 keys with them!! not many at all.
OnlineMr Tidy
Not really sure what the 3rd key is for to be fair - bit of a chocolate teapot IMO!
If you lock the car with 1 of the proper ones then opening the car with the plastic one sets the alarm off (found this out at an airport parking site)!
I'd put much more time and effort into previous history and general condition.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- bensz4mc
Thanks for all the advice.. They are checking whether they can change the front discs included in the price at the mo.
- hopz121
Maybe switch to some uprated pads too at the same time OP?
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- bensz4mc
Work would be done at Approved dealer. Can they offer updated pads?
Would you recommend the pads get changed the same time at the disks or doesn't it matter?
- hopz121
Pads 100% need changing at the same time as Disc's
Approved dealer wont fit aftermarket parts so stick with OEM for now
Didn't realise you were buying from BMW
- bensz4mc
Thanks Hopz! Anything else you would get BMW to replace at my cost whilst the car is being prepped?
- tomscott
I would have the engine mounts and bolts checked. The mounts are rubber and one of them sits right behind the heat shield and tends to go quicker because of the heat plus with these cars being 10+ year old and being rubber they are probably past there best, one less thing to worry about.
in the next 10-20k I would also have the half shell bearings replaced for piece of mind. Its not technically in the service schedule but is a serviceable part and its really the only weakness of these engines. Depending how it has been used they wear differently. Its about £1000 to do and most would have the engine bolts and mounts done at the same time as its all in the same area and cheaper to do all together.
- MrPT
+1, great shout.tomscott wrote: ↑Fri Sep 08, 2017 11:30 am I would have the engine mounts and bolts checked. The mounts are rubber and one of them sits right behind the heat shield and tends to go quicker because of the heat plus with these cars being 10+ year old and being rubber they are probably past there best, one less thing to worry about.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- hopz121
It will come with a minimum 1 year warranty mate so I wouldn't worry too much for now.
Make sure they change the pads (at there cost) when changing the disc's
- tomscott
Ye each axle will cost you around £700+ so worth getting them to do it!
- bensz4mc
Are half shell bearings the same as rod bearings?
