Hi all,
I’m having trouble hosting a signature picture. I know this has been covered a lot before and I’ve searched old posts and tried to recreate what’s been said by hosting my image and then using the marks.
Now, the issue I’m having is that photobucket no longer provides me with the correct link to host to a forum and when I copy the only link available, it doesn’t work. I’ve then used google images to host, copied and all i keep getting is that it cannot detect the size of the image and to check the URL is correct. I’ve used the link to resizeyourimage.com to ensure it wasn’t too big.
Any help would be gratefully received as I can’t believe it should be this difficult.
This is the image I am trying to post as my signature, both in its original and resized versions...
Signature Hosting
- Wyldie85
- Wyldie85
Signature Hosting
Here
- B60D79C7-AAB7-4E0D-8691-4F6411C19AF2.jpeg (31.37 KiB) Viewed 1418 times
- 99C4F00E-917B-4ECD-883B-8AFA8172C7E8.jpeg (651.38 KiB) Viewed 1418 times
Signature Hosting
i put mine on https://postimages.org/ works fine for yours!
Signature Hosting
have you tried that option? very simple to do once you have the file, just drop it on the website and it gives you the URL
- Wyldie85
Signature Hosting
Will give it a try now... thanks!
- Wyldie85
Signature Hosting
Thanks clarker63. This post can be deleted now if the mods would like!?
Signature Hosting
if you like!
- Wyldie85
Signature Hosting
I do indeed.
