Rough idle and injector cleaner
- R.E92
I don't think it's a case of them getting dirty as the fix was an injector design change. I think it's more likely the issue is accelerated component wear or a weakness which causes the injectors to eventually leak.
The injector issue is a common talking point. Some people choose to fit reconditioned injectors to save a little money but those same people seem to still end up replacing all 6 injectors with new ones due to issues. The price of new injectors and the replacement procedure has fallen over the years, may be worth getting a quote from an independent garage if the dealer doesn't give goodwill.
There was a recall in the USA but not here.
Well got a response back from BMW which was as expected jus a bland no your vehicle has not been subject of a recall for dodgy fuel injectors.
If there's a design flaw with N54 injectors and there's multiple versions, how do you find out which version is fitted?
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Smartbear
If you need replacements just get the latest revision number, what’s fitted now shouldn’t really matter?Nanu wrote: ↑Thu Sep 24, 2020 8:12 pm Well got a response back from BMW which was as expected jus a bland no your vehicle has not been subject of a recall for dodgy fuel injectors.
e85 3.0si sold
- R.E92
It's written on the top part of the injector, not sure if visible without removing them though.Nanu wrote: ↑Thu Sep 24, 2020 8:12 pm Well got a response back from BMW which was as expected jus a bland no your vehicle has not been subject of a recall for dodgy fuel injectors.
Here's a pic, the revision number comes after the part number in the top right. These are revision 12.
Thanks but I was just going to try and find out which ones were fitted to mine and if they are the same as ones already subject to recall in other models or in the USA.Smartbear wrote: ↑Thu Sep 24, 2020 8:28 pmIf you need replacements just get the latest revision number, what’s fitted now shouldn’t really matter?Nanu wrote: ↑Thu Sep 24, 2020 8:12 pm Well got a response back from BMW which was as expected jus a bland no your vehicle has not been subject of a recall for dodgy fuel injectors.
If they were I was going to put the question to BMW that if they were faulty in the USA how are they not faulty here?
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- ph001
Good luck with that!
- Smartbear
It’s due to group action in the USA, you’ve not got a snowflake in hells chance of bmw granting the same concession over here in the ukNanu wrote: ↑Fri Sep 25, 2020 8:05 pmThanks but I was just going to try and find out which ones were fitted to mine and if they are the same as ones already subject to recall in other models or in the USA.Smartbear wrote: ↑Thu Sep 24, 2020 8:28 pmIf you need replacements just get the latest revision number, what’s fitted now shouldn’t really matter?Nanu wrote: ↑Thu Sep 24, 2020 8:12 pm Well got a response back from BMW which was as expected jus a bland no your vehicle has not been subject of a recall for dodgy fuel injectors.
e85 3.0si sold
Brutal ..could you not sugar coat it?Smartbear wrote: ↑Mon Sep 28, 2020 6:27 pmIt’s due to group action in the USA, you’ve not got a snowflake in hells chance of bmw granting the same concession over here in the ukNanu wrote: ↑Fri Sep 25, 2020 8:05 pmThanks but I was just going to try and find out which ones were fitted to mine and if they are the same as ones already subject to recall in other models or in the USA.
As an aside bought some Redex at Lidl today....expecting another 5 bhp at least..
Thanks Guys,
Just sent them a response that I was not happy about the issue and left it at that. At some point in the future if they do a recall then at least I have registered my displeasure and would then take legal action to recover what I am no doubt about to spend on new injectors. Unlikely but you never know.
PS. Not happy with the pics of the Atacama zed. Want one that's newer than my 2014 35is, but don't think there is one out there.
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
2013 was the last model year for Atacama Yellow...very few 35i 35is were made for the UK market....also not many were ‘fully loaded’ ..I guess cause the retail price premium of the 35’s...
Maybe a re-spray...about £3,000?
I have resigned myself to having to replace the injectors and my Indy mechanic reckons circa £200 per injector for index 12 and says he wouldn’t recommend fitting anything other than genuine new ones. Apparently there are cheaper ones which turn out to be refurbished. Now waiting for a price but in the mean time, anyone purchased these recently and can recommend where to get them.
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
Don’t think the yellow would match the orange leather trim inside
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
Getting new injectors fitted tomorrow by my local Indy. Not sure of final price as he said he would search for best price for genuine BMW injectors so expecting circa £200 each plus fitting which he says is not a big job. Not cheap but it has to be done so hope it fixes the problem and the old girl is back to peak performance.
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- ph001
Injectors: 1353 8648937-12 is the latest index 12 injector and seem reliable. They were £102 ech from a main dealer as of Jan 2018, but typically these were only used for warranty work and BMW will want to retail part number 1353 8616079-12 which is exactly the same but with a £240 price tag.
