Bradz Z4MC Project thread, Back on the road!
"M" Specific discussion
Beedub
Post by Beedub » Fri Nov 10, 2017 8:41 pm
TomK wrote: ↑Fri Nov 10, 2017 8:30 pm
Beedub wrote: ↑Fri Nov 10, 2017 8:23 pm i run -2.7 with the billet top mounts and a combo of the shims i do it this way, because the window in the strut top is so small that the camber plates aren't that usable without pulling the damper anyway, which is still abit of a pain considering how easy it should be with plates and the solid top end,
The correct solution for that problem, but it's a bit severe.
Welding-plates
We also have welding-plates which you can weld in the domes of the vehicle.
You have then to cut off the original domes and replace it by the thicker (5mm thick) welding plates. Because these plates are flat, you get more adjustment range for the camber and caster. Also, the car is a lot stronger and prevents the domes from tearing.
great solution but i really didn't want to cut the chassis and weld these in... i got the camber at a happy medium for my use, the -2.5 area really work well on this car and combined with spirited driving tyre wear isn't anywhere near as bad as you'd expect. Turn in is lovely, razor sharp, with my additional widen track the old girl feel stable as hell.
i really should start to experiment abit more with the rebound and compression but i CBA. i put in KW recommended Nurburg settings and pretty much left it alone so far, the car is so well controlled....
TomK
Post by TomK » Fri Nov 10, 2017 8:50 pm
Beedub wrote: ↑Fri Nov 10, 2017 8:41 pm but i really didn't want to cut the chassis and weld these in...
I didn't think you would :lol:
Beedub wrote: ↑Fri Nov 10, 2017 8:41 pmthe -2.5 area really work well on this car and combined with spirited driving tyre wear isn't anywhere near as bad as you'd expect. Turn in is lovely, razor sharp, with my additional widen track the old girl feel stable as hell.
Agree, I have the same, it doesn't seem to kill them that badly on the road, I do a fair few miles, but then balance it perhaps with a fair few track miles. Overall, wear is acceptable to me set at 2.5.
bradz
Post by bradz » Fri Nov 10, 2017 10:24 pm
Superb, Thanks Beedub & Tom, I'll stick with the stock top mounts for now and go down this route.
Z4M Coupe, E92 M3, E46 M3 Track car :driving:
bradz
Post by bradz » Sat Nov 18, 2017 5:59 pm
Small update...
Collected the freshly blasted and powder coated parts last night.
Superpro E46 M3 Subframe bushes fitted
Superpro RTAB Bushes fitted
Powerflex Front Diff bush
4x New Meyle Rose Bushes
2x New Lemforder Upper arm bushes.
2x New Meyle Wheel bearings.
Just waiting for the diff back from the specialist..
Now to tackle the brake lines.... :thumbsdown:
bmwaddict
Post by bmwaddict » Sat Nov 18, 2017 6:23 pm
Nice work Adam! :thumbsup:
Currently zedless :(
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
bradz
Post by bradz » Mon Dec 11, 2017 10:06 pm
Small update.
Porsche rear calipers have come back from being refurbished.
Supersprint powerloop rear boxes arrived
H&R e46 m3 ARB delivered
Genuine bmw steel brake lines (ABS to rear flexi)
Ordered
Apex ARC-8 9.5" square setup.
Groundforce top mounts.
Diff is having a new bearing kit as under a microscope the output bearings were showing early signs of wear, surprised on a genuine 60k car.. but then again the oil has probably never been changed as bmw say it doesn't need changing 😑
Beedub
Post by Beedub » Mon Dec 11, 2017 10:19 pm
ok...... This car is about to transform !!!!
so jealous on the power loops!!!!!!! WANT!!!
Mangozac
Post by Mangozac » Tue Dec 12, 2017 7:58 am
bradz wrote: ↑Mon Dec 11, 2017 10:06 pm but then again the oil has probably never been changed as bmw say it doesn't need changing 😑
The service list actually specifies changing Z4M transmission and diff fluids at inspection 2, so they should have been done by 60k miles...
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
bradz
Post by bradz » Tue Dec 12, 2017 12:31 pm
Mangozac wrote: ↑Tue Dec 12, 2017 7:58 am
Interesting.. Maybe it was just the Si diff that was sealed for life? thanks for that, The car has FBWSH but there is no mention of it being done on its 60k inspection 2 and the oil certainly wasn't clean at 63k!
Adam
bradz
Post by bradz » Tue Dec 12, 2017 12:36 pm
Beedub wrote: ↑Mon Dec 11, 2017 10:19 pm ok...... This car is about to transform !!!!
Slowly does it... :driving:
Apex did me a deal on the top mounts so I decided to go down that route instead of running the shim kit. Do it once do it right!
Beedub... Cup'2s or Ns2-r's? Cup 2's are coming in at 900 and the Ns2r's are coming in at Β£500
Or middle ground of Ad08r?
Part of me wants the Michelin's because they are the dogs... But I don't want to destroy Β£900 of tyres on a track day :headbang:
Fishy Dave
Post by Fishy Dave » Tue Dec 12, 2017 1:48 pm
bradz wrote: ↑Mon Dec 11, 2017 10:06 pmApex ARC-8 9.5" square setup.
Ooh, nice, that's exactly what I have been looking at, what colour have you chosen?
bradz wrote: ↑Tue Dec 12, 2017 12:36 pmCup'2s or Ns2-r's? Cup 2's are coming in at 900 and the Ns2r's are coming in at Β£500
It looks like they have stopped doing the 'track' compound of NS2R, but I am happy enough with the street version anyway. I'm sure that the Cup 2's will be quicker and based on feel and lap time Tom says the AD08R are quicker than the NS2R. For me I'll stick to the NS2R, the saving is substantial when wearing them out quickly. :)
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
bradz
Post by bradz » Tue Dec 12, 2017 1:54 pm
Fishy Dave wrote: ↑Tue Dec 12, 2017 1:48 pm
I went with satin black... The reason for this is the pic I have attached... With my phoenix gold calipers all round it just looks so right to me! ofcourse being a coupe it will be even better :rofl:
How much life do you get out of the NS2R's Dave? a few trackdays? I dont really plan to do many road miles other than to SPA & the ring.
Adam
Fishy Dave
Post by Fishy Dave » Tue Dec 12, 2017 4:11 pm
bradz wrote: ↑Tue Dec 12, 2017 1:54 pmof course being a coupe it won't be as much fun in the summer
:P
I haven't done a trackday for over a year now, but my first set lasted a 'Ring trip, drift day and four or possibly five UK trackdays plus a few thousand road miles. By the end they were VERY low on tread.
Corvette C6
Mazda RX-8 race car
bradz
Post by bradz » Tue Dec 12, 2017 7:47 pm
Fishy Dave wrote: ↑Tue Dec 12, 2017 4:11 pm
:P
Haha! Love a bit of banter!
That's a lot more than I expected to be honest. How do you find the road noise on them? That's what really puts me off.. a long drive with a horrible drone makes me think its worth paying the extra... the cups are actually quieter than the Super sports!
Are you on the 120 or the 180's?
Fishy Dave
Post by Fishy Dave » Tue Dec 12, 2017 7:54 pm
No drone, they are just like a normal road tyre in that respect, unlike the R888R on the race car. :)
Corvette C6
Mazda RX-8 race car
