Roof jammed!
Roof jammed!
Quick update, The second sensor seems to have done the job. No errors or bongs when operating the roof
Incidentally the sensor is made by TE automation part number ats0050 here is the data sheet
https://www.te.com/global-en/product-CA ... asheet.pdf]
- maxman
Roof jammed!
Good to see it fixed with a big cost saving.
- tintoverano
Roof jammed!
please, out of the 4 similar ones, where was the culprit located?mole734 wrote: ↑Fri Jul 17, 2020 7:31 pm Quick update, The second sensor seems to have done the job. No errors or bongs when operating the roof
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
Roof jammed!
There's a silver hydraulic ram on the right side of the boot that raises the rear section, the 2 sensors I replaced clip into the underside of that ram, you need to remove some of the trim panels to see them
- tintoverano
Roof jammed!
cool, thanks
mSport 23i
- ProfCJJ
Roof jammed!
I got myself a couple of these sensors (the cheaper ones) and put them in my toolbox just in case they are needed (hopefully never!)
Thanks for the info.
Roof jammed!
I was thinking to do the same, might be worthwhile stocking up on them before BMW decide to jack the prices up on these too. LOL
- ProfCJJ
Roof jammed!
Yes, its crazy money for sensors that are worth pennies really!Silverstar wrote: ↑Sat Jul 18, 2020 10:58 amI was thinking to do the same, might be worthwhile stocking up on them before BMW decide to jack the prices up on these too. LOL
Roof jammed!
I've currently brought a couple of these sensor's from the 2 series BMW, waiting for delivery on these at the moment. does anyone have a wiring guide on how to wire these up. i brought some parts which another forum member said i would need, but he appears to be off line at the moment.
i am a complete beginner with this but i have some friends that might be able to help me if i have a rough guide one what to do
2010 E89 Z4 - 23i M Sport - Deep Sea Blue
2004 E46 BMW 320d Sport - Mystic Blue (Daily)
- RobbiZ4
Roof jammed!
TBH, this is nonsense and not a recommendation.
If one of these sensors fail due to aging and/or corrosion, there are 2 standard fault scenarious:
- the boot won't open and you don't get access to the right ram and are not able to cut zip ties, open plugs, remove/reposition hydraulic hoses and replace these sensors
- the main pillar crashes into the NOT completely opened boot lid and you don't get access... [see above]
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
