Car on jack orange warning on ignition??
Often particularly if I’ve not driven my 2011 2.31 for a few days when I put key in the yellow “ car on jack” symbol shows. I’ve run through the service menu and despite the fact I’ve Cleared it back it comes,
Anyone had this?
Anyone had this?
- Smartbear
Annual inspection or mot due?
e85 3.0si sold
Both done .
My old 2.3i used to do this too. I always assumed it was a low battery... it seemed to go away if it was driven more often.
Some service item is due...MOT..Inspection..Brake Pads...Brake Fluid etc
Battery - Deffo.....
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
It was battery for me. I got it a few times last year...each after car hadn’t been used for a while and hadnt been left on trickle charger. Hasn’t appeared at all since battery was replaced a few months ago. “Service due”indicator is completely different symbol.
- obewan
Same experience hereColin_E wrote: ↑Thu Aug 06, 2020 8:11 am It was battery for me. I got it a few times last year...each after car hadn’t been used for a while and hadnt been left on trickle charger. Hasn’t appeared at all since battery was replaced a few months ago. “Service due”indicator is completely different symbol.
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Honda CB500F.
It’s on trickle charger now so I’ll check it tonight.
The car on jack indicates a service requirement as per rmanual see page..it MAY be caused (as so many things by a low / ageing battery).
It is a general call to arms and can be called by over a dozen possible functions see https://www.newtis.info/tisv2/a/en/e89- ... ts/1vVCauT
- E89 displays.jpg (137.23 KiB) Viewed 1214 times
It requires a service, nothing to do with the battery whatsoever.
- Smartbear
E89’s are proving to be sensitive to ailing batteries, they have caused issues like this before - they can also knock the electronic handbrake sideways and needing a software update to function again.Danglesberries wrote: ↑Mon Aug 10, 2020 11:05 pm It requires a service, nothing to do with the battery whatsoever.
The hardtop roof can also have issues with a below par battery.
e85 3.0si sold
May well be so, but the icon clearly advises 'Service Requirement'.
- Smartbear
As previously mentioned, icons can be falsely triggered by an aging battery so you can’t always take the warnings at face value as many on the forum have found outDanglesberries wrote: ↑Wed Aug 12, 2020 10:32 pm May well be so, but the icon clearly advises 'Service Requirement'.
e85 3.0si sold
