If that panicked you, be prepared for a lie down
Low idle speed ?
- Argyll Andy
Low idle speed ?
- D8802C1C-E1A9-48A9-A79D-E6315F68DDB5.jpeg (70.71 KiB) Viewed 362 times
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- N4LLY
- Argyll Andy
Low idle speed ?
The OH just loves taking all these random pictures when we’re out
- JimsZ
Low idle speed ?
I see the problem (sport mode) it draws you in
That and it’s the 35i / is I’m guessing.
E89/28i Msport gone .. Zx10r track bike gone… time for a KTM 350 exc-f and some green laning and dirt bike excursions…. Let’s see how this goes… :
- Argyll Andy
Low idle speed ?
I think sports mode x2 with the engine and gearbox that’s the problem, and the roads on my doorstep.
The DCT S mode holds the gear much higher before it changes
It’s not a problem............... until it’s time to refuel.
Yes, 35iS
- Portisz4
Low idle speed ?
Well,
It appears to be running at 550 rpm idle today with the Aircon off.
Smooth as a button and the gear stick is not shaking around either !!
Maybe I just happen to notice it when it's cold or not warmed up much.
- IMG_20201111_164624.jpg (109.12 KiB) Viewed 333 times
Low idle speed ?
It is upto normal operating temperature now unlike the previous photo..
Wonder if being a manual makes a difference..set a slower idle?
TIS says "Idle speed control
For idle speed control, the Digital Engine Electronics (DME) control the following factors:
Air mass (via Valvetronic and electrical throttle-valve actuator)
Injected fuel quantity
Point of ignition.
The set engine speed when idling depends on different conditions, for example coolant temperature or power requirement of the auxiliary components."
I assume no error codes when you looked?
Point of ignition.
