I need to renew my fronts (225/45/18) of a staggered set. The rears are in good shape - BridgeStone Potenza Runflats 255/40/18
I'm an advocate for the benefits of removing the runflats but does anyone have an opinion on replacing them in stages?
Non-runflat fronts and runflat rears?
Is the non runflats alone going to help with any tramlining and ride quality?
Runflat Rear Only?
- Street
Runflat Rear Only?
3.0si Coupe Sapphire Black Target 300k miles
3.0si Coupe Sapphire Black Why have 1 when you could have 2!!
Serial Zed tinkerer. Always looking for the next Zed project
- Zforbes
Runflat Rear Only?
You may get a difference in responses but IMO keep the axles the same and you'll be fine, tramlining is mainly the fronts so changing them to non RFT's will make the biggest difference. I did this on an E46 some years ago now with no issues what so ever, just don't forget to buy a slime / compressor kit just in case of a puntureStreet wrote: ↑Thu Sep 16, 2021 9:21 pm I need to renew my fronts (225/45/18) of a staggered set. The rears are in good shape - BridgeStone Potenza Runflats 255/40/18
Ride quality isn't as big as a difference as the tramlining though but a decent non RFT will give you lots more grip
E89 sDrive 35is Titan Silver Kansas Black Leather
Onlineronk
Runflat Rear Only?
I think that answers the question.
Don’t do it! Change all four tyres is the safest way.
- Street
Runflat Rear Only?
Cheers guys
Both good advice. I'll have a look into what I might get second hand for the rears towards replacements and go from there.
- M1k3yC
Runflat Rear Only?
I've posted my thoughts on runflats vs. non-runflats before. In short, I didn't like the Bridgestones that my E86 came with but was fine for years with Michelin runflats. I've recently moved away from runflats altogether and noticed a slight improvement but nothing (in my opinion) revolutionary. Some forum members have posted on here that runflats have improved a lot over recent years and now would be less concerned about running them.
To your question, I think that it depends on how you drive. I am normally not concerned about mixing tyres on a car as long as they are the same brand and type on each axle. My MX-5 is running like that until a couple wear out and I can match them all. However, if you like to drive hard and near the limit and expect a significant difference in grip between the front and back axle then I absolutely would not mix tyres in the way you're considering. You only need that to catch you out once and the bill will be much more than two tyres Personally, I wouldn't do what you're asking about for any length of time, despite what I've said about my MX-5, just because I don't like the idea of 50% runflat tyres. That's just my thoughts - the choice is yours and what's important is that you're confident in the car and consider it safe.
2022 Hyundai Kona N - greyhound transport
2018 F56 Mini JCW
2016 MX-5 2.0 Sport Recaro
Gone to a good home: 2007 E86 3.0Si Sport
2018 F56 Mini JCW
Runflat Rear Only?
how long do you think the rears will last before they need replacement?
sounds like it'll be a while yet, in which case i'd take the runflats off and put them on ebay.
i ran a mis matched run flat/non run flat combo on a daily driver with no adverse issues, but only did it so i could buy front tyres from one paycheck and rears from the next.
- Mr Tidy
Runflat Rear Only?
I've never had issues with tramlining on BMWs (E46s and E86M) with non run-flats, but I had a few other models (E87 1 Series and E9* 3 Series) with Pirelli, Continental and other brands of run-flats that didn't seem to suffer from it either.
The Bridgestone Potenzas on my 3.0Si Coupes were just awful, but as they had decent tread on both cars I never got around to swapping them for "proper" tyres.
As someone said non runflats on the front should help with any tramlining, but given where you sit in a Z4 I think the rears would be far more likely to improve the ride.
I've never tried it but I can't see why having two of each at opposite ends should be a problem, unless you are driving like you stole it!
You could always try selling your rear Potenzas, or maybe just turn the T/C off and have some fun.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- kinger
Runflat Rear Only?
Ive just had a similar decision to make .
I recently broke a 326 alloy on the back of my car, i bought a new one from Poland and went to get the tyre swapped.
The run flat Potenza tyre had started to delaminate inside so i swapped the rear pair for 'normal' tyres, the difference is ride is amazing.
So the front pair will be swapped very shortly, i think they will bring in enough money to self fund the swap.
As my car was sat waiting for its new alloy to arrive i was playing with my Carly, i got distracted and left it in for a little over 2 weeks.
So flat battery and 'Hand Brake' failure followed.
I do have a mate with a garage that has all the BMW software, he reset my car for me to sort that problem out.
So if anyone in the Somerset / south west area is looking for someone to fix their handbrake failure without paying BMW prices...DM and ill pass their info on.
Mike
Mike
Current - E89 35is Saphire Black
Previous- E89 35i Space Grey
