3" dual action polisher
Claying, polishing, waxing... share your secrets in here.
sw4nny
Post by sw4nny » Sun Sep 11, 2022 7:27 pm
Can anyone recommend a 3" car polishing machine,looking for a cheap one that will do the job,I am not after a profesional bit of kit just an easy to use decent one for an amateur.
Any links would be appreciated.
paddy wright
Post by paddy wright » Sun Sep 11, 2022 7:31 pm
I bought a cheap one off Amazon- about £90 a few years ago and it’s been good. Will try and find the link for you
Special Kay
Post by Special Kay » Sun Sep 11, 2022 7:53 pm
www.in2detailing.co.uk is worthy of a look swanny. the forensic detailing guy on youtube seems to rate him quite highly. Unfortunately, I can't offer any advice on which one is good but he does recommend the in2detailing machine. I hope it helps :thumbsup:
sw4nny
Post by sw4nny » Sun Sep 11, 2022 8:17 pm
Cheers guys :thumbsup:
After browsing gone for the spta mini one from amazon
True-Blue
Post by True-Blue » Sun Sep 11, 2022 8:56 pm
sw4nny wrote: Sun Sep 11, 2022 8:17 pm Cheers guys :thumbsup:
I’ve got the SPTA nano battery powered polisher and it’s great. Is the machine you’ve ordered a DA? Looks like it might be a rotary from the screenshot
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
sw4nny
Post by sw4nny » Sun Sep 11, 2022 9:01 pm
True-Blue wrote: Sun Sep 11, 2022 8:56 pm
Bollocks :headbang: i think you are correct
sw4nny
Post by sw4nny » Sun Sep 11, 2022 9:03 pm
True blue is yours a Da?
True-Blue
Post by True-Blue » Sun Sep 11, 2022 9:29 pm
sw4nny wrote: Sun Sep 11, 2022 9:03 pm True blue is yours a Da?
Yes, it can be da or rotary.
but the battery powered one isn’t up to the job of big panels. It’s brilliant for bumpers, door shuts, windscreen pillars, head lights that sort of thing. It’s not going to work for bonnets, doors, bigger panels… it’ll run out of steam and the batteries will flatten too quickly.
What do you want to use it for?
sw4nny
Post by sw4nny » Sun Sep 11, 2022 10:06 pm
Every panel but doesnt have to be in one hit,the cars paint isnt bad for 19 years just wanted to have a bash at machine polishing
I would start with the small less noticeable panels first,ie door shuts.
True-Blue
Post by True-Blue » Sun Sep 11, 2022 10:43 pm
sw4nny wrote: Sun Sep 11, 2022 10:06 pm Every panel but doesnt have to be in one hit,the cars paint isnt bad for 19 years just wanted to have a bash at machine polishing
The SPTA nano isn’t the machine for this.
You definitely want a dedicated 3’’ machine or bigger. Ideally a machine that can run 5.25’’ pads and 3’’ pads (2 backing plates). I polished for years with only a low cost das6 pro and 5.25’’ pads. It’s only in the last few years I’ve had more than one polishing machine.
True-Blue
Post by True-Blue » Sun Sep 11, 2022 10:47 pm
I think this is the SPTA 3’’ Dual action machine… reasonably well reviewed..
https://www.amazon.co.uk/SPTA-Variable- ... B07HXRGTPM
sw4nny
Post by sw4nny » Sun Sep 11, 2022 11:13 pm
True-Blue wrote: Sun Sep 11, 2022 10:47 pm I think this is the SPTA 3’’ Dual action machine… reasonably well reviewed..
I pondered between that one and the one i have purchased,i thought they were the same machines but with different kit,i did say i was an amateur :oops:
Bluecat
Post by Bluecat » Wed Sep 14, 2022 5:57 pm
You could try Ali express? www.Aliexpress.com. Stuff mostly comes from China but pretty much all the budget machines are made there. Posting will take a while and you need to factor in uk vat at 20%
