Flat laquer. Best cutting compound to use?
- Chris_D
My bootlids paint has gone as flat as a pancake. It's been on the job card for way too long now and I need to address it.
Got a D/A sorted, 1000W 150mm variable speed but need to choose the best heavy cutting compound.
Was thinking of Megs 105?
Then a polish with Megs Ultimate.
Anything better for flat paint revival?
Will throw a photo up later today.
- tomscott
Mags Ultimate compound is excellent
- Z4C_er
Yes, the ultimate compound is great, and as far as the correction stage goes, could be all you need. If you want to go further you could refine with 205 or Menzerna final finish 3000. Remember to seal/protect it after, as your polishing leaves no protection.Chris_D wrote: ↑Mon Sep 14, 2020 9:48 am My bootlids paint has gone as flat as a pancake. It's been on the job card for way too long now and I need to address it.
2006.5 E86 Z4C si SE Phoenix Yellow
Where are you based Chris? If you’re in Surrey and can make your way over I’ll do your bonnet for free. Have a look at Orginal Car Spa, my business
E86 3.0 M-Sport with lots of twiddly bits causing a decreasing bank account and my wife’s Audi A4 cabriolet to have extra work done so she keeps up.
- enuff_zed
Fair old way from Cloggy-land tbh. And even if you got his bonnet looking perfect, he'd still be stuck with his 'flat' bootlid.
Megs ultimate and a heavy cut microfibre pad
- Chris_D
Thanks buddy, kind offer but yes, unfortunately I’m across the channel in NL, so not so close to you.
I should be taking delivery of some bits and pieces to have a crack it myself soon....
Ordered some megs ultimate compound and polish.
Thx all for suggestions
- Chris_D
Not a bad result for a first-timer with a DA!
Wasn't quite expecting the results to be so good but I'm quite chuffed how my absolutely minging bootlid has turned out!
I thought I might have to resort to 2000grit for the first stage but I went straight in with a hexlogic orange pad. 2 passes with megs ultimate compound then 2 passes with the polish and a final layer of Harley wax.
Just need to get the rest of the car sorted now...
And there ya go........
Just like magic!...
Just like magic!...
- Chris_D
Got the bonnet done today. Got a nice mirror finish after finishing up with a layer of Harley wax. That stuff and the Megs is fekin amazin!
- Swiftly
That's popping
You surely clay barred or mitted it first right Christefer...?Chris_D wrote: ↑Tue Sep 22, 2020 6:11 pm Not a bad result for a first-timer with a DA!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Chris_D
Of course Johnny. That's a bit of a 'given' though isn't it?john-e89 wrote: ↑Sun Sep 27, 2020 10:04 amYou surely clay barred or mitted it first right Christefer...?Chris_D wrote: ↑Tue Sep 22, 2020 6:11 pm Not a bad result for a first-timer with a DA!
I used my trusty old Bilt Hamber blue claybar and just soapy demineralised water in a spraybottle. Does just as well as the ridiculously overpriced 'claybar lubricant' sprays.
I was also using a 50/50 mix of demin water and alcohol to wipe down every so often as there's a cherry tree close to where I was buffing that seems to be shedding an obnoxious amount of dust and dead leaves at the moment. Outrageous.
Try a clay mitt squire, so much easier than a bar and much quicker too boot. You can get a much better feel of how it’s going with a mitt too.Chris_D wrote: ↑Sun Sep 27, 2020 10:43 amOf course Johnny. That's a bit of a 'given' though isn't it?john-e89 wrote: ↑Sun Sep 27, 2020 10:04 amYou surely clay barred or mitted it first right Christefer...?Chris_D wrote: ↑Tue Sep 22, 2020 6:11 pm Not a bad result for a first-timer with a DA!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
