Cdv removal clutch delay valve OMG!
- thanatu55
I currently have a Sprint Booster installed and set about mid way in race mode to negate laggy standing start. I don't race, it just helps it to set off like a normal car by adjusting the throttle response rather than clutch. Presumably without the CDV it would have the same effect but with much better fuel economy, and the Sprint Booster would just be a kind of 'sport' mode.
- Smartbear
I’m not sure how removing the cdv could improve fuel economy? Tell us more
e85 3.0si sold
- thanatu55
I mean by not having to use such an aggressive throttle response as I am at present when moving from a standing start. Or not having to use the Sprint Booster at all.
- Smartbear
Ahh!
e85 3.0si sold
- thanatu55
Basically I think I'm trying to say that because I already have a solution of sorts, I might not notice that much of a difference by removing the CDV, but it should be more fuel friendly and therefore wallet friendly!
- kis
Glad you asked... lots of people commenting / threads about this ATM!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- srhutch
- Moderator
Removing the CDV will have no effect on fuel. What it will stop is clutch slipping which is what the CDV induces.
- thanatu55
Again yes I understand, the effect on fuel would come from not using the Speed Booster as a means to negate the lag from a standing start that the CDV causes. With the Speed Booster set as high as it is at present it is bound to use up more fuel, for example; in an extreme case I could easily set off in second with it as s quickly as I could in first by adjusting the throttle resistance. Remove the cause of the lag and you remove the need for the Speed Booster.
- srhutch
- Moderator
It really isn't going to make that much difference that you'll notice when pulling away.
Was under the car the weekend, am I right in thinking my CDV has already been deleted?
- Ducklakeview
Hard to tell from that angle, but looks like it's gone, need a pic from the other side to be sure.
Mike
Mike
- Ducklakeview
There is NO way you could get away as fast in 2nd as in 1st, especially in a 2.0, sprint booster or not. Those sprint boosters are a waste of time and money, all they do is "move" the throttle map, they don't make it any "quicker" you get exactly the same effect by pressing further on the accelerator. Try pulling away quickly in 2nd and you'll see exactly what the CDV does, the clutch WILL slip..thanatu55 wrote: ↑Mon Oct 23, 2017 9:36 amAgain yes I understand, the effect on fuel would come from not using the Speed Booster as a means to negate the lag from a standing start that the CDV causes. With the Speed Booster set as high as it is at present it is bound to use up more fuel, for example; in an extreme case I could easily set off in second with it as s quickly as I could in first by adjusting the throttle resistance. Remove the cause of the lag and you remove the need for the Speed Booster.
Mike
- MrPT
Yes.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
You could try pulling away in second gear with loads of torque.....but don't expect your clutch to see out the week! The main reason that first gear ratios are set at the ratio they are in any sort of car is to manage the thermal energy of pull away, allowing for likely gradients that you might encounter. Most cars will pull away in 2nd but the thermal loading from increased torque load downstream of the clutch will quickly destroy a standard road car clutch if repeated regularly.thanatu55 wrote: ↑Mon Oct 23, 2017 9:36 amAgain yes I understand, the effect on fuel would come from not using the Speed Booster as a means to negate the lag from a standing start that the CDV causes. With the Speed Booster set as high as it is at present it is bound to use up more fuel, for example; in an extreme case I could easily set off in second with it as s quickly as I could in first by adjusting the throttle resistance. Remove the cause of the lag and you remove the need for the Speed Booster
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
- MACK
I don't understand why your trying to compensate for the cdv with a sprintbooster. Having a partially slipping clutch is still having a partial slipping clutch whether you use a BMW sport button (If installed),sprintbooster, remapDucklakeview wrote: ↑Mon Nov 06, 2017 10:49 pmThere is NO way you could get away as fast in 2nd as in 1st, especially in a 2.0, sprint booster or not. Those sprint boosters are a waste of time and money, all they do is "move" the throttle map, they don't make it any "quicker" you get exactly the same effect by pressing further on the accelerator. Try pulling away quickly in 2nd and you'll see exactly what the CDV does, the clutch WILL slip..thanatu55 wrote: ↑Mon Oct 23, 2017 9:36 amAgain yes I understand, the effect on fuel would come from not using the Speed Booster as a means to negate the lag from a standing start that the CDV causes. With the Speed Booster set as high as it is at present it is bound to use up more fuel, for example; in an extreme case I could easily set off in second with it as s quickly as I could in first by adjusting the throttle resistance. Remove the cause of the lag and you remove the need for the Speed Booster.
Mike
or even turbo/supercharge it. The clutch issue will still detract from the performance so you really want to fix that with the CDV removal rather than try to compensate or mask it in some way.
I don't understand why the sprintbooster gets such a bad rap. I can understand some loving and some loathing the sharpened throttle response. but what I can understand is why their sneered at yet It does to the throttle exactly what the BMW sport button does and folks seem to like that. In fact sprintboosters allow you an even sharper throttle response than the sport button does which really livens up the car. Its the same trick a lot of remappers employ on normally aspirated cars, thats why do many folks rave about their remap afterwards despite the headline gains being marginal. My biggest issue these days with sprintboosters is they've become so damn expensive, you might as well pay a little more for a proper remap.
Silver 05 3.0i SE
White E89 20i M Sport
