Hi everyone,
From new, I've a 'buzzing' from the metal door speaker grills, especially when car is cold. You can only hear it at low speeds and is definitely from the speaker grills as when you put your hand on it, it stops. I've had it back in the dealership a couple of times, but both times I've had the car back with 'unable to reproduce fault'. Just wondering if anyone else has experienced same or similar issues.
Buzzing from door speaker grills
You need to take it to dealer and show them when it happens if you are able to reproduce it.
I’ve got a rattle from behind central...ish when the base hits.
It seems to get a lot better when warmed up.
