Drivers Master Switch for windows and mirrors - water ingress?
Hi
I’m a newbie to the forum and recently bought a 2009 E89 3.5i M-Sport Z4.
Absolutely over the moon with it!
However I have a couple of niggling issues that I want to sort.
It seems my master switch on the drivers side for all things, folding mirrors, mirror adjustment and windows gives up after a rain fall and becomes intermittent. Given the chance to dry out and on dryer days it doesn’t cause any problems at all.
There is no sign of water ingress in the car itself and body work is pristine with no signs of where water can get in.
Worth noting when the error occurs the passenger window works fine and the roof and windows work fine when operating the roof.
When it fails, diagnostics point to the footwell module but I’m told that this may pick up errors from further down the line.
Any one had a similar experience that maybe able to shed light on this problem?
I am armed with a multimeter to check when the problem reoccurs again but before I start pulling switches out of sockets thought I’d put it to the board first!
I had the same issue once where heavy condensation on the roof dripped onto the drivers side switch pack as the roof was opening..started working 2 days later as it dried out..
So I doubt its the FRM..more like water ingress somehow in and around the switch..
I had problem with some pins on the connector. My windows got stuck down.
I noted the illumination was not on so assumed a bad earth.
Pulling connector behind the door card and cleaning with contact cleaner, refitted, never had a problem since.
Where is this "master switch"? Do I have one on my E89?
2012 Z4 2.0 M-Sport Atacama Yellow
2000 Z3 3.0
2016 Vauxhall GTC Sunny Melon Yellow
2000 Jaguar X308 Sovereign 4.0
1969 Jensen Interceptor 6.3 litre
2000 Z3 3.0
- Nictrix
The switch they will be talking about is the panel of switches on the drivers arm rest on the door with the window/mirror buttons on it.SV8Predator wrote: ↑Sat May 29, 2021 9:23 pmWhere is this "master switch"? Do I have one on my E89?
Thanks. I don't seem to have a "master switch" that deals with all these functions.
Instead, I've got a panel of switches that has individual switches for mirrors, windows, etc. But no master switch.
2000 Z3 3.0
2000 Z3 3.0
It’s called the master switch as the E89 variant of this switch pack there is a toggle that opens / shuts all 4 windows in one go..SV8Predator wrote: ↑Sun May 30, 2021 10:07 amThanks. I don't seem to have a "master switch" that deals with all these functions.
- 80EA5741-808F-4DEA-B83E-3CCCE6B6D3D0.jpeg (17.6 KiB) Viewed 827 times
Yes, I've got that switch that moves all four of the windows.
But the OP was referring to a "master switch" for all things, folding mirrors, mirror adjustment and windows. I haven't got that.
2000 Z3 3.0
2000 Z3 3.0
Yup that unit does all those functions..mine does
One switch does all these functions? Really?
2000 Z3 3.0
2000 Z3 3.0
Just being silly now.
Thanks for the info.
I'll take a look at the connectors in the door also.
With this good weather we're having (now!) the problem hasn't completely gone away but (dare I say Master Switch ) is working more often than not. So there must still be a little damp from the torrential downpours we had in May.
When it doesn't work it tends to be for a 5-10min stint per day then works again all day.
I'll just have to wait until it rains again (when it doesn't work for longer periods) before i get the spanners out!
Cheers All.
Cheers All.
