Is rust an issue?
Is rust an issue?
I come from a Mazda MX5 background so take this with a very healthy dose of pessimism but my E89 is going to be my daily, will be used in all weathers and is going to live outside. Are they well protected or should I take any precautions to make sure it stays in the perfect condition it is in? Are there any particular weak areas I should be aware of i.e. drain holes that can get blocked?
Thanks. Any advice will be gladly accepted.
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- Zed Five
Is rust an issue?
No rust in my 7years of ownership.daily driver. Side badges and boot badge deteriorate, but thats it.
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
Is rust an issue?
Main rust you will find is underneath, structural reinforcement bars and similar. It’s surface rust and will likely be 20 years before requiring replacement. No body issues I’m aware of.
Is rust an issue?
My cars coming up to eight years old, the only rust i have seen is on, discs and rear brake calipers, the rear axle support frame work which is thinly painted steel, a few brackets in that area and the rubber strips along the bottom of the side windows where corrosion is causing the rubber to bubble slightly as that used to on my old TR7 (that was a rust bucket), so nothing has advanced there in 40 years. Why the internal strip is not made of stainless, would have prevented that.
Also the badges in the centre of the wheels corrode and my original BMW alloy wheels i don't think were as good quality as the ones i had on Rover MGTF and that's saying something.
I think the Zed will look tidy for a long time seeing that it is mostly aluminium and plastic.
Is rust an issue?
All good then. MX5s rust for fun in the sills, rear arches and front chassis rails so to have one as a “keeper” it needs a healthy dose of underseal on anything exposed and in all the box sections.
In the spring I will get under my Z4 and clean up any exposed metal I can find and give it a coat of hammerite and stop worrying so much
Z4 S-Drive 35i
Audi TT S-line
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- Mr Tidy
Is rust an issue?
My E86 will is now 11 years old, and the only corrosion issue I've had was rear brake lines just behind where they pass under the passenger seat - but I don't know if E89s have the same arrangement.
Still "Ducklakeview" replaced them in copper for me a couple of months ago, so that's my advisories sorted!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- makeshiftuk
Is rust an issue?
Just bumping this thread up - has the consensus changed when it comes to rust protection/undersealing E89s or should I be comfortable going without? Rustbusters in Spalding are an outfit that were recommended to me: https://www.rust.co.uk/product/cat/our- ... service-24
I noticed some minor surface rust before I bought our E89, but it sounds like tin worm doesn't plague these cars much like it can/does with my other two cars.
Current:
- 2010 Maserati Quattroporte Sport GT S
- 2010 BMW 'E89' sDrive30i
- 2002 BMW 'E39' 530i Sport Touring
Past:
- '07 Maserati GranSport, '02 Jag XK8 Coupe, '03 BMW 530i Saloon, '02 MG ZR 105+, '94 Ford Probe 24v, '95 Renault Clio RT
Past:
- RobbiZ4
Is rust an issue?
Well, rust could be more or less an issue under the E89, very rarely on the surface.
Check out our discussions:
https://www-zroadster-com.translate.goo ... st-3204455
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
- makeshiftuk
Is rust an issue?
Thanks for sharing - I'll have the car up on a 2-post lift next week for a better look, but given this is going to be used all year round I'm tempted to get her undersealed anyway. I've also bookmarked your preventative roof maintenance threadRobbiZ4 wrote: ↑Thu Mar 10, 2022 10:55 pm Well, rust could be more or less an issue under the E89, very rarely on the surface.
Current:
Past:
Past:
Is rust an issue?
My car now 12 years old. No body corrosion, but usual suspects rust, so get annual lick of black paint.
Mainly rear trailing arm links and wheel mounts at front and rear are steel.
Few brackets for the lamp levelers, tension bars, bump plate stiffener.
Discs can spray up. I used just cheap silver paint does the job and rear caliper is steel so might need a few coats to stop rusting.
Nearly everything else is alloy.
When i pulled off one plastic side sill to replace due to a mark, there was a lot of dirt behind it.
I keep meaning to pull the other side to clean, but no sill corrosion.
Is rust an issue?
Under plastic sills where mud gathers.
My original 17 inch wheels from factory. I think this damage done by BMW fitting tyres, something to look out for.
Is rust an issue?
Isn't the body made of aluminium? So rust is out of the question for the panels, basically, maybe just some parts underneath.
2016 E89 28i | Melbourne red | Kansas / Canberra beige
Is rust an issue?
Only the bonnet, front wings and roof panels are aluminium. The bootlid, doors and rear wings are steel. It's to do with BMW's famous 'near 50-50 weight distribution' thing. The roof being ally helps in lowering the centre of gravity and means smaller motors and hydraulics to move it.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- enuff_zed
Is rust an issue?
But rust is just the name given to corrosion on iron or steel. Aluminium can corrode too.
- RobbiZ4
Is rust an issue?
Correct.
And there were lots of E89 with corrosion on the roof panels made of alloy.
