Tyre cracking on runflats
Folks, had our Z4 for a few weeks, and one of the things that looked ok was the tyres, in terms of tread depth. They are all about 6mm, dot coded for 2017, so not massively old, but if I look in the treads I can see the rubber is cracked. I have only seen this before on old tyres, and usually more on the sidewalls, whereas the sidewalls on ours look ok. Are runflats more susceptible to cracking. My thoughts are to ditch the runflats but didn’t want to shell out on a set of tyres just yet.
Al
Al
BMW newbie, 2003 E85 2.5 SE - but after 10 Discoveries this ought to be a walk in the park
- Mr Tidy
Cracking on tyres seems to have only become an issue more recently, but I don't think it is just run-flats that suffer from it.
My sister just bought a 2018 Fiat 500 (on non run-flats) and when it had it's first MOT in May the tester gave it advisories for cracking on all 4 tyres.
Whether you change them probably depends on how bad the cracking is - but if you do you definitely don't want more run-flats!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- groovy_hippy
OP, are they Bridgestones? I seem to remember that it was an issue on the RE050 run flat…
Current ... 2007 Z4 Coupe 3.0si Sport | Manual | Alpine White | Black leather | Piano black dash
Intro to Zeds, now sold... 2007 Z4 2.5i SE Roadster | Manual | Stratus Grey | Red Leather | CDV delete | DLV backbox
- M1k3yC
The rears on my M135i were cracking after about four years. They also showed small cuts around some of the treads where the tyre makes contact with the road. The fronts didn't seem to suffer from it. All tyres were Michelin Pilot Super Sport and on the car since new.
2022 Hyundai Kona N - greyhound transport
2018 F56 Mini JCW
2016 MX-5 2.0 Sport Recaro
Gone to a good home: 2007 E86 3.0Si Sport
2018 F56 Mini JCW
Well swapped the runflats for a set of “normal” Bridgestones, and the ride is much nicer, less harsh, and not tramlining anywhere near as much.
Happier now
Al
Happier now
Al
- Chippie
Make sure you have a can or two of tyre weld and a 12v inflator in the boot just in case you get a puncturethespannerman wrote: ↑Tue Sep 21, 2021 5:07 pm Well swapped the runflats for a set of “normal” Bridgestones, and the ride is much nicer, less harsh, and not tramlining anywhere near as much.
Happier now
Al
Already had them
Al
Al
- Mr Tidy
That's great news.thespannerman wrote: ↑Tue Sep 21, 2021 5:07 pm Well swapped the runflats for a set of “normal” Bridgestones, and the ride is much nicer, less harsh, and not tramlining anywhere near as much.
Happier now
Al
I regret not binning them run-flats on either of my 3.0Si Coupes just to experience the difference, although I don't have run-flats now!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Further update. I did approx 50 miles yesterday, a mix of urban (full of pot holes and badly repaired surfaces) and rural ( fast but uneven) roads, and the car is transformed
It’s a much much nicer car to drive without the runflats, much more comfortable ride, no tramlining but still pin sharp steering.
Al
Al
Glad I spotted this! Couldn't understand why my Z4 just failed its MOT due to both RE050 rears having cracks in. Looking forward to switching to non-RFTs
Glad I spotted this! Couldn't understand why my Z4 just failed its MOT due to both RE050 rears having cracks in. Looking forward to switching to non-RFTsgroovy_hippy wrote: ↑Mon Jun 28, 2021 9:54 pm Tyre cracking on runflatsQuote groovy_hippy
by groovy_hippy »
Hi
Re050 s do crack a thing that can make them crack quicker is low tyre pressure I was surprised at was the recommended tyre pressure on my E92 coupe with the fronts at 38 psi and rears at 42 psi ! You would expect low to mid 30 s
Seems far too high for the weight of the car but that is what is recommended .
Allan
Allan
- dhobbs
I thought tyres cracking can only be an MOT advisory not a failure.
Maybe if you can see any of the structure through the crack but not for general aging
Happy to be proven wrong
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
https://www.gov.uk/guidance/mot-inspect ... tion-5-2-3
Tried pasting but doesn't come out well. Nothing on that list for cracks, so advisory.
