Removing Hand Brake and Cover
- PaulN
Hi,
Just looking to replace the hand brake handle which i know just pulls off
Has anyone took the cover assemble or Gaitor Assembly off as they suggest having it inside out and tie wrapping it onto the inner shaft before pulling it the right way around and fitting in position before putting the new Handbrake handle on.
PaulN
PaulN
Everything Happens for a Reason!
14 TT Black Edition
07 Z4 2.0 SE Jet Black
06 Freelander Sport Java Black
14 TT Black Edition
- pvr
Re: Removing Hand Brake and Cover
Here you go ...
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- PaulN
Lovely!
Which lot of clips should i attack first and is it easy to get your fingers under? Oh yeah and what handle did you put on?
PaulN
Ps Nice watch Mr Bond!
PaulN
14 TT Black Edition
14 TT Black Edition
- srhutch
- Moderator
Paul
PVR didnt change the handbrake but removed it to install SatNav.
- pvr
And that is not me in the picture - I would never wear white trousers when working on a car but I guess I was doing the dirty work ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- PaulN
Cheers,
I wasn't going to mention the white slacks.....
Stupidly Only checked on the way to work this morning (didn't go in the Z) and mine seems to be all in one from the back of the handbrake right to the front of the gear stick????
I guess its a case of brute force and getting them off....
Thanks for the photos chap, really helps.
PaulN
PaulN
14 TT Black Edition
14 TT Black Edition
- pvr
ah, ok. You may not have the armrest then ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- PaulN
Hi,
Managed to have a good look at the handbrake last weekend, and got the trim off and found the tie wrap holding the gaitor on.
One thing was i really tried to get the handle off but it would shift.... Is it just like the gear knob, pull it till it flys off?
PaulN
PaulN
14 TT Black Edition
14 TT Black Edition
- fallingman
Okay, I know I'm 2 years late to this thread's party,b ut I got my 05-reg Z4 2.0 a couple of weeks ago and am already modding, albeit modestly.PaulN wrote:Hi,
PaulN
I ordered and received my Storm Motorwerks gear knob and hand brake cover. Gear knob successfully installed - and I didn't even give myself a black eye in the process! Pics to come.
However, I'm having trouble removing the old hand brake cover. Gaitor removed, tie-clip removed, pulled very hard, cover just won't budge. There appears to be some clipping going on with the plastic cover securing itself over a couple of protrusions in the metal shaft.
Any help, advice, sympathy gratefully recieved.
Cheers!
E85 Z4R 2.0i Sapphire Black (2005)
Done: Storm Motorwerks gear knob and hand brake cover, AUX-in, chrome tailpipe, gapTech RCH+
- andysat
Hi and welcome-i too have a stormwerks gearknob -would like to see the pics with the handbrake when you get round to doing it.
Gone but not forgotten.
New ride silver e93.
- fallingman
So how does that happen?
You spend all day going back to the Z4 every hour or so to try and get the hand brake cover off, but to no avail - hence frustrated post above.
Then you go back the next day and, whoosh, it comes off first try.
Ambient temperature maybe?
Anyway, here's the result...
- bradmarsh1989
I can't get my handbrake off! I am such a pansy! Do I really just PULL AND PULL?
- Mau
You could do that, but you could also use a small hammer. Pictures from a small how to I posted on the Dutch forum:
More on the '03 roadster and '08 coupe:click me.
Need to replace my handbrake handle and was wondering, in the post above, the cover with the silver trim, is that an OEM part?
If yes, does anyone know the part number?
Can anyone tell me if you can remove the handle without removing the gaiter first ?
Does the zip tie for gaiter go round the end of the handle ?
2005 Z4 3.0 Black, Zhp gear knob.
