quick tyres question
Quote from the sticky guide:
"18” Tyre Sizes
Changing tyre sizes is also an option for those with 18” wheels. This could be because of a complex suspension and low spring set up, or simply to save some money on opting for slightly thinner tyres. The fronts can be changed from standard 225/40/18 to 215/40/18 (narrower) or 215/45/18 (narrower and for increased sidewall… comfort). Rear wheels as standard are 255/35/18 and this could be changed to 245/35/18 (narrower) or 245/40/18 (narrower and for increased sidewall… comfort)."
Now, i have order 245/40/18 on the rear, does it make a difference if i will go for 225/40/18 or 215/40/18 on the front?
Rears should arrive tommorow, want to change front tyres now, so wanted to double check vefore i would do a mistake.
"18” Tyre Sizes
04' 3.0i
- Mr Tidy
With 245/40 tyres on the rear fitting a 40 profile on the front will make it sit a bit higher at the rear in relation to the front, compared to the standard tyre sizes - if that matters!
I'd probably stick to 225 fronts, even if only for a bit more kerb protection for your wheels. But possibly go for 225/45 fronts. That was the standard size for the M models, with 255/40 rears.
But there probably isn't a wrong answer - it all comes down to personal preference and what you want to achieve. Your choice for rears suggests you may be looking for a bit more compliance to help the ride - if that is the case I'd definitely go for 225/45 fronts.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
The key point is that the rolling diameter / circumference of the front and rears should ideally be within 1% tolerance ..
That’s why the fronts are always one size up in terms of aspect ratio over the rears..
This is for E85/E89 not necessarily for other BMWs..
- sars
If you could explain why you want to change from stock sizes?
Stock size for the front alloy width is 8” so ideal is 225 or 235, minimum is 215 but that will limit the amount of rim protection afforded.
Standard sizes were, excepting Z4M
16”& 17” 8 x 16/17 ET47, 225/50 R16 or 225/45 R17 all round (square set up)
18” fronts 8 x 18 ET47, 225/40 R18 & 8.5 x 18 ET50, 255/35 R18 (staggered)
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
Thank you all for reply
car came with awful setup of 19" rims, changed that in first two weeks to 18" staggered 8/8.5j style 32 , MASSIVE difference. so was happy with it for a long time but now i think its time for the tyres to go and want to do proper size this time.
yes, more comfort and better grip. tyres i have now on are too stretched and its time for a change. Does 225/45 wont cause rubbing? i have standard suspension with fresh B4 bilstein
i never had standard sized tyres on.
04' 3.0i
- Mr Tidy
I suppose each car has slightly different tolerances but the width is the same as OE so that won't be an issue, just possibly more sidewall depth although there is a fair bit of height in the arches.
I've got H & R coil-overs so my car is about 15mm lower than standard and my 225/45s aren't a problem.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
thats great news, thank you
i actually found same tyres i bought for rear in said size and in great price as well so will order them today.
Thanks for help
04' 3.0i
Mattex trying to spam again, with his bot-generated, nonsensical posts - at least the link has been auto-filtered out.Mattex wrote: ↑Wed Jul 14, 2021 12:33 pm I'd go with 225 fronts just to give your wheels a little more kerb protection. 225/45 fronts, on the other hand, are a possibility. That was the standard size for M models, with 255/40 rear tires. It is very important to choose the right [url=https://*************.com/wheel-and-tire-packages.283376]wheels and tires[/url] for your car for your safety.
i did wonder about Mattex and every post of his having some embedded link somewhere. so has he been deleted now?
I assume so, but you think they'd go to a bit of effort to check where the majority of users are from and spam forums that are from the US where a US link may generate some interestbrillomaster wrote: ↑Wed Jul 14, 2021 4:24 pm i did wonder about Mattex and every post of his having some embedded link somewhere. so has he been deleted now?
