This is for US Specs pre-face lift version (03'-05') with the rear round reverse lights. Face lift models may be similar.
Disclaimer:
Whatever you do to your own car is your own responsibility.
Rear Foglight:
One way would to add a fog light is by using a rear red lamp to the rear of the car, wired directly to the battery with a relay and an aftermarket illuminated switch attached to the dash. This is what most conversion shops use, but I didn't do it that way. For my conversion I used an LED bulb for the fog light.
Marker lights
UK regs require two front white lights, while in the US it is amber. I used LED lamps which satisfy UK regs and passes the MOT.
MarkC
Note: Edited to minimize information acquired by those who would use it to profit from.
Addng Rear Fog light and Side Marker Lights to US Spec Zeds
- MarkC
- Aebous
Re: Addng Rear Fog light and Side Marker Lights to US Spec Zeds
Thanks a bunch!
I'm a bit unclear on the side markers. Your referring to the lights with the bmw roundels on them correct?
'03 Z4 3.0i manual transmission w/ sports package, interior xenons, wind deflector, Michelin Sport PS3's, cheap big brake upgrade, headlights with black internals and clear lenses, Alutech braces inc horizontal strut bar.
ZEEEE 4
ZEEEE 4
- MarkC
Hi, thanksAebous wrote:Thanks a bunch!
I didn't use power from the side BMW roundel lights but I'm sure it could be used some how.
I'll update the 'how-to', I also have some pics but need to find a place to store them (don't know if I can upload them here?).
Thanks, MarkC
- Aebous
Ohhh, ok. I'm bagging what your raking on the side lights now
Flikr works well with this forum.
ZEEEE 4
ZEEEE 4
- Aebous
Question, for the rear "foglight bulb" You mentioned you used a 1watt LED bulb.....are they that bright that it will pass inspection? Or is there a special type of automotive LED?
ZEEEE 4
ZEEEE 4
- MarkC
I used an automotive style LED bulb, it passed the MOT with out any issues.Aebous wrote:Question, for the rear "foglight bulb" You mentioned you used a 1watt LED bulb.....are they that bright that it will pass inspection? Or is there a special type of automotive LED?
- Aebous
Another question, now that I have looked at the bulb/housing in question, am I understanding correctly that you basically "deleted" one reverse light?
I.E. just put the bulb in the housing and left it in the trunk not visible outside the car?
ZEEEE 4
ZEEEE 4
- MarkC
Yes, you can use one reverse light as done in the UK and EU pre-facelift Z4s.Aebous wrote:Another question, now that I have looked at the bulb/housing in question, am I understanding correctly that you basically "deleted" one reverse light?
